Software Archive
Read-only legacy content
Inconsistency in the SDK (imageposition)
AndreCarlucci
I just would like to report  a small inconsistency in the SDK (is there a better place to report these things?
When getting a Joint positionImage, it is returned a PXCMPoint3DF32. (JointData)
When getting a hand positionImage, it is returned a PXCMPointF32 (QueryMassCenterImage)
I believe both should be PXCMPointF32 since Z is not present in image coordinates, right?
André
Pubudu-Silva_Intel
Andre,
Are you suggesting that both should not be  PXCMPointF32 ?
quote=Andre Carlucci]
André
AndreCarlucci
Yes, they represent the same concept (position in the generated image) and they have no Z in this case.
Dagan_E_Intel
Thanks Andre,
Good catch!
The 3D dimension holds the depth at the X,Y location, which was thought to be helpful, but indeed both image positions should better have the same type for consistency and clearer usage
cheers,
Dagan
