Software Archive
Read-only legacy content
17060 Discussions
How to re-build project debug module?
Qinghu_Z_
I created a vert simple new project using HTML5 + Cordove with Blank temple  in Intel XDK. And then nuder DEVELOP tab, add the alert('Hello World!') to app.js as below:
function onAppReady() {
    alert('Hello World!');
    if( navigator.splashscreen && navigator.splashscreen.hide ) {   // Cordova API detected
        navigator.splashscreen.hide() ;
document.addEventListener("deviceready", onAppReady, false) ;
Switch to DEBUG tab, run Debug with USB connect to Samsung Galaxy S III. 'Hello World!' popup in the device without any problem.
Then switch to DEVELOP tab.  I added the second alert as below
    alert('at end of onAppReady');
After save the app.js, switch to  DEBUG tab and run Debug  again. Only 'Hello World!' popup.
I checked app.js code in Sources sub-tab under DEBUG tab. There is not 2nd alert
It look like the old project debug module is catched.
How can I re-build the project debug module?
Thanks for any help!
PaulF_IntelCorp
There has been an issue with caching of files by the Debug tab, however I have not found a reliable way to fix the issue. You should only have to close the debug session and restart it (using the Debug tab toolbar). There is no need to rebuild a debug module, that is not the source of the problem.
Qinghu_Z_
HI Paul, thanks for your reply. I found out it is the device issue. When I replaced the Samsung Galaxy 3 III with  Samsung Galaxy s Edge, debug show the modify result.
