Software Archive
Read-only legacy content
17060 Discussions
How to reduce the size of apps build in intel XDK
Farhan_A_
I develop my first app in intel xdk which is a very basic and simple app but the size of the .apk file is 6Mb and after installation the size of the app is 15Mb+ on the mobile phone..can anyone help me in this.
PaulF_IntelCorp
The size depends on which build target you used. The standard Android build with Gold option enabled will generate about 5-7MB file. The Crosswalk for Android build will give a minimum of about 15MB. The Cordova for Android build is much smaller.
The footprint you're describing is not terribly large, this is very typical of many apps. I would not expect it to grow dramatically beyond this size as you add more to your app. There is a minimum amount of space and memory required to support the underlying structure.
Alfred_B_
@Paul   "The standard Android build with Gold option enabled will generate about 5-7MB file
Please where is this option located? I have a similar issue... My 2.2mb HTML5 app became a 18MB apk.
PaulF_IntelCorp
@Alfred -- I'm guessing you built with Crosswalk. You can't decrease the size of the Crosswalk build, it will be a minimum of 15-18MB in size because it includes a complete web browser to use instead of the built-in webview on the device. Despite the size, this is the preferred solution for Android, because the built-in webviews on the majority of Android devices are very bad and inconsistent.
The "gold option" only applies to the older legacy builds. I do not recommend you invest time and effort in the legacy build system, it will be disappearing sometime in 2015 and cannot take advantage of the numerous Cordova plugins that are available for the Cordova and Crosswalk build systems.
John_H_6
I can understand apps growing under crosswalk (or anything as the underlying foundation becomes more robust).  But I just rebuilt 3 (Android) apps, each about 400k, under the latest version of the XDK.  One was strictly computational - about 20 inputs, just a little crunching, the other two were primarily in (constant) communication with a remote server.  Building without Crosswalk they grew to 1.83M.  Not unreasonable.  Build using Crosswalk (laughingly called 'Optimize with Crosswalk') they all grew to over 46M.  That is absurd.
jitendra_p_
 i have create my apk 31 mb size what is process reduce apk size.
jitendra patidar
jitendra.patidar07@gmail.com
9009186786
Michael_O_2
Optmise the size of your images and uncheck the Crosswalk option.
PARMINDER_S_
Hello ,Everyone
recently i develop a project and it includes upto 15 images total, no single image showing when anybody download this app,
i already update it but the issue still remains same.
please provide me solution.
