Software Archive
Read-only legacy content
17060 Discussions
How to silence firmware logging message
JONG_L_
I have built a firmware via IFE 1.1 for a custom board, which is similar to MinnowBoard MAX.
1. Unlike MinnowBoard.MAX.X64.083.R01.bin, the firmware I built has lots of message. See below. Is there any way to get rid of more logging messages?
2. What caused "ERROR: C40000002:V0306000A I0 378D7B65-8DA9-4773-B6E4-A47826A833E1" at the bottom? What does that mean?
Jong
PlatformPei: Performance data = 12131830
GGC: 0x00000210 GMSsize:0x00000002
CheckCfioPnpSettings: CFIO Pnp Settings Disabled
Info: SeC PPI load sucessfully
SeCUmaEntry done
FtpmPolicyInit Entry
PcdfTPMEnable = 0x1
FtpmPolicyInit done
Previous boot cycle successfully completed handover to OS
Prioritizing Boot mode to BOOT_WITH_MINIMAL_CONFIGURATION
Setting BootMode to BOOT_WITH_MINIMAL_CONFIGURATION
Setup MMIO size ...
PROGRESS CODE: V00051001 I0
SeC Device ID: F18
SeC UMA Size Requested: 16384 KB
PROGRESS CODE: V00051002 I0
PROGRESS CODE: V00051003 I0
SeC Device ID: F18
Entered SeC DRAM Init Done procedure.
 SeCUmaBase read: 7EF, SeCUmaBaseExt: 0 and SeCUmaSize: 16 MB
UmaBase 7EF00000, UmaBaseExt 0
 HFS read before DID ACK: 1000195
 SEC R_DID_MSG written: 10000000
SEC DRAM Init Done ACK received.
BiosAction = 7
SEC FW DID Ack requested to continue to POST.
PROGRESS CODE: V030F100B I0
>>>>MemoryInit Done
Payload Fv Hob Built, BaseAddress=0xFFC00000, Size=1A0000
