Software Archive
Read-only legacy content
17060 Discussions
IOS build fails without warning or log
Arjan_K_
Dear reader, I try to build an IOS adhoc application and i get the message that "the build has failed"
without link to logs or message to show what is wrong.
IOS build has never worked, Android did work though.
Can someone tell me what is wrong ?
screenshot of build message without log
John_H_Intel2
Are you including any 3rd party plugins?
What build of the XDK are you using?
Arjan_K_
I do not use a plugin.
Did find the problem, after using a demo project, because to be sure it wasn't a code error in my app.
i got the same error, so I checked again what I had changed in the demo. and found that you can only use dots and alphabetic & number characters in the bundle ID. So i recreated the bundlename and the certificates and it worked with the demo project, so I inserted the new certs into my app project and it worked. So next time I'm careful with what I enter and use in my name and bundle Id.
John_H_Intel2
When you create you bundleID, you must also create it on Apples Developer site, which also only allows certain chars.
