Software Archive
Read-only legacy content
17060 Discussions
Incomplete task type
lee_j_2
I am getting the error of incomplete task type. Am i doing something wrong and why?
PXCSenseManager *psm = 0;
psm = PXCSenseManager::CreateInstance();
//Projection
        PXCCaptureManager *cm = psm->QueryCaptureManager();
        PXCCapture::Device *device = cm->QueryDevice();
        // color and depth image size.
        PXCImage::ImageInfo dinfo = depth_image->QueryInfo();
        PXCImage::ImageInfo cinfo = color_image->QueryInfo();
        // Calculate the UV map.
        PXCPointF32 *uvmap = new PXCPointF32[dinfo.width*dinfo.height];
        //projection->QueryUVMap(depth_image, uvmap);
        PXCProjection *projection = device->CreateProjection();
        projection->QueryUVMap(depth, uvmap);                                <<<-------------error happens here
Below is what the document suggests doing.
Example 40 shows how to map depth to color coordinates using the UV map.
Example 40: Map Depth to Color Coordinates using UV Mapping
// Create the PXCProjection instance.
PXCProjection *projection=device->CreateProjection();
PXCImage::ImageInfo dinfo=depth->QueryInfo();
PXCImage::ImageInfo cinfo=color->QueryInfo();
PXCPointF32 *uvmap=new PXCPointF32[dinfo.width*dinfo.height];
// Translate depth points uv[] to color ij[]
for (int i=0;i<npoints;i++) {
  ij[i].x=uvmap[(int)uv[i].y*dinfo.width+(int)uv[i].x].x*cinfo.width;
  ij[i].y=uvmap[(int)uv[i].y*dinfo.width+(int)uv[i].x].y*cinfo.height;
// Clean up
delete[] uvmap;
projection->Release();
