Software Archive
Read-only legacy content
17060 Discussions
I get the error below when I try to download a build of cordova crosswalk for android.
William_M_3
I get the error below when I try to download a build of cordova crosswalk for android. My other builds are able to download but for some reason cordova crosswalk can't.
Error:
NoSuchKey The specified key does not exist. cust.0205fb23-235c-4420-9301-0f4f414cd1c3/app.5fb46098-d321-4b9e-b0fb-69a7a498e200/ANDROID/bibleofmanycolors2-Crosswalk.201602085336.zip B7FBD617D764BA76 2/DTBrzYB7KQNzXzlY7DPndT8pYkosTKz4J+4yGy/MJauFgVi0XcgiXsxMnl8pT1J9iaPS9VKHM=
Amrita_C_Intel
Can you send the .zip file of your project?
Amrita_C_Intel
Which XDK version are you using?
William_M_3
The version of XDK I am using is 2893
William_M_3
Amrita,
I just sent you the zip file of my project.
Amrita_C_Intel
I was able to successfully build the app with Android crosswalk. Please see the attachment, assuming that this is the expected behaviour.FullSizeRender[1]_0.jpg
William_M_3
It does build for me as well. The problem is when I try to down load the files.
William_M_3
Are you able to download it or just build it? my error is with the downloading not the building.
William_M_3
in the first picture below you can see that in XDK I get to the screen where it has built and gives me the button to download the .apk files the "download crosswalk apks" button. when I click that button you can see on the next picture that error that comes up.
Anusha_M_Intel1
Hi William. I am not able to reproduce the error. It might be project based. Lets wait for Amrita to try your project. In the meantime, you can also email it to yourself. That might be a temporary workaround.
Anusha_M_Intel1
William it looks like this might be a login issue. So if you have ever logged in with a different user account, your browser might need to have its cache cleared. Can you try that?
Clear the cache on your browser or try a different browser
Try opening the link in a chrome incognito window, you should be prompted to signin
Remember, only the most recent build is able to be downloaded via the email. When you rebuild, the previous emails are invalid for downloading.
UPDATE:
Another user has had luck with CLI to 5.1.1 / CW 15. Could you try this config?
Amrita_C_Intel
Yes! if you upgrade to CLI 5.1.1 the error will go away and you will be able to download APK. Thank you so much for pointing that out. We have escalated this issue.
PaulF_IntelCorp
There is a bug in our build system causing this, specifically for CLI 4.1.2 and Crosswalk builds. At hotfix should be live in a few days to address it. This would be a good time to move to CLI 5.1.1, see this post for reasons why > https://software.intel.com/en-us/forums/intel-xdk/topic/606371
William_M_3
-Emailing it to myself creates the same error when I try to download it through the link in the email.
-This is not a login issue as I am able to download all other version(ISO, Android) so why would my logins work for those but not work for crosswalk? seems like a system issue on your end.
-I can not use CLI 5.1.1 because the plugins I am using don't work with CLI 5.1.1 so for now I am stuck with CLI 4.1.2.
hopefully the hotfix can resolve this problem.
John_H_Intel2
We are working on the issue.
John_H_Intel2
The issue has been fixed. Please rebuild your app and try downloading again.
Hamilton_Tenório_da_
Valued Contributor I
Confirmed: everything is OK.
