Software Archive
Read-only legacy content
IOS Build Fail
Nuno_A_
I'm not able to build for IOS.
Always gives error:
Build Log:
Building a Cordova 5.1.1 application.
The application name is "farmacia-nova"
The package name is "app.farmacia.nova"
Will use the provisioning profile for "production"
Plugin "cordova-plugin-splashscreen" (2.1.0) installed.
Plugin "cordova-plugin-device" (1.1.0) installed.
Plugin "cordova-plugin-dialogs" (1.2.0) installed.
Plugin "cordova-plugin-inappbrowser" (1.1.0) installed.
Plugin "cordova-plugin-network-information" (1.1.0) installed.
Targeting iOS version 7.0.
Error: A build error occurred. Check the build log.
LOG:
** BUILD FAILED **
The following build commands failed:
	Check dependencies
(1 failure)
Error code 65 for command: xcodebuild with args: -xcconfig,.../farmacia_viriato/platforms/ios/cordova/build-release.xcconfig,-project,farmacia-viriato.xcodeproj,ARCHS=armv7 armv7s arm64,-target,farmacia-viriato,-configuration,Release,-sdk,iphoneos,build,VALID_ARCHS=armv7 armv7s arm64,CONFIGURATION_BUILD_DIR=.../farmacia_viriato/platforms/ios/build/device,SHARED_PRECOMPS_DIR=.../farmacia_viriato/platforms/ios/build/sharedpch
Command finished with error code 2: .../farmacia_viriato/platforms/ios/cordova/build --release,--device
ERROR building one of the platforms: Error: .../farmacia_viriato/platforms/ios/cordova/build: Command failed with exit code 2
You may not have the required environment or OS to build this project
    at ChildProcess.whenDone (/Developer/cordova/5.1.1/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:134:23)
    at ChildProcess.EventEmitter.emit (events.js:98:17)
    at maybeClose (child_process.js:753:16)
    at Process.ChildProcess._handle.onexit (child_process.js:820:5)
Someone can help me?
Nuno_A_
Now gives the error:
** BUILD FAILED **
	CodeSign build/device/Farmacia\ Viriato.app
(1 failure)
Error code 65 for command: xcodebuild with args: -xcconfig,.../farmacia_viriato/platforms/ios/cordova/build-release.xcconfig,-project,Farmacia Viriato.xcodeproj,ARCHS=armv7 armv7s arm64,-target,Farmacia Viriato,-configuration,Release,-sdk,iphoneos,build,VALID_ARCHS=armv7 armv7s arm64,CONFIGURATION_BUILD_DIR=.../farmacia_viriato/platforms/ios/build/device,SHARED_PRECOMPS_DIR=.../farmacia_viriato/platforms/ios/build/sharedpch
PaulF_IntelCorp
@Nuno -- usually that error means there's a plugin in your project that requires the use of Xcode 7, our iOS build system currently uses Xcode 6. We are in the process of upgrading that, but no estimate regarding availability. However, the list of plugins shown in your first post appear to be only core Cordova plugins. Can you confirm what plugins you were using in your project when you got the second message?
Nuno_A_
I've solved the problem. The certificate Apple was wrong.
Daniele_A_
Hi nuno i have the same problem how you fix this ?
Nuno_A_
In my case has the IOS certificate replaced by correct
