Software Archive
Read-only legacy content
IOS Ipad splash screen not displaying
yeoyong_l_
Im using latest version of intel xdk which is incorporated with cordova 5.1.1. I built an application by adding all splashscreen for ios in build settings and also i added cordova splashscreen plugin but i'm still getting cordova as my application splash screen. Please let me know the solution or fix for this.
Amrita_C_Intel
yeoyong_l_
hi,
is no working after cleaning the cache. If i change splash screen to old design of splash screen, it will be working fine but if change to new design it will not display.
PaulF_IntelCorp
@yeoyoung -- are you adding the splash screen using the Projects tab?
Amrita_C_Intel
Where are you testing on? Device or emulator?
Amrita_C_Intel
Go through the process of downloading the .ipa and inspecting it to see what configuration Cordova created.
What's happening is that if you don't specify a resolution, Cordova is filling in its own default image. Therefore, for your app to show a splashscreen reliably, you must provide one for all 11 resolutions.
What might be happening is that you had "Display zoom" set on your iPhone 6. This meant that the screen resolution being used was the "Rendered pixels" size of 640x1136, not the "Physical pixels" size of 750x1334.
And
See the hello-cordova sample and the intelxdk.config.additions.xml file. In particular, the
    <preference name="AutoHideSplashScreen" value="false" />
line... Don't recall if this needs to be true or false, but I think that's the key so you need to try this out with both the values.
For further reference checkout this article : https://software.intel.com/en-us/xdk/docs/using-the-cordova-for-android-ios-etc-build-option
Including Custom Splash Screens
yeoyong_l_
hi Paul im adding splash screen using projects tab. but the splash screen is not displaying on the ipad device
yeoyong_l_
And
For further reference checkout this article : https://software.intel.com/en-us/xdk/docs/using-the-cordova-for-android-...
hi Amrita,
I'm include my splash screen in the project tab, which following the resolution require.
And i'm not using emulator, but device (ipad).
PaulF_IntelCorp
Yeoyong -- the splash screen config image you show is for Android devices. You have to click the "iOS" tab to configure the splash screens for your iPad and other Apple devices. See the image below:
yeoyong_l_
hi
sorry for uploading the wrong screenshot, i have upload a new screenshot
thanks
Amrita_C_Intel
Try to close the running XDK and restart it, change the app id , and build it again and check on device.
yeoyong_l_
Hi Amrita,
i have close and restart the XDK but it still same, only the mobile splash screen is working fine. For table it''s no showing at all.
