Software Archive
Read-only legacy content
17060 Discussions
Intel 945GM suddenly no longer doing video out
fafnr
Hey,
I have an old Dell laptop I'm using to see High-Def video on my flat-screen TV - basically as a TV centre, without a tuner. It's running a 945GM video card.
It's been working fine for a while, but it suddenly stopped working.
The TV is fine - it accepts input from another laptop using the same VGA cable, or an an xbox using another VGA cable, it's as if the out-connector suddenly broke for no reason!
I've tried updating the driver, reinstalling Windows 7, and live-booting ubuntu 8.04 - all with the same result. The tv is found by the software, but when I ask the computer to clone to the TV - it just doesn't.
I've more or less resigned myself to it being knackered - but I just can't reconcile that with the software always identifying the TV. (Ubuntu even recognized the TV model!)
I guess I'm just hoping someone here can say: "But, ahh! You should just..." and I won't have to spend 120$ on WD TV Live or something to replace my old "media centre"...
Thanks in advance!
The add files dialog here is kindda strange, so I'll just paste the saved report from the laptop here:
Intel Graphics Media Accelerator Driver for Mobile Report
Report Date: 01/07/2010
Report Time[hr:mm:ss]: 14:56:04
Driver Version: 8.15.10.1912
Operating System: Windows 7 Ultimate* , (6.1.7100)
Default Language: Danish
DirectX* Version: 11.0
Physical Memory: 1014 MB
Minimum Graphics Memory: 8 MB
Maximum Graphics Memory: 251 MB
Graphics Memory in Use: 96 MB
Processor: x86 family 6 Model 14 Stepping 8
Processor Speed: 1828 MHZ
Vendor ID: 8086
Device ID: 27A2
Device Revision: 03
* Accelerator Information *
Accelerator in Use: Mobile Intel 945 Express Chipset Family
Video BIOS: 1264
Current Graphics Mode: 1680 x 1050 True Color (60 Hz)
* Devices Connected to the Graphics Accelerator *
Active Monitors: 1
Active Notebook Displays: 1
* Monitor *
Monitor Name: Generic PnP Monitor
Display Type: Analog
Gamma Value: 2,20
DDC2 Protocol: Supported
Maximum Image Size: Horizontal: 34,6 inches
Vertical: 19,2 inches
Monitor Supported Modes:
640 x 480 (60 Hz)
800 x 600 (60 Hz)
1024 x 768 (60 Hz)
1280 x 720 (60 Hz)
1280 x 1024 (60 Hz)
1360 x 768 (60 Hz)
1920 x 1080 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Supported
Raw EDID:
00 ff ff ff ff ff ff 00 4d d9 01 c7 01 01 01 01
01 13 01 03 08 58 31 78 2a ee 9d a3 54 4c 99 26
0f 4f 54 21 08 00 81 c0 81 80 01 01 01 01 01 01
01 01 01 01 01 01 02 3a 80 18 71 38 2d 40 58 2c
45 00 70 ea 31 00 00 1e 66 21 50 b0 51 00 1b 30
40 70 36 00 70 ea 31 00 00 1e 00 00 00 fd 00 39
3f 1e 50 0f 00 0a 20 20 20 20 20 20 00 00 00 fc
00 53 4f 4e 59 20 54 56 0a 20 20 20 20 20 00 90
* Notebook *
Display Type: Digital
Gamma Value: 2,20
Maximum Image Size: Horizontal: 12,9 inches
Vertical: 8,2 inches
1680 x 1050 (60 Hz)
Active Off Mode: Not Supported
Raw EDID:
00 ff ff ff ff ff ff 00 32 0c 00 00 00 00 00 00
00 0f 01 03 80 21 15 78 0a bc a5 95 54 52 8c 27
23 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 a8 2f 90 e0 60 1a 10 40 20 40
13 00 4b cf 10 00 00 19 a8 2f 90 e0 60 1a 10 40
20 40 13 00 4b cf 10 00 00 00 00 00 00 fe 00 58
44 35 37 30 01 31 35 34 57 30 32 0a 00 00 00 fe
00 28 3f 4e 58 80 af d2 f6 02 01 0a 20 20 00 ff
* Other names and brands are the property of their respective owners.
