Hello everyone
I want use the CAO mode of MKL.
I writed a sample code ,
#pragma offload target(mic) \
in(n, alpha, incx, incy) \
in(x:length(n)) \
in(y:length(n)) \
out(y:length(n))
cblas_caxpy(n, &alpha, x, incx, y, incy);
Compiler ICC printf some error message:
mkl_test.cpp(63): error: function "cblas_caxpy" called in offload region must have been declared with compatible "target" attribute
So , Is the MKL(2017) support 's CAO mode.
Yes, CAO is supported in MKL (see https://software.intel.com/en-us/node/528601)
A good example of how to use CAO can be downloaded here: https://software.intel.com/en-us/articles/intel-math-kernel-library-intel-mkl-compiler-assisted-offload-and-automatic-offload-example
Nguyen .
Thanks for response.
I run the example successful.
There is another important thing to note here. The MKL library of MIC is not installed by default, you need to manually install it.
