Software Archive
Read-only legacy content
Ankündigungen
17060 Diskussionen
IPoIB in Xeon Phi
Alfonso_P_
Einsteiger
815Aufrufe
I am configurating Lustre in Xeon Phi. But only works with mic0 (mic0-br0-eth0) interface. It's possible to configure intel xeon phi scif0 interface with IPoIB and connect lustre inside Xeon Phi by Infiniband (o2ib).
Thanks in advance!
3 Antworten
Wendy__C_
Einsteiger
815Aufrufe
No. Xeon Phi's IPOIB is built on top of "MIC Kernel CCL Direct" drivers. It'll not work on scif interface directly. Any reason you want to run on scif0 ?
-- Wendy
Wendy__C_
Einsteiger
815Aufrufe
I think I misunderstood you .. what you want is to run Lustre on top of Infiniband ? The set of kernel drivers are offered in MPSS 3.x as an experimental feature. You would need
  • Install MPSS 3.x
  • Get the corresponding luster rpms that support Xeon Phi
  • Configure OFED-3.5.1-mic (see the Admin Guide)
  • Configure ib0 interface (see the Admin Guide)
Then the rest should be identical to the usual Lustre setup. Again, it should be on ib0, not scif0.
-- Wendy
Frances_R_Intel
Mitarbeiter
815Aufrufe
You might want to check out https://software.intel.com/en-us/forums/topic/475315#comment-1785430 .I believe that comment from Belinda has the magic you need.
Antworten
