I believe I've seen other posts with this problem, but this is aggravating as it makes the Debugger somewhat useless while tracing through a program. While in Debug mode and stepping through execution lines, all local variables, whether I specify them in the Watch window, or mouse over them in the code, the debugger doesn't display the proper values. I believe internally, variables are being correctly computed as the program wouldn't work otherwise, but the variables [when viewing at a breakpoint] are extremely large or extremely small, as if uninitialized.
My compiler options:
/nologo /debug:full /Od /Qdiag-enable:sc-include /debug-parameters:all /warn:declarations /warn:unused /warn:ignore_loc /warn:uncalled /warn:nousage /warn:interfaces /Qcomplex_limited_range /Qfp-stack-check /module:"Debug\\" /object:"Debug\\" /Fd"Debug\vc100.pdb" /traceback /check:pointer /check:bounds /check:uninit /check:format /check:output_conversion /check:arg_temp_created /check:stack /libs:qwin /dbglibs /c
Is this a known bug?
Amalia
- « Previous
- 1
- 2
- Next »
This nasty problem strikes again with parallel_studio_xe_2013_update2.
It has disappeared with update1...
Two phenomenom:
> debugger reporting weird values
> and program bugging!
Config:
Visual Studio 2012 + Parallel studio 2013 update 2
Target: Intel C++ Compiler XE 12.1 (v100)
The programs works ok if compiled in debug mode, itr works ok too if compiled in Release using Microsoft Visual Studio.
HELP REQUESTED!
>Thanks
Gianni,
Thank you for the heads-up. Please open a Premier issue with more specific information (alternatively, you can reply with a private message, and attach your code). A reproducer would be very helpful for us, and I would be glad to take your case.
Thank you!
Many thanks Georg,
Indeed the Ivdep pragma was definitively wrong!
cheers
gianni
- « Previous
- 1
- 2
- Next »
