Software Archive
Read-only legacy content
17060 Discussions
Intel 82945G Express 1680x1050 LG w2252s issue - solved
qaredy353
I browsed the support and fund this. But it didn't work for me.
Accelerator in Use: Intel 82945G Express Chipset Family
Video BIOS: 1215
Driver Version: 6.14.10.4926
Operating System: Windows XP* Professional, Dodatek Service Pack 2 (5.1.2600)
Monitor: LG Flatron W2252S
Any help would be most appreiciated!
Many thanks in advance.
Aaron_B_Intel
Well, that's quite useless. I did find the EDID for your monitor out in the wild someplace, and it contains two different timings for 1680x1050:
21 39 90 30 62 1A 27 40 68 B0 36 00 DA 28 11 00 00 1C
and
7C 2E 90 A0 60 1A 1E 40 30 20 36 00 DA 28 11 00 00 1A
Using either one of these with the DTDCalc utility found in the "Custom Resolutions" sticky post in this Forum should allow you to enable 1680x1050. If you have trouble following the instructions or they don't seem to be working, come back here and I'll try to help further.
Aaron_B_Intel
Can you get a Diagnostic Report and post it? Click the Information button in the Intel Graphics Tray, and choose Save to File. Post the result.
qaredy353
There you go:
Report Date: 01/15/2009
Report Time[hr:mm:ss]: 07:23:46
Default Language: Polish
DirectX* Version: 9.0
Physical Memory: 1015 MB
Minimum Graphics Memory: 64 MB
Maximum Graphics Memory: 128 MB
Graphics Memory in Use: 9 MB
Processor: x86
Processor Speed: 3215 MHZ
Vendor ID: 8086
Device ID: 2772
Device Revision: 02
* Accelerator Information *
Video BIOS: 1215
Current Graphics Mode: 1400 x 1050 True Color (60 Hz)
qaredy353
... and MonInfo which shows my old monitor's data (why???) :
Monitor
Model name............... DELL D1626HT
Windows description...... Dell D1626HT
Manufacturer............. Dell
Plug and Play ID......... DEL515B
Serial number............ 55348B0NU259
Manufacture date......... 1999, ISO week 22
EDID revision............ 1.1
Input signal type........ Analog 0.700,0.300 (1.0V p-p)
Sync input support....... Separate, Composite, Sync-on-green
Display type............. RGB color
Screen size.............. 380 x 290 mm (18,8 in)
Power management......... Standby, Suspend, Active off/sleep
Extension blocs.......... None
DDC/CI................... n/a
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2,50
Red chromaticity......... Rx 0,625 - Ry 0,340
Green chromaticity....... Gx 0,280 - Gy 0,595
Blue chromaticity........ Bx 0,155 - By 0,070
White point (default).... Wx 0,283 - Wy 0,298
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 30-107kHz
Vertical scan range...... 50-160Hz
Video bandwidth.......... 2550MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... No
Detailed timing #1....... 720x350p at 70Hz (4:3)
Modeline............... "720x350" 28,320 720 738 846 900 350 356 358 449 +hsync -vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 75Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 75Hz - VESA
1024 x 768p at 60Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
640 x 480p at 85Hz - VESA STD
800 x 600p at 85Hz - VESA STD
1024 x 768p at 85Hz - VESA STD
1280 x 1024p at 85Hz - VESA STD
1600 x 1200p at 75Hz - VESA STD
1600 x 1200p at 85Hz - VESA STD
Report information
Date generated........... 2009-01-15
Software revision........ 2.20.0.779
Raw data................. 00,FF,FF,FF,FF,FF,FF,00,10,AC,5B,51,32,55,4E,30,16,09,01,01,0E,26,1D,96,E8,0D,C9,A0,57,47,98,27,
......................... 12,48,4C,A5,4B,00,31,59,45,59,61,59,81,99,A9,4F,A9,59,01,01,01,01,10,0B,D0,B4,20,5E,63,10,12,6C,
......................... 62,08,84,23,11,00,00,1A,00,00,00,FF,00,35,35,33,34,38,42,30,4E,55,32,35,39,0A,00,00,00,FC,00,44,
......................... 45,4C,4C,20,44,31,36,32,36,48,54,0A,00,00,00,FD,00,32,A0,1E,6B,FF,00,0A,20,20,20,20,20,20,00,1E
Aaron_B_Intel
Your new EDID is not being read. Try searching the registry for an entry called "BitBashingSupport". You should be able to modify it from the default of 00 to FF. There may be several copies; modify them all. Then try running the Diagnostics Report again.
qaredy353
Thank you Aaron for getting back. I modified "BitBashingSupport" value from 00 to FF
but the report seems to be the same:
Report Time[hr:mm:ss]: 20:21:57
Processor: x86
Processor Speed: 3216 MHZ
Vendor ID: 8086
Device ID: 2772
Device Revision: 02
Video BIOS: 1215
and the MonInfo 'detects' Dell monitor again :(
Aaron_B_Intel
and
qaredy353
Aaron MANY THANKS! I am enjoing 1680x1050 while writing this. Thank you again.
seakinfo
and
Wow - that's exactly what I am looking for but unfortunately I have a different monitor. I share the rest of the story with qaredy353: Despite installing the driver for the chipset I couldn't choose the native resolution for my "Belinea 2230 s1w".
Is there a chance that you know the EDID for this monitor too? I tried to look it up but up to now I was unlucky and couldn't find anything useful.
Any help to solve this problem is welcome,
thx
samuraisilhouette
and
I am also having a similar problem. Back in May of this year I reformatted my computer but my monitor was recognized prior to that incident and allowed me to display my monitor's native resolution. Now however, my monitor and computer don't seem to be communicating and the 1680 x 1050 resolution is no longer an option. I've reformatted my computer again to do my best to make sure that it wasn't a software issue that I might have developed, but it still doesn't give the correct display options. I don't see my display adapter model in this list so I might be out of luck.
I'd be ecstatic if you could find a solution for this!
Computer: HP Pavilion a1220n
Accelerator in Use: Intel 82915G/GV/910GL Express Chipset Family
Video BIOS: Unsure
Driver Version: 6.14.10.4332
Operating System: Windows XP Home Edition Version 2002 Service pack 3
Monitor: Element Flx-2210
UPDATE:
I've found and solved the problem. Between the time of purchasing my monitor and reformatting, I've replaced the VGA cable. It seems that the newer cable omitted a pin and I assume that it prevented EDID information from being passed on. I am a very happy camper!
hithwen
Im having same problem.
Under linux I can use that resolution but it does not appear under WinXP. I've alreade updated the drivers that say they solve the issue (http://www.intel.com/support/graphics/sb/cs-028886.htm ) but they dont.
Specs:
OS: WinXP SP3
Chipset Intel 945GC
Video Driver Version: 6.14.10.4926
Monitor: BenQ T201WA 20''
