Software Archive
Read-only legacy content
17061 Discussions
How to run xdk on fedora 23
Vengayi_M_
Hi folks,
I installed the 64 bit linux version on fedora 23 but it won't run.
Can anyone help?
PaulF_IntelCorp
We do not test or support running on that version of Linux. Sorry, but resources do not allow us to insure proper operation on all versions and variants of Linux. We recommend you use Ubuntu (you can create an Ubuntu VM on your Fedora machine).
hahn1
remove libudev.so.0 on /opt/intel/XDK
then make ln to lib64
$ sudo ln -s /lib64/libudev.so.1 libudev.so.0
in fedora 24 it's work.
Massimiliano_S_
I (possibly) fixed this issue on fedora 22 by importing somo ubunto libraries. I can provide them if anyone ask for it.
1) create directory /lib/x86_64-linux-gnu
2) create library files and links:
lrwxrwxrwx 1 root root      43 12 lug 12.26 libcgmanager.so.0 -> /lib/x86_64-linux-gnu/libcgmanager.so.0.0.0
-rw-r--r-- 1 root root  108480 12 lug 12.24 libcgmanager.so.0.0.0
-rw-r--r-- 1 root root 1930528 12 lug 12.10 libcrypto.so.1.0.0
lrwxrwxrwx 1 root root      42 12 lug 12.35 libnih-dbus.so.1 -> /lib/x86_64-linux-gnu/libnih-dbus.so.1.0.0
-rw-r--r-- 1 root root   38920 12 lug 12.35 libnih-dbus.so.1.0.0
lrwxrwxrwx 1 root root      37 12 lug 12.34 libnih.so.1 -> /lib/x86_64-linux-gnu/libnih.so.1.0.0
-rw-r--r-- 1 root root   96280 12 lug 12.33 libnih.so.1.0.0
-rw-r--r-- 1 root root  387256 12 lug 12.10 libssl.so.1.0.0
lrwxrwxrwx 1 root root      16 12 lug 12.13 libudev.so.1 -> libudev.so.1.3.5
-rw-r--r-- 1 root root   67600 12 lug 12.10 libudev.so.1.3.5
3) add file XDK.conf in /etc/ld.so.conf.d containing this line: "//lib/x86_64-linux-gnu"
4) run command "ldconfig"
5) install xdk software
Run it
Hope this helps
Carlo_M_
Hello Massimiliano,
Could you please provide a file to download, with included all the libraries?
Do you know if your solution still works on Fedora 24?
Thank you!
