Software Archive
Read-only legacy content
17060 Discussions
Intel 82855, cannot display 1680x1050
s_mueller13
Hi erverybody!
I have a brandnew Acer AL2216w 22 inch widescreen display. My Notebook has a Intel 82855 graphic adapter, with VGA out. the monitor has a native resolution of 1680x1050 , but i cant choose this resolution. can anyone tel me how to set a custom resolution?
Aaron_B_Intel
s_mueller13
Thats what I already did. I can choose moren resolution, but not the one i want to. 1920x1200 (16:10, but too high res) and 1280x800 (16:10, low) are available, but 1680x1050 is missing:(
Aaron_B_Intel
Can you get the EDID information out of the display using MonInfo? I can see how to probably get you 1680x1050, but it's damned complicated. Not having the right EDID parameters would make it nightmarish.
zeq
Hi guys, I have the same problem :( I would like to buy new LCD but resolution 1680x1050 is missing in configuration, I hope you can help us. Thanks REALLY a lot !!!
Here are my EDID info.:
Raw EDID base
00: 00 FF FF FF FF FF FF 00 06 AF 01 0C 01 01 01 01
10: 01 0E 01 03 80 FF FF FF EA 00 00 A0 57 49 9B 26
20: 10 48 4F 21 08 00 01 01 01 01 01 01 01 01 01 01
30: 01 01 01 01 01 01 4C 1D 00 80 50 20 10 30 15 20
40: 44 00 05 A3 10 00 00 18 00 00 00 00 00 00 00 00
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03
(it's from MonInfo with a internal monitor /i don't know if there is any difference)
zeq
I tried to do that myself (http://softwarecommunity.intel.com/Wiki/Graphics/239.htm) but I don't have this "HKR,, TotalDTDCount, %REG_DWORD%, 0" in the .inf file. (I've got laptop DELL Inspiron 700m - it has 855GM chipset).
Aaron_B_Intel
Actually, we need the EDID from the monitor in question, not from the "internal monitor". That one's 1280x800, which I don't think is what we're looking for.
The 855 appears to have a different structure for which registry entries to modify, so the "TotalDTDs" won't work.
zeq
Ok, I'm sorry.Here it is:
Raw EDID base
zeq
Oh, it seems it is the same :-/ I will copy everything:
Monitor
Windows description......... SyncMaster 206BW(Analog)
Manufacturer................ AUO
Plug and Play ID............ AUO0C01
Serial number............... n/a
EDID data source............ Registry (stored)
Manufacture date............ 2004, ISO week 1
EDID revision............... 1.3
Display type and signal..... Digital
Sync input support.......... n/a
Screen size................. 2550 x 2550 mm (~155")
Power management............ Standby, Suspend, Active off/sleep
Color characteristics
Display gamma............... 3,55
Red chromaticity............ Rx 0,625 - Ry 0,340
Green chromaticity.......... Gx 0,285 - Gy 0,605
Blue chromaticity........... Bx 0,148 - By 0,063
White point (default)....... Wx 0,281 - Wy 0,309
Timing characteristics
VESA GTF support............ Not supported
Horizontal scan range....... n/a
Vertical scan range......... n/a
Video bandwidth............. n/a
Extension blocks............ n/a
Timing recommendation #1.... 1280x800 at 65Hz
Modeline................ "1280x800" 75,000 1280 1301 1333 1408 800 804 808 816 -hsync -vsync
Standard timings supported
640 x 480 at 60Hz - IBM VGA
800 x 600 at 60Hz - VESA
1024 x 768 at 60Hz - VESA
1280 x 800 at 65Hz - AUO
Raw EDID base
Display adapter
Adapter description......... Intel 82852/82855 GM/GME Graphics Controller
Adapter device ID........... 0x35828086
Display settings............ 1400x1050, 32bpp
zeq
I've got also "newest" drivers which Dell offer - DriverVer=07/19/2005,6.14.10.4363 - and I can't install the newer from Intel. (and the .inf file is ialmnt5.inf and it is the only .inf file there)
Aaron_B_Intel
Yeah, that appears to be the information for your laptop display. Not gonna help.
It's a Dell? :( They tend to have their own custom version of the drivers, and it's not as easy to modify them.
zeq
Oh no :( I've still hoped there is some chance :( But thank you anyway
zeq
Don't you know where I can ask some better informed people? I don't believe I'm the first one who want figure out this problem. Thanks
Aaron_B_Intel
The entechtaiwan link I posted above should work. The folks there have solved this problem for themselves.
