Software Archive
Read-only legacy content
17060 Discussions
Intel 945G 800x600
kavadarci
Hi, I'm using Intel 945G and by default my resolution is 1024x768.
What I need is to modify the igxp32.inf to start with 800x600.
Where in the file can I make this change to stick to this resolution by default?
Thank you.
kavadarci
Quoting - kavadarci
Thank you.
Archibael, WHERE ARE YOU?
I need the default resolution on startup during install to be 800x600 on Intel 945G chipset.
Can this be done.
I've read the rest of the threads and all describe how to add more resolutions so one can select later but nothing about settingchanging the default resolution on startup.
Thank you very much.
