Software Archive
Read-only legacy content
17061 Discussions
IPoIB in Xeon Phi
Alfonso_P_
I am configurating Lustre in Xeon Phi. But only works with mic0 (mic0-br0-eth0) interface. It's possible to configure intel xeon phi scif0 interface with IPoIB and connect lustre inside Xeon Phi by Infiniband (o2ib).
Thanks in advance!
Wendy__C_
No. Xeon Phi's IPOIB is built on top of "MIC Kernel CCL Direct" drivers. It'll not work on scif interface directly. Any reason you want to run on scif0 ?
-- Wendy
Wendy__C_
I think I misunderstood you .. what you want is to run Lustre on top of Infiniband ? The set of kernel drivers are offered in MPSS 3.x as an experimental feature. You would need
  • Install MPSS 3.x
  • Get the corresponding luster rpms that support Xeon Phi
  • Configure OFED-3.5.1-mic (see the Admin Guide)
  • Configure ib0 interface (see the Admin Guide)
Then the rest should be identical to the usual Lustre setup. Again, it should be on ib0, not scif0.
-- Wendy
Frances_R_Intel
You might want to check out https://software.intel.com/en-us/forums/topic/475315#comment-1785430 .I believe that comment from Belinda has the magic you need.
