I am trying to develop a function that can share content to wechat , but unfortunately , I tried some cordova plugin, but failed.
can anyone tell me which plugin should be used and will successful on XDK platform.
- Tags:
- HTML5
- Intel® XDK
Can yo tell me which plugin are you trying add?
Which XDK version are you using?
Which plugin did you try?
Not sure if it is suitable for your purpose but this plugin is pretty popular among our users - https://github.com/EddyVerbruggen/SocialSharing-PhoneGap-Plugin
The Intel XDK latest version (2496) has CLI 5.1.1 support. However, you will need to use Min Android API 14 with 5.1.1. Android v.14 supports Android 4+. So if you want your app to work with Android 2.3+ (versions before 4.0) you cannot use Cordova 5.1.1.
<Edit - Previously stated wrong version number. It is now correct.>
Thank you. I will try by using CLI 5.1.1
Are you still having this issue? Newer version of XDK is released 3088. You should try with newer version.
