Software Archive
Read-only legacy content
Installing Cuda library on Intel Edison
Luke_P_
Hi everyone,
  Does anyone know a way to install the Cuda library from Nvidia to use with OpenCV on the Intel Edison boards? I cannot find any documentation online.
Thank you!
NagaVenkat_K_Intel
Please post your question in the makers forum
samontab
Valued Contributor II
Hi Luke,
I don't think you can run CUDA on the Edison as it does not have an NVidia GPU. Maybe you could run OpenCL though, which is also supported in OpenCV...
Stewart_C_Intel
1:Currently only Ivy-Bridge and Haswell  are the only Intel chips that can run OpenCL on the GPU, according to http://boinc.berkeley.edu/wiki/GPU_computing.
2:And there is no Graphics Hardware at all,   VGA or otherwise on an Edison chip.
3:Its a headless system with no PCIe expansion, so there's no possibility of even adding a graphics card.
Three strikes...
