our App uses requires the camera permission.
But camera is not used at all.
We use the following plugins, but can't find a way to remove the camera permission.
Any help is welcome.
Cordova:
Device
In App Browser
SplashScreen
StatusBar
Intel:
Device
Player
Best,
Tom
- Tags:
- HTML5
- Intel® XDK
Hi Tom,
In the Plugin Management Section of your project settings you can see for each plugin which "android permission" is used.
For example: the Intel XDK Device plugin is using the Camera permission, that's because the included barcode scanner code. And a barcode scanner without camera doesn't make any sense ;-)
I see you use the Cordova device plugin too, maybe you don't need the intel.device plugin at all, but that depends of-course on your code.
So check all you plugins and it's permissions in the plugin management.
Ad
Hi Tom,
Ad
Thanks for the quick reply!
