Software Archive
Read-only legacy content
17060 Discussions
Initialization of data
lucaletizia
Hy Guys,
I am trying to inizialise the local varables when I declare them (and the same for the data in a UserDefined Type). But what I am finding is that when I call the subrioutine the first time averything works fine, if I call the same subroutine once more the values of the local variables are not the initialization value but the values which were given to the variables the previous time I have called the subroutine. Is it a Bug of the compiler (i have tryed on 6.6 and 6.5 and the behaivour is the same)?
Here is a brief example
Program Main
Implicit None
Type Report
    Character (Len = 20) Report_Name
    Integer Day
    Character (Len = 3) Month
    Integer :: Year = 1995
End Type Report
    Type (Report) Report1
    Integer i, nInt
    Real lReal
    Do i = 1, 2
        Call setData(Report1, nInt, lReal)
        Call printData(Report1, nInt, lreal)
    End Do
Contains
Subroutine setData(YourReport, YourInt, YourReal)
    Integer YourInt
    Real YourReal
    Type (Report) :: MyReport = Report("Sales", 15, "Nov", 1996), YourReport
    Integer :: MyLocalInt = 0
    Real :: MyReal = 1.01
    MyReport%Year = MyReport%Year + 1
    MyLocalInt = MyLocalInt + 1
    MyReal = MyReal * MyReal
    YourReport = MyReport
    YourInt = MyLocalInt
    YourReal = MyReal
End Subroutine setData
Subroutine printData(YourReport, YourInt, YourReal)
    Type (Report) YourReport
    Integer YourInt
    Real Yourreal
    Print*, "Report Name: ", YourReport%Report_Name
    Print*, "Day: ", YourReport%Day
    Print*, "Month: ", YourReport%Month
    Print*, "Year: ", YourReport%Year
    Print*, "Integer: ", YourInt
    Print*, "Real: ", YourReal
    Print*, " "
End Subroutine
End Program
No, this is not a compiler bug - it is the behavior specified by the Fortran standard. Variables that are DATA initialized or are initialized in their type specification statements (you did the latter) are given an implicit SAVE attribute and retain their values across calls. (F95 14.7.3)
There is an interesting subcase, though, that CVF used to get wrong (we fixed it in 6.5A, I think). If you have a derived type declaration in which you specify component initialization, local, non-ALLOCATABLE or POINTER variables of that type get the initialization reapplied on each entry to the routine (unless the variable also has SAVE explicitly specified.)
Steve
Jugoslav_Dujic
Valued Contributor II
No, that's as it should be. Data initialization gives the initial value at the time when the variable is created. Since variables are saved (static) by default, they are created and thus initialized only once (when they're first time encountered), as you notice.
So, you should use assignment statements instead. Have in mind that
INTEGER:: i = 0
is different from
INTEGER:: i
i=0
The latter assigns zero every time it's encountered; the former assigns zero only the first time the containing routine is executed. Note that in common speech both ways are usually referred as initialization, but when talking about uninitialized variable one means that neither kind of initialization was performed.
Jugoslav
