Software Archive
Read-only legacy content
17060 Discussions
Installing MPSS
Karan_S_
All,
I Recently obtained a xeon-phi and I have been trying to install it. I have centos 6.5. I followed the instruction and installed the mpss service using yum install MPSS. After installing, i do lsmod | grep mic and I can see the mic. Furthermore, I can see xeon phi in lspci -vv
Co-processor: Intel Corporation Xeon Phi coprocessor SE10/7120 series (rev 20)
        Subsystem: Intel Corporation Device 7d99
        Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Interrupt: pin A routed to IRQ 255
        Region 0: Memory at <unassigned> (64-bit, prefetchable) [disabled] [size=16G]
        Region 4: Memory at f2000000 (64-bit, non-prefetchable) [disabled] [size=128K]
        Capabilities: [44] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot-,D3cold-)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [4c] Express (v2) Endpoint, MSI 00
                DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <4us, L1 <64us
                        ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
                DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
                        RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop+
                        MaxPayload 256 bytes, MaxReadReq 512 bytes
                DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
                LnkCap: Port #0, Speed 5GT/s, Width x16, ASPM L0s L1, Latency L0 <4us, L1 unlimited
                        ClockPM- Surprise- LLActRep- BwNot-
                LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- Retrain- CommClk+
                        ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
                LnkSta: Speed 5GT/s, Width x8, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR-, OBFF Not Supported
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
                LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
                         Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
                         Compliance De-emphasis: -6dB
                LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
                         EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
        Capabilities: [88] MSI: Enable- Count=1/16 Maskable- 64bit+
                Address: 0000000000000000  Data: 0000
        Capabilities: [98] MSI-X: Enable- Count=16 Masked-
                Vector table: BAR=4 offset=00017000
                PBA: BAR=4 offset=00018000
        Capabilities: [100 v1] Advanced Error Reporting
                UESta:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UEMsk:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
                CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
                CEMsk:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
                AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
However I get the following
[root@apollo1 mpss-3.2.1]# lsmod | grep mic
mic                   591295  0
microcode             112685  0
[root@apollo1 mpss-3.2.1]# sudo modprobe mic
[root@apollo1 mpss-3.2.1]# sudo micctrl --initdefaults
[Warning] No Mic cards found or specified on command line
Can someone help me out. Am i doing something wrong ?
TaylorIoTKidd
Hi Karan,
You are using a non-supported OS. This just means that we don't validate against it. Plenty of people use Centos without issue.
Have you recompiled the kernel module for use with Centos?
Taylor
TimP
TimP
The pre-built MPSS for RHEL 6.5 should work on CentOS 6.5 x86_64 if the BIOS is compatible with the right settings.
TaylorIoTKidd
Tim,
You took the wind right out of my sails. If the BIOS doesn't support memory mapped I/O >4G, you need to update your BIOS.
You can find a lot more information about what type of BIOS upgrades you need by searching software.intel.com.
Taylor
