Software Archive
Read-only legacy content
17060 Discussions
How to use a SR300 on Windows 8.1
Hiroki_Takeyama
SR300 is only supported Windows10.
But because our application targeted Windows 8.1 and was developing so we wanted to use SR300 on it.
Does SR300 not work on it at all? Can't we make it work?
samontab
Valued Contributor II
Hiroki Takeyama wrote:
Quote:
samontab wrote:
Quote:
samontab wrote:
It seems that you can use the SR300 on Win8.1 as a F200. Have a look here:
https://software.intel.com/en-us/forums/realsense/topic/537872#comment-1...
Does it mean using SR300 with F200's DCM on Windows8.1? so can it be used as F200?
Now we have only F200 device.
if that method can do, we want to buy SR300 and try it.
I don't have a SR300 camera, so I can't tell you for sure. But it seems that it might be possible to use the SR300 as a F200 on Win8.1 based on the other users input.
but, it seems that your information is about setting Windows8 compatibility to old application on Windowss10.
because there are related modules which can't work on Windows10 now, if possible we want to use Windows8.1.
Ah yeah, you're right.
If you want to use Win8.1 you could try using librealsense. You can get it from github.
Xusheng_L_Intel
SR300 DCM ONLY supports window 10. If you want to use SR300 under windows 8.1 and use your own algorithm, you can use librealsense. It can be found @https://github.intel.com/PerCSystemsEngineering/librealsense. Thanks!
samontab
https://software.intel.com/en-us/forums/realsense/topic/537872#comment-1862332
Hiroki_Takeyama
That page couldn't be displayed.
Perhaps is it a closed page in the Intel?
PKusm
I think David is trying to show you this URL: https://github.com/IntelRealSense/librealsense
Hiroki_Takeyama
samontab
Hiroki_Takeyama
samontab
Hiroki_Takeyama
We decided that we would repare our modules so that these could work on Windows10.
We also checked the librealsense. but we couldn't use easily at once because our programs made by C#.
Thanks everybody!
