i need some help,
i can't installing intel hardware accelerated execution manager,
also can't uninstalling old version,It prompted me to missing hax.msi
So... i not kown what to do
- Tags:
- Virtualization
I don't believe this the right forum for this request but here are some related topics with the URLs. They may have hints for your issue.
- https://software.intel.com/en-us/forums/android-applications-on-intel-architecture/topic/537144
- https://software.intel.com/en-us/android/articles/how-to-use-the-intel-hardware-accelerated-execution-manager-intel-haxm-android-emulator
- https://software.intel.com/en-us/android/blogs/2013/12/11/performance-results-for-android-emulators-with-and-without-intel-haxm
- https://software.intel.com/en-us/videos/intel-haxm-drivers-making-your-emulators-run-faster-at-idf-2013
regards, -Thai
I also had trouble installing HAXM recently and after I read your post I decided to try a few things and whammy, I was able to figure it out and I now have HAXM installed and working. Make sure you have Hyper-v disabled. Then open a commandline prompt with admin rights and type "bcdedit /set hypervisorlaunchtype off" without the double quotes on each end. I would also restart just to be safe and then try installing HAXM. Just in case you need to re-enable Hypervisorlaunchtype, you would pull up commandline with admin rights and you would type out "bcdedit /set hypervisorlaunchtype auto" again minus the double quotes on each end. Hopefully that will resolve your troubles like it did mine.
Bill
