Software Archive
Read-only legacy content
17060 Discussions
Implementing a 'remember me' login in hybrid app
xkevin
I am developing an app that uses ajax request to the server to login. I want to add a feature to the login- the 'remember me'. In which whenever the user launch the app he/she doesn't need to login anymore, but when logout was pressed/triggered, the login credentials will erase/expired - so, he needs to log in again. What is the right approach on this and how to do it on hybrid app? Is there any plugin that good for ios, andriod and windows that can save the login credentials for remember me feature? Any idea?
Mycode so far is just the manual login
if($.trim(email).length>0 && $.trim(password).length>0) {
                $.ajax({
                        type: "POST",
                        url: "http://www.example.com/app/login.php",
                        crossDomain: true,
                        dataType: 'json',
                        data: $.trim(frm.serialize()),
                        beforeSend: function(){
                            $('#loader').css({ display: "block" });
                        success: function(data,status,XHR) {
                            handleData(data);//handle the servers respond
                        error: function(httpReq,status,exception){
                            alert("Network error: "+status+" "+exception);
                            $('#loader').css({ display: "none" });
Handle data code
function handleData( responseData ) {
            var access = responseData;
            if(access == "good"){//server respond good username/pass
                alert("Welcome");
            else{
                alert("Your username and password didn\'t match.");
                $('#input_password').val('');
            console.log(responseData);
Fab_V_
hi,
this is what i do in my apps. i will try to explain to you shortly..
the principle is to store login datas in local storage. here is a short explanation.
when user datas are stored you automatically connect the user.
in my case (and this is not written here) in the quick login method i do a background login verification..
  • when framework is loaded (in my case a modified version of appframework 3) i load my js classes dynamically and init them.
  • use a login method to connect user manually
    	/***************** LOGIN **********************/
    	login : function(login,md5_pass)
    		var self = this;
    		var success = function(data,textStatus,jqXHR){
    			self.parseLogin(data);
    		var error = function(jqXHR,textStatus,errorThrown){
    		 	self.parseLogin({});
    		return myapp.json(myapp.Conf.get('json_url')+'?task=login',{'login':email,'md5_pass':md5_pass}, success,o,error);
  • use a quickLogin method to connect user in background mode, on init..
    	/***************** QUICKLOGIN *************************/
    	quickLogin : function(){
    		this.isLogged=true;
    		var data = {
    			user : myapp.Storage.get('User'), /* class to manage storage*/
    			settings : myapp.Storage.get('Settings'),
    		this.parseLogin(data);
                   here you have to do a background login verification to be sure user already exists
                   for example
  • in both cases, whan ajax complete you need to parse login results in a 3rd method named parseLogin.
    this method will store your needed user datas in local storage and if needed init others thing on your app
      parseLogin : function(data,checkProfile,transparent){
        var self = this;
        else if(typeof(data.user)=='object' && data.user.ID && data.user.sessionid)
          self.set(data.user);
          self.isLogged=true;
          self.defaultCredentials();
          $(document).trigger('user.parseLogin',data);
        else
        	self.isLogged=false;
            self.logout();
  • defaultCredentials is a method to add user identified datas to ajax requests.
    it must be called on login and logout.
    	/******************** DEFAULT CREDENTIALS FOR AJAX REQUESTS ********************/
    	defaultCredentials : function(){
    	     var Data = {'platform':myapp.Conf.platform,'sessionid' : myapp.User.get('sessionid'),'userid' : myapp.User.get('ID')};
    	     $.ajaxSetup({crossDomain : true,data:Data});
i hope this will be clear enough to help you.
Fab_V_
hi,
    		var self = this;
    		this.isLogged=true;
    		var data = {
                   for example
        var self = this;
          self.isLogged=true;
        else
            self.logout();
