Software Archive
Read-only legacy content
17060 Discussions
How to share content to wechat(weixin) ?
sam_y_
 I am trying to develop a function that can share content to wechat , but unfortunately , I tried some cordova plugin, but failed.
can anyone tell me which plugin should be used and will successful on XDK platform.
Amrita_C_Intel
Can yo tell me which plugin are you trying add?
Which XDK version are you using?
Pamela_H_Intel
Which plugin did you try?
Anusha_M_Intel1
Not sure if it is suitable for your purpose but this plugin is pretty popular among our users - https://github.com/EddyVerbruggen/SocialSharing-PhoneGap-Plugin
sam_y_
Hi My XDK version is 2366 and cordova CLI is 4.1.2. I tried com.wordsbaking.cordova.wechat , which listed on Cordova plugin , but build failed. And tried xu.li.cordova.wechat , build successful , but the Wechat object always by undefined and the header bar position of the page being not correct. the latest version of cordova is 5.1.1 , could we use it on XDK platform ?
Pamela_H_Intel
The Intel XDK latest version (2496) has CLI 5.1.1 support. However, you will need to use Min Android API 14 with 5.1.1. Android v.14 supports Android 4+. So if you want your app to work with Android 2.3+ (versions before 4.0) you cannot use Cordova 5.1.1.
<Edit - Previously stated wrong version number. It is now correct.>
sam_y_
Thank you. I will try by using CLI 5.1.1
Amrita_C_Intel
Are you still having this issue? Newer version of XDK is released 3088. You should try with newer version.
