Software Archive
Read-only legacy content
17060 Discussions
Re: generic+intrinsic procedures
Intel_C_Intel
Tough question! You can't name MATMUL as a specific function in your INTERFACE block where you create the generic name "myMatmul" because it's not a specific name. Indeed, since MATMUL is a transformational intrinsic it has no set of specific names. Here is my attempt, which also doesn't work:
module matmul_mod
   implicit none
   interface matmul
      module procedure matmul_3
   end interface matmul
   public matmul
   private matmul_3
   contains
      function matmul_3(x,y)
         real, intent(in) :: x(:,:), y(:,:)
         real matmul_3(size(x,1),size(y,2))
         matmul_3 = 42
      end function matmul_3
end module matmul_mod
module myMatmul_mod
   use matmul_mod, only: myMatmul=>matmul
   implicit none
end module myMatmul_mod
program matmul_overload
   use myMatmul_mod
   implicit none
   integer :: a(3,3) = reshape((/1,2,3, &
                                 4,5,6, &
                                 7,8,9/), &
                       (/3,3/), order = (/2,1/))
   integer :: b(3,3) = reshape((/0,1,0, &
                                 0,0,1, &
                                 1,0,0/), &
   real c(3,3), d(3,3)
   c = a
   d = b
   write(*,'(3(i2:1x))') transpose(myMatmul(b,a))
   write(*,'(3(f4.1:1x))') transpose(myMatmul(d,c))
end program matmul_overload
Now, this all looks plausible becuase I first extend the MATMUL generic name to include my matmul_3 function and then, via a USE statement, rename MATMUL to MYMATMUL. But CVF 6.6 sees only MATMUL_3 as being renamed in this last operation and not the transformational intrinsic MATMUL as we desired, so it prints out a couple of error statements. Indeed, I would have thought that the original interface block should have been an error because the compler has no way of knowing whether to choose MATMUL_3 or the transformational intrinsic MATMUL when called upon to multiply two rank 2 real arrays. You can overload ELEMENTAL functions like this (the compiler selects the non-elemental function where available and the ELEMENTAL function otherwise) but I am not sure about the rules pertaining to transformational intrinsics. CVF 6.6 doesn't complain about this when F95 standard checking is enabled, however.
