Software Archive
Read-only legacy content
17060 Discussions
I can't login to the program.
Fatih_A_
John_H_Intel2
Are you behind a firewall/proxy that could be blocking the XDK from connecting to our servers?
I see you do have apps in the cloud with that login, so at some point you were able to login. Were you able to login with a previous version of the XDK?
Fatih_A_
I don't use a firewall / proxy. I was using XDK. I changed the computer. Doesn't open now.
John_H_Intel2
Can you try logging into appCenter and see if you can login?
https://appcenter.html5tools-software.intel.com/csd/controlpanel.aspx?
Fatih_A_
I tried logging in again today. I can log in without any problems. Thank you for your interest. (:
Ramon_R_
I just installed XDK but I had the same problem on OS X Yosemite but in my case the login form does not appear--just the dimmed screen with the yellow bar. What can be done to solve this? Thanks,
PaulF_IntelCorp
There is an issue with the login servers that is being worked on. No estimate as to when it will be resolved.
