Software Archive
Read-only legacy content
17060 Diskussionen
Installation goes well, activation seems to fail Fortan on Linux
Dave_A__from_Lifeboa
1.026Aufrufe
My customer writes the following on a failure after what appears to be a successful installation:
I have downloaded and installed the latest update of the Linux compiler: Fortran Composer XE 2011 for
Linux* Update 9, Version 2011.9.293
And it seems to install OK. The license is fine too.
However, the compiler setup script does not identify the compiler correctly and as such the thing is useless.
I get:
smithp01-ISI-110> source ~/intel/composer_xe_2011_sp1.9.293/bin/compilervars.csh intel64
smithp01-ISI-111> source .login
Defining the Linux paths
smithp01-ISI-112> which ifort
ifort: Command not found.
If I initialize the older version it works...
smithp01-ISI-113> source ~/intel/composer_xe_2011_sp1.8.273/bin/compilervars.csh intel64
smithp01-ISI-114> source .login
smithp01-ISI-115> which ifort /ifs/home/smithp01/intel/composer_xe_2011_sp1.8.273/bin/intel64/ifort
smithp01-ISI-116>
I have downloaded and installed the latest update of the Linux compiler: Fortran Composer XE 2011 forLinux* Update 9, Version 2011.9.293And it seems to install OK. The license is fine too.However, the compiler setup script does not identify the compiler correctly and as such the thing is useless.I get:smithp01-ISI-110> source ~/intel/composer_xe_2011_sp1.9.293/bin/compilervars.csh intel64smithp01-ISI-111> source .loginDefining the Linux pathssmithp01-ISI-112> which ifortifort: Command not found.If I initialize the older version it works...smithp01-ISI-113> source ~/intel/composer_xe_2011_sp1.8.273/bin/compilervars.csh intel64smithp01-ISI-114> source .loginDefining the Linux pathssmithp01-ISI-115> which ifort /ifs/home/smithp01/intel/composer_xe_2011_sp1.8.273/bin/intel64/ifortsmithp01-ISI-116>
I believe they are running GNU
any help would be appreciated.
Thanks....Dave A. from Lifeboat.
6 Antworten
Nikolay_L_Intel
Mitarbeiter
1.026Aufrufe
It seems the environment variables were not set correctly.
Could you double check if Fortran componentis installed? If it is not installed, please reinstall it.
To check:
Option 1. Pease go to ~/intel/composer_xe_2011_sp1.9.293/bin/intel64 and try to find ifort binary.
Option 2. Please call ~/intel/composer_xe_2011_sp1.9.293/bin/uninstall.sh and check the components to uninstall, is Fortran component there or not.
In other case please invoke environment script in "echo" mode to look how the environment setup works:
# /bin/csh -x ~/intel/composer_xe_2011_sp1.9.293/bin/compilervars.csh intel64
Please copy this command output to theforum if problem will not be solved.
I will monitor this topic and willfind another workaround.
Thank you,
- Nikolay
1.026Aufrufe
Thank you Nikolay, I'll relay to customer and advise if something else is needed.
Thanks...Dave A. from Lifeboat Distribution.
1.026Aufrufe
Nikolay,
Customer tried what you said here are the results:
smithp01-ISI-126> ls ~/intel/composer_xe_2011_sp1.9.293/bin/intel64/
codecov idb.el ifort inspxe-wrap profdcg xild
fortcom idbc ifort.cfg libiml_attr.so profmerge
fpp idbserver iidb loopprofileviewer.csh proforder
ia32.xrd idbvars.csh inspxe-inject loopprofileviewer.sh tselect
idb idbvars.sh inspxe-runsc map_opts xiar
As you can see, fort is there.
Welcome to uninstallation program for Intel Composer XE 2011 Update 9 for Linux*.
Please select the following component(s) to uninstall. After you complete your selection, press enter to proceed uninstallation for the selected component(s)
0. Select/unselect all component(s) [ ] 1. Intel Fortran Compiler XE 12.1 Update 3 on IA-32
AND Intel Fortran Compiler XE 12.1 Update 3 Intel 64 [ ] 2. Intel Debugger 12.1 Update 3 on IA-32
AND Intel Debugger 12.1 Update 3 on Intel 64 [ ] 3. Intel Math Kernel Library 10.3 Update 9 on IA-32
AND Intel Math Kernel Library 10.3 Update 9 on Intel 64
Please enter your selection : ^C
> intel64
DUMP FILE CONTENTS
smithp01-ISI-101> /bin/csh -x ~/intel/composer_xe_2011_sp1.9.293/bin/compilervars.csh intel64
set PROD_DIR=/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293
if ( intel64 != ia32 && intel64 != intel64 ) then
if ( -e /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/pkg_bin/idbvars.csh ) then
source /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/pkg_bin/idbvars.csh intel64
if ( intel64 == ia32 ) then
if ( intel64 == intel64 ) then
source /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/bin/intel64/idbvars.csh
if ! ( 0 ) then
setenv NLSPATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/debugger/intel64/locale/%l_%t/%N
else
else
endif
if ( -e /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/tbb/bin/tbbvars.csh ) then
if ( -e /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/bin/mklvars.csh ) then
source /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/bin/mklvars.csh intel64
set CPRO_PATH=/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293
setenv MKLROOT /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl
set SCRIPT_NAME=/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/bin/compilervars.csh
set MOD_NAME=mod
set MKL_TARGET_ARCH=
set MKL_LP64_ILP64=
set MKL_MOD=
set MKL_VERBOSE=
if ( intel64 == ) then
while ( intel64 != )
set MKL_TARGET_ARCH=intel64
else if ( intel64 == mic ) then
shift
end
while ( != )
if ( 0 ) then
setenv LD_LIBRARY_PATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/compiler/lib/intel64:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/lib/intel64
endif
if ( 0 ) then
setenv LIBRARY_PATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/compiler/lib/intel64:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/lib/intel64
endif
if ( 1 ) then
setenv NLSPATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/lib/intel64/locale/%l_%t/%N:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/debugger/intel64/locale/%l_%t/%N
else
if ( 0 ) then
setenv MANPATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/man/en_US:`manpath`
manpath
endif
if ( 0 ) then
setenv INCLUDE /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/include
endif
if ( 0 ) then
setenv CPATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/include
endif
if ( == mod ) then
if ( 0 ) then
setenv FPATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/include
endif
if ( == verbose ) then
goto End
endif
if ( -e /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/ipp/bin/ippvars.csh ) then
if ( -e /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/pkg_bin/compilervars_arch.csh ) then
source /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/pkg_bin/compilervars_arch.csh intel64
set INSTALL_DIR=/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293
if ! ( 1 ) then
setenv PATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/bin/intel64:/home-isilon/smithp01/bin/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/games:/usr/local/sbin:/usr/local/bin:/usr/X11R6/bin:/home-isilon/smithp01/bin
setenv PATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/bin/intel64:/home-isilon/smithp01/bin/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/games:/usr/local/sbin:/usr/local/bin:/usr/X11R6/bin:/home-isilon/smithp01/bin:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mpirt/bin/intel64
if ( 0 ) then
endif
if ( `uname` == Darwin ) then
uname
if ! ( 1 ) then
setenv LD_LIBRARY_PATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/compiler/lib/intel64:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/compiler/lib/intel64:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/lib/intel64
setenv LD_LIBRARY_PATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/compiler/lib/intel64:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/compiler/lib/intel64:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/lib/intel64:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mpirt/lib/intel64
if ( 0 ) then
endif
if ! ( 1 ) then
setenv LIBRARY_PATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/compiler/lib/intel64:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/compiler/lib/intel64:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/lib/intel64
endif
if ! ( 1 ) then
setenv NLSPATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/compiler/lib/intel64/locale/%l_%t/%N:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/lib/intel64/locale/%l_%t/%N:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/debugger/intel64/locale/%l_%t/%N
endif
if ! ( 0 ) then
setenv INTEL_LICENSE_FILE /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/licenses:/opt/intel/licenses:/home-isilon/smithp01/intel/licenses
else
if ( 0 ) then
if ( 1 ) then
if ( en_US.UTF-8 != ) then
set LANGUAGE_TERRITORY=`echo $LANG | sed s/\\..\*//`
echo en_US.UTF-8
sed s/\..*//
endif
endif
if ( en_US != en_US ) then
if ! ( 1 ) then
setenv MANPATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/man/en_US:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/man/en_US:/home-isilon/smithp01/bin/man:/usr/share/man/en:/usr/share/man:/usr/local/share/man:/usr/local/man:
endif
endif
endif
smithp01-ISI-102>
smithp01-ISI-101> /bin/csh -x ~/intel/composer_xe_2011_sp1.9.293/bin/compilervars.csh intel64set PROD_DIR=/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293if ( intel64 != ia32 && intel64 != intel64 ) thenif ( -e /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/pkg_bin/idbvars.csh ) thensource /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/pkg_bin/idbvars.csh intel64if ( intel64 == ia32 ) thenif ( intel64 == intel64 ) thensource /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/bin/intel64/idbvars.cshif ! ( 0 ) thensetenv NLSPATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/debugger/intel64/locale/%l_%t/%Nelseelseendifif ( -e /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/tbb/bin/tbbvars.csh ) thenif ( -e /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/bin/mklvars.csh ) thensource /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/bin/mklvars.csh intel64set CPRO_PATH=/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293setenv MKLROOT /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mklset SCRIPT_NAME=/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/bin/compilervars.cshset MOD_NAME=modset MKL_TARGET_ARCH=set MKL_LP64_ILP64=set MKL_MOD=set MKL_VERBOSE=if ( intel64 == ) thenwhile ( intel64 != )if ( intel64 == ia32 ) thenif ( intel64 == intel64 ) thenset MKL_TARGET_ARCH=intel64else if ( intel64 == mic ) thenshiftendwhile ( != )if ( intel64 == ) thenif ( 0 ) thensetenv LD_LIBRARY_PATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/compiler/lib/intel64:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/lib/intel64endifif ( 0 ) thensetenv LIBRARY_PATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/compiler/lib/intel64:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/lib/intel64endifif ( 1 ) thensetenv NLSPATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/lib/intel64/locale/%l_%t/%N:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/debugger/intel64/locale/%l_%t/%Nelseif ( 0 ) thensetenv MANPATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/man/en_US:`manpath`manpathendifif ( 0 ) thensetenv INCLUDE /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/includeendifif ( 0 ) thensetenv CPATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/includeendifif ( == mod ) thenif ( 0 ) thensetenv FPATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/includeendifif ( == verbose ) thengoto Endendifif ( -e /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/ipp/bin/ippvars.csh ) thenif ( -e /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/pkg_bin/compilervars_arch.csh ) thensource /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/pkg_bin/compilervars_arch.csh intel64set INSTALL_DIR=/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293if ! ( 1 ) thensetenv PATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/bin/intel64:/home-isilon/smithp01/bin/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/games:/usr/local/sbin:/usr/local/bin:/usr/X11R6/bin:/home-isilon/smithp01/binsetenv PATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/bin/intel64:/home-isilon/smithp01/bin/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/games:/usr/local/sbin:/usr/local/bin:/usr/X11R6/bin:/home-isilon/smithp01/bin:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mpirt/bin/intel64if ( 0 ) thenendifif ( `uname` == Darwin ) thenunameif ! ( 1 ) thensetenv LD_LIBRARY_PATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/compiler/lib/intel64:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/compiler/lib/intel64:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/lib/intel64setenv LD_LIBRARY_PATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/compiler/lib/intel64:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/compiler/lib/intel64:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/lib/intel64:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mpirt/lib/intel64if ( 0 ) thenendifif ! ( 1 ) thensetenv LIBRARY_PATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/compiler/lib/intel64:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/compiler/lib/intel64:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/lib/intel64endifif ! ( 1 ) thensetenv NLSPATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/compiler/lib/intel64/locale/%l_%t/%N:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/lib/intel64/locale/%l_%t/%N:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/debugger/intel64/locale/%l_%t/%Nendifif ! ( 0 ) thensetenv INTEL_LICENSE_FILE /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/licenses:/opt/intel/licenses:/home-isilon/smithp01/intel/licenseselseif ( 0 ) thenif ( 1 ) thenif ( en_US.UTF-8 != ) thenset LANGUAGE_TERRITORY=`echo $LANG | sed s/\\..\*//`echo en_US.UTF-8sed s/\..*//endifendifif ( en_US != en_US ) thenif ! ( 1 ) thensetenv MANPATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/man/en_US:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/man/en_US:/home-isilon/smithp01/bin/man:/usr/share/man/en:/usr/share/man:/usr/local/share/man:/usr/local/man:endifendifendifsmithp01-ISI-102>
Nikolay_L_Intel
Mitarbeiter
1.026Aufrufe
It is strange. Based on log file - should work fine.
Could you try to setup main variables manually? (reused values from thelog above)
setenv LD_LIBRARY_PATH /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/compiler/lib/intel64:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mkl/lib/intel64:/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mpirt/lib/intel64
- Nikolay
1.026Aufrufe
Hi Nikolay,
That worked ! But....something else is now going on...customer writes:
Yes, this works!
hpcf-106> ifort -V
Intel Fortran Intel 64 Compiler XE for applications running on Intel 64, Version 12.1.3.293 Build 20120212 Copyright (C) 1985-2012 Intel Corporation. All rights reserved.
But there is something weird going on. If I "source" the initialization file "ifort" vanishes, so somewhere in there (?) the PATH information gets flushed.
I'm still looking at it and will send more info later I hope.
MORE Here:
mcrc13-4> ssh -2 -Y -X hpcf
Last login: Tue Mar 6 11:34:07 2012 from 10.193.36.208 Defining the Linux paths
hpcf-101> which ifort
hpcf-102> ~/intel/composer_xe_2011_sp1.9.293/bin/compilervars.csh
hpcf-102> intel64
hpcf-103> which ifort
hpcf-104> echo $path
/opt/openmpi/bin/ /opt/gridengine/bin/lx26-amd64/ /home-isilon/smithp01/bin/bin /sbin /bin /usr/sbin /usr/bin /usr/games /usr/local/sbin /usr/local/bin /usr/X11R6/bin /home-isilon/smithp01/bin
hpcf-105> echo $PATH
/opt/openmpi/bin/:/opt/gridengine/bin/lx26-amd64/:/opt/openmpi/bin/:/opt/gridengine/bin/lx26-amd64/:/home-isilon/smithp01/bin/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/games:/usr/local/sbin:/usr/local/bin:/usr/X11R6/bin:/home-isilon/smithp01/bin
hpcf-106> setenv PATH
hpcf-106> /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/bin/int
hpcf-106> el64:/home-isilon/smithp01/bin/bin:/sbin:/bin:/usr/sbin:/usr/b
hpcf-106> in:/usr/games:/usr/local/sbin:/usr/local/bin:/usr/X11R6/bin:/h
hpcf-106> ome-isilon/smithp01/bin:/home-isilon/smithp01/intel/composer_x
hpcf-106> e_2011_sp1.9.293/mpirt/bin/intel64
hpcf-107>
hpcf-107> setenv LD_LIBRARY_PATH
hpcf-107> /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/compile
hpcf-107> r/lib/intel64:/home-isilon/smithp01/intel/composer_xe_2011_sp1
hpcf-107> .9.293/mkl/lib/intel64:/home-isilon/smithp01/intel/composer_xe
hpcf-107> _2011_sp1.9.293/mpirt/lib/intel64
hpcf-108>
hpcf-108> setenv LIBRARY_PATH
hpcf-108> /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/compile
hpcf-108> r/lib/intel64:/home-isilon/smithp01/intel/composer_xe_2011_sp1
hpcf-108> .9.293/mkl/lib/intel64
hpcf-109>
hpcf-109> echo $path /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/bin/intel64 /home-isilon/smithp01/bin/bin /sbin /bin /usr/sbin /usr/bin /usr/games /usr/local/sbin /usr/local/bin /usr/X11R6/bin /home-isilon/smithp01/bin /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mpirt/bin/intel64
hpcf-110> echo
hpcf-110> $PATH/opt/openmpi/bin/:/opt/gridengine/bin/lx26-amd64/:/opt/op
hpcf-110> enmpi/bin/:/opt/gridengine/bin/lx26-amd64/:/home-isilon/smithp
hpcf-110> 01/bin/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/games:/usr/local
hpcf-110> /sbin:/usr/local/bin:/usr/X11R6/bin:/home-isilon/smithp01/bin
hpcf-111> which ifort
/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/bin/intel64/ifort
hpcf-112> ~/intel/composer_xe_2011_sp1.9.293/bin/compilervars.csh
hpcf-112> intel64hpcf-113> which
hpcf-112> ifort/home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/bi
hpcf-112> n/intel64/iforthpcf-114> source
hpcf-112> intel64
hpcf-115> which fort
hpcf-116> echo $path
/opt/openmpi/bin/ /opt/gridengine/bin/lx26-amd64/ /opt/openmpi/bin/ /opt/gridengine/bin/lx26-amd64/ /home-isilon/smithp01/bin/bin /sbin /bin /usr/sbin /usr/bin /usr/games /usr/local/sbin /usr/local/bin /usr/X11R6/bin /home-isilon/smithp01/bin /home-isilon/smithp01/intel/composer_xe_2011_sp1.9.293/mpirt/bin/intel64
hpcf-117>
The bottom line is that if the path is correct the initialization script REMOVES the path to the compiler while leaving the path to the mpi wrappers.
If the path is absent it does not add it.
Nikolay_L_Intel
Mitarbeiter
1.026Aufrufe
Hello Dave,
Unfortunately, I have no idea why it happens. I can't reproduce the problem in my lab.
There is no difference between scripts in update 8 (customer said it works fine) and update 9 (corrupt paths). It looks it is a customer environment specific..
I would recommend trying to callthe sh-based scripts instead of csh:
# source ~/intel/composer_xe_2011_sp1.9.293/bin/compilervars.sh intel64
probably it can help because of changing the interpreter..
If it does not help, the only way to setup environment is the manual setup as customer used in the postabove (customer replied that it works).
Please keep me updated if any new information will be available.
Thank you,
- Nikolay
Antworten
