Software Archive
Read-only legacy content
IndexedDB just not work on iPhone.
Rodrigo_M_1
New Contributor II
Hi there,
I'm trying to use a local Database on iPhone 6 plus, but it seems that's not working...
On Android devices works fine!
Here is the link of a sample I'm using for tests: http://qnimate.com/local-database-storage-using-intel-xdk/
And here is the compatibility link, but It's not the IndexedDBpolyfill: http://caniuse.com/#feat=indexeddb
Should I use the SQLite instead of IndexedDB for iPhone ?
Thanks!
Amrita_C_Intel
In Qnimate example that API has been deprecated. Use the equivalent Cordova plugin instead or any other equivalent third party Cordova plugin.
Amrita_C_Intel
Rodrigo_M_1
New Contributor II
Hi Amrita C., thanks for your answer!
Just one more question: What's the difference between the SQLite Cordova Plugin and the Web SQL Storage from https://software.intel.com/en-us/articles/html5-local-storage
Thanks Again!
Rodrigo.
Amrita_C_Intel
  • HTML5 web storage = generic umbrella term for the new client-side data storage options:
  • Local Storage = persistant and scoped to the domain. At the moment two flavors are usually mentioned:
  • Web SQL (aka Web Database) = uses a SQL database
  • 'default' = stores things in name/value pairs
  • Session Storage = non persistent and scoped only to the current window
  • Cookies = the old school way of doing all of the above. Stores name/value pairs per domain.
