Software Archive
Read-only legacy content
17060 Discussions
Installation problem
Intel_C_Intel
When I tried to use the 6.6 patch, I get the following error message
cannot be installed on visual fortran 6.0
When I load Fortran, it shows 6.5. Also About shows 6.5. But then why do I get the above message.
Any idea?
Venkat
Because the CurrentVersion registry key says 6.0. I'm not sure why that should be - try reinstalling the 6.5 upgrade (which I assume you used to get to 6.5) and try again. If that doesn't work, follow the troubleshooting tips the upgrade displays.
Steve
