Software Archive
Read-only legacy content
17060 Discussions
How to protect SR300 against theft in public areas?
Pierre_L_3
I would like to use the RealSense SR300 (mounted on a Windows tablet) in stores, supermarkets, museums and other public areas. In these places, the devices will be accessible to everyone. Thus, I am looking for antitheft solutions (lockers, fixations, etc.). Has anyone solved this problem already? Can you share knowledge on that?
Regards.
samontab
Valued Contributor II
You can put a person there.
Pierre_L_3
Do you have a less expensive solution? A way to lock the SR300 to the tablet for example?
samontab
Instead of a person you could use a grad student ;)
Other than that, well, it will just depend on how far your thieves will go.
F200 does come with a tripod mount, so maybe SR300 as well has that. You could at a minimum secure it in a fixed tripod or similar structure. At least it would take a little while to take it.
Pierre_L_3
Thanks for your answer. Could you post a photo of your F200's tripod mount? It would help me braintsorm.
samontab
Well, it's a standard mounting hole at the bottom. Here's an image that I found in the web:
samontab
Just wanted to comment that it's sad that we have to devote time and energy in an Intel Technology forum to try to keep thieves away.
