Software Archive
Read-only legacy content
17061 Discussions
Intel_AMT_Software_Version11.8.55.3510 _ Unable to Install
Mouk__Nik
Hello, I'm unable to proceed with AMT installation > returned error: The installer was terminated prematurely because of the following error: This platform is not supported. I'm not sure what this mean, can you help me plz ? > IntelME.log = 2018:09:30 14:43:50:703: 2018:09:30 14:43:50:719: >>>Dumping deffered logs 2018:09:30 14:43:50:563: Adding XP-x86 (0x50000501 == 0x40000501) 2018:09:30 14:43:50:563: Adding XP-x64 (0x90000502 == 0x80000502) 2018:09:30 14:43:50:563: Adding W2K3-x64 (0xA0000502 == 0x80000502) 2018:09:30 14:43:50:563: Adding W2K3-x86 (0x60000502 == 0x40000502) 2018:09:30 14:43:50:563: Adding Vista-x64 (0x90000600 == 0x80000600) 2018:09:30 14:43:50:563: Adding W2K8-x64 (0xA0000600 == 0x80000600) 2018:09:30 14:43:50:563: Adding Vista-x86 (0x50000600 == 0x40000600) 2018:09:30 14:43:50:563: Adding W2K8-x86 (0x60000600 == 0x40000600) 2018:09:30 14:43:50:563: Adding Windows7-x64 (0x90000601 == 0x80000601) 2018:09:30 14:43:50:563: Adding W2K8R2-x64 (0xA0000601 == 0x80000601) 2018:09:30 14:43:50:563: Adding Windows7-x86 (0x50000601 == 0x40000601) 2018:09:30 14:43:50:563: Adding Windows8-x64 (0x90000602 == 0x80000602) 2018:09:30 14:43:50:563: Adding W2K12-x64 (0xA0000602 == 0x80000602) 2018:09:30 14:43:50:563: Adding Windows8-x86 (0x50000602 == 0x40000602) 2018:09:30 14:43:50:563: Adding Windows8.1-x64 (0x90000603 == 0x80000603) 2018:09:30 14:43:50:563: Adding W2K12R2-x64 (0xA0000603 == 0x80000603) 2018:09:30 14:43:50:563: Adding Windows8.1-x86 (0x50000603 == 0x40000603) 2018:09:30 14:43:50:563: Adding Windows10-x64 (0x90000A00 == 0x80000A00) 2018:09:30 14:43:50:563: Adding W2K16-x64 (0xA0000A00 == 0x80000A00) 2018:09:30 14:43:50:563: Adding Windows10-x86 (0x50000A00 == 0x40000A00) 2018:09:30 14:43:50:563: Checking .NET version... 2018:09:30 14:43:50:563: Expected version: v2.0.50727 2018:09:30 14:43:50:563: Found registry key for the expected .NET version. 2018:09:30 14:43:50:563: Checking .NET version... 2018:09:30 14:43:50:563: Expected version: v3.0 2018:09:30 14:43:50:563: Found registry key for the expected .NET version. 2018:09:30 14:43:50:563: Checking .NET version... 2018:09:30 14:43:50:563: Expected version: v3.5 2018:09:30 14:43:50:563: Found registry key for the expected .NET version. 2018:09:30 14:43:50:563: Checking .NET version... 2018:09:30 14:43:50:563: Expected version: v4\Client 2018:09:30 14:43:50:563: Found registry key for the expected .NET version. 2018:09:30 14:43:50:563: Checking .NET version... 2018:09:30 14:43:50:563: Expected version: v4\Full 2018:09:30 14:43:50:563: Found registry key for the expected .NET version. 2018:09:30 14:43:50:563: Checking .NET version... 2018:09:30 14:43:50:563: Expected version: v4.5\Client 2018:09:30 14:43:50:563: Found registry key for the expected .NET version. 2018:09:30 14:43:50:563: Looking for .NET version 4.5 or above 2018:09:30 14:43:50:563: Found version: 4.7.02053 2018:09:30 14:43:50:563: Checking .NET version... 2018:09:30 14:43:50:563: Expected version: v4.5\Full 2018:09:30 14:43:50:563: Found registry key for the expected .NET version. 2018:09:30 14:43:50:563: Looking for .NET version 4.5 or above 2018:09:30 14:43:50:563: Found version: 4.7.02053 2018:09:30 14:43:50:563: Loading saved properties 2018:09:30 14:43:50:687: Effective command line: "Disk1\ME_SW_MSI\SetupME.exe" 2018:09:30 14:43:50:719: >>> Log start 2018:09:30 14:43:50:719: Mutex with given name doesn't exist. Creating new one. 2018:09:30 14:43:50:719: Obtained mutex succesfully. 2018:09:30 14:43:50:719: Single-instance mutex has been obtained 2018:09:30 14:43:50:719: Core version: 2.7.1 2018:09:30 14:43:50:719: Setup version: 2.3.18.0 2018:09:30 14:43:50:719: Command line: "Disk1\ME_SW_MSI\SetupME.exe" 2018:09:30 14:43:50:719: OS data: 6-1-1-1 64-bit 2018:09:30 14:43:50:719: System up time: 377 sec 2018:09:30 14:43:50:719: Reboot pending: No 2018:09:30 14:43:50:719: Current UI language: 040C 2018:09:30 14:43:50:719: Language folder: C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp 2018:09:30 14:43:50:765: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\ar-SA\IntelCommon.dll. Lang 0401. Rank 0 2018:09:30 14:43:50:797: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\cs-CZ\IntelCommon.dll. Lang 0405. Rank 0 2018:09:30 14:43:50:828: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\da-DK\IntelCommon.dll. Lang 0406. Rank 0 2018:09:30 14:43:50:843: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\de-DE\IntelCommon.dll. Lang 0407. Rank 0 2018:09:30 14:43:50:890: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\el-GR\IntelCommon.dll. Lang 0408. Rank 0 2018:09:30 14:43:50:984: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\en-US\IntelCommon.dll. Lang 0409. Rank 1 2018:09:30 14:43:50:999: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\es-ES\IntelCommon.dll. Lang 0C0A. Rank 0 2018:09:30 14:43:51:015: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\fi-FI\IntelCommon.dll. Lang 040B. Rank 0 2018:09:30 14:43:51:046: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\fr-FR\IntelCommon.dll. Lang 040C. Rank 3 2018:09:30 14:43:51:077: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\he-IL\IntelCommon.dll. Lang 040D. Rank 0 2018:09:30 14:43:51:093: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\hu-HU\IntelCommon.dll. Lang 040E. Rank 0 2018:09:30 14:43:51:109: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\it-IT\IntelCommon.dll. Lang 0410. Rank 0 2018:09:30 14:43:51:155: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\ja-JP\IntelCommon.dll. Lang 0411. Rank 0 2018:09:30 14:43:51:202: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\ko-KR\IntelCommon.dll. Lang 0412. Rank 0 2018:09:30 14:43:51:249: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\nb-NO\IntelCommon.dll. Lang 0414. Rank 0 2018:09:30 14:43:51:265: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\nl-NL\IntelCommon.dll. Lang 0413. Rank 0 2018:09:30 14:43:51:327: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\pl-PL\IntelCommon.dll. Lang 0415. Rank 0 2018:09:30 14:43:51:343: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\pt-BR\IntelCommon.dll. Lang 0416. Rank 0 2018:09:30 14:43:51:389: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\pt-PT\IntelCommon.dll. Lang 0816. Rank 0 2018:09:30 14:43:51:421: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\ru-RU\IntelCommon.dll. Lang 0419. Rank 0 2018:09:30 14:43:51:436: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\sk-SK\IntelCommon.dll. Lang 041B. Rank 0 2018:09:30 14:43:51:452: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\sl-SI\IntelCommon.dll. Lang 0424. Rank 0 2018:09:30 14:43:51:467: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\sv-SE\IntelCommon.dll. Lang 041D. Rank 0 2018:09:30 14:43:51:467: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\th-TH\IntelCommon.dll. Lang 041E. Rank 0 2018:09:30 14:43:51:499: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\tr-TR\IntelCommon.dll. Lang 041F. Rank 0 2018:09:30 14:43:51:499: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\zh-CN\IntelCommon.dll. Lang 0804. Rank 0 2018:09:30 14:43:51:514: Found C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp\zh-TW\IntelCommon.dll. Lang 0404. Rank 0 2018:09:30 14:43:51:514: Loading language 040C 2018:09:30 14:43:51:592: Setup mode: Installation 2018:09:30 14:43:51:592: Looking for OS: 5.1 5.2 2018:09:30 14:43:51:592: Preparing to check for Kernal Mode Driver Framework 1.11 or higher 2018:09:30 14:43:51:592: KMDF 1.11 or higher detected! 2018:09:30 14:43:51:592: Checking .NET version... 2018:09:30 14:43:51:592: Expected version: v3.5 2018:09:30 14:43:51:592: Found registry key for the expected .NET version. 2018:09:30 14:43:51:592: .NET version check passed 2018:09:30 14:43:51:592: Looking for OS: 5.1 5.2 6.0 6.1 6.2 6.3 10.0 2018:09:30 14:43:51:592: OS check passed 2018:09:30 14:43:51:592: Checking .NET version... 2018:09:30 14:43:51:592: Expected version: v3.5 2018:09:30 14:43:51:592: Found registry key for the expected .NET version. 2018:09:30 14:43:51:592: .NET version check passed 2018:09:30 14:43:51:592: Resolving driver source 2018:09:30 14:43:51:592: Using embedded driver(s). Temp source is 'C:\Users\SAD~1\AppData\Local\Temp\IIFC60D.tmp' 2018:09:30 14:43:51:639: Using folder 'C:\Users\SAD~1\AppData\Local\Temp\IIFC60D.tmp' as the driver source 2018:09:30 14:43:51:639: Scanning all active devices 2018:09:30 14:43:51:748: Scanning HECI_REL\win10\heci.inf (Name: HECI_REL_WIN10_HECI, Version: 11.7.0.1045) 2018:09:30 14:43:51:764: Section with the best match: Intel.NTamd64.6.2 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_8C3A (Intel(R) Management Engine Interface ) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_9C3A (Intel(R) Management Engine Interface ) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_8D3A (Intel(R) Management Engine Interface ) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_9CBA (Intel(R) Management Engine Interface ) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_8CBA (Intel(R) Management Engine Interface ) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_9D3A (Intel(R) Management Engine Interface ) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_A13A (Intel(R) Management Engine Interface ) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_A2BA (Intel(R) Management Engine Interface ) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_A1BA (Intel(R) Management Engine Interface ) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_A23A (Intel(R) Management Engine Interface ) 2018:09:30 14:43:51:764: MUP OS bits: 0x1FF000 2018:09:30 14:43:51:764: Scanning HECI_REL\win7\heci.inf (Name: HECI_REL_WIN7_HECI, Version: 11.7.0.1045) 2018:09:30 14:43:51:764: Section with the best match: Intel.NTamd64.6.1 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_8C3A (Intel(R) Management Engine Interface ) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_9C3A (Intel(R) Management Engine Interface ) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_8D3A (Intel(R) Management Engine Interface ) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_9CBA (Intel(R) Management Engine Interface ) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_8CBA (Intel(R) Management Engine Interface ) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_9D3A (Intel(R) Management Engine Interface ) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_A13A (Intel(R) Management Engine Interface ) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_A2BA (Intel(R) Management Engine Interface ) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_A1BA (Intel(R) Management Engine Interface ) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_A23A (Intel(R) Management Engine Interface ) 2018:09:30 14:43:51:764: MUP OS bits: 0x1B6FFE 2018:09:30 14:43:51:764: Scanning SOL_REL\mesrl.inf (Name: SOL_REL_MESRL, Version: 11.6.0.1009) 2018:09:30 14:43:51:764: Section with the best match: Intel.NTamd64 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_8C3D&CC_0700 (Intel(R) Active Management Technology - SOL) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_9C3D&CC_0700 (Intel(R) Active Management Technology - SOL) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_9CBD&CC_0700 (Intel(R) Active Management Technology - SOL) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_8D3D&CC_0700 (Intel(R) Active Management Technology - SOL) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_9D3D&CC_0700 (Intel(R) Active Management Technology - SOL) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_A13D&CC_0700 (Intel(R) Active Management Technology - SOL) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_A2BD&CC_0700 (Intel(R) Active Management Technology - SOL) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_A1BD&CC_0700 (Intel(R) Active Management Technology - SOL) 2018:09:30 14:43:51:764: Device: PCI\VEN_8086&DEV_A23D&CC_0700 (Intel(R) Active Management Technology - SOL) 2018:09:30 14:43:51:764: MUP OS bits: 0x1FFFFE 2018:09:30 14:43:51:764: E Win32 exception occurred!! 2018:09:30 14:43:51:764: Error code: 0x4E24 (20004) 2018:09:30 14:43:51:764: Error text: '' 2018:09:30 14:43:51:764: Extended error text: 'Error in device matching' 2018:09:30 14:43:51:764: Debug info: 'Setup.cpp (841)' 2018:09:30 14:43:51:764: Reading storyboard 2018:09:30 14:43:51:764: Page count: 7 2018:09:30 14:43:51:764: Added: Welcome 2018:09:30 14:43:51:764: Added: Modify 2018:09:30 14:43:51:764: Added: License 2018:09:30 14:43:51:764: Added: Destination 2018:09:30 14:43:51:764: Added: Progress 2018:09:30 14:43:51:764: Added: Finish 2018:09:30 14:43:51:764: Added: Error 2018:09:30 14:43:51:764: Reading string map 2018:09:30 14:43:51:764: No string map present 2018:09:30 14:43:51:811: Showing page: Error 2018:09:30 14:44:14:695: Dumping properties (40 total) 2018:09:30 14:44:14:695: IIF_MSILOGLEVEL=4096 2018:09:30 14:44:14:695: ME_WMI_STATE=1 2018:09:30 14:44:14:695: ME_LMS_STATE=1 2018:09:30 14:44:14:695: ME_NAC_STATE=1 2018:09:30 14:44:14:695: ME_IMSS_STATE=1 2018:09:30 14:44:14:695: ME_VCCRT_STATE=1 2018:09:30 14:44:14:695: ME_DAL_STATE=1 2018:09:30 14:44:14:695: ME_GEMALTO_FW=0 2018:09:30 14:44:14:695: IIF_NOPRUNE=1 2018:09:30 14:44:14:695: IIF_NOMSITRANSACTIONS=1 2018:09:30 14:44:14:695: ME_IOC_STATE=0 2018:09:30 14:44:14:695: ME_IOCU_STATE=1 2018:09:30 14:44:14:695: ME_ICLS_ONLY=0 2018:09:30 14:44:14:695: ME_ICLS_SHOW=0 2018:09:30 14:44:14:695: IIF_LOGFOLDER=C:\Users\Saâd\Intel\Logs 2018:09:30 14:44:14:695: IIF_SETUPVERSION=2.3.18.0 2018:09:30 14:44:14:695: IIF_PACKAGEVERSION=11.7.0.1052 2018:09:30 14:44:14:695: IIF_SETUPPATH=C:\Users\Saâd\AppData\Local\Temp\{5EBE2EE2-1CEC-47C6-BB37-C280ED4BE626}\Disk1\ME_SW_MSI 2018:09:30 14:44:14:695: IIF_CACHELOC=C:\ProgramData\Intel\Package Cache\{1CEAC85D-2590-4760-800F-8DE5E91F3700} 2018:09:30 14:44:14:695: IIF_OS=6.1 2018:09:30 14:44:14:695: IIF_OSSERVICEPACK=1 2018:09:30 14:44:14:695: IIF_IS64=1 2018:09:30 14:44:14:695: IIF_NET20=1 2018:09:30 14:44:14:695: IIF_NET30=1 2018:09:30 14:44:14:695: IIF_NET35=1 2018:09:30 14:44:14:695: IIF_NET40CLIENT=1 2018:09:30 14:44:14:695: IIF_NET40FULL=1 2018:09:30 14:44:14:695: IIF_NET45CLIENT=1 2018:09:30 14:44:14:695: IIF_NET45FULL=1 2018:09:30 14:44:14:695: IIF_INSTALLFOLDER=C:\Program Files (x86)\Intel\Intel(R) Management Engine Components 2018:09:30 14:44:14:695: IIF_LANGCOUNTRY=fr-FR 2018:09:30 14:44:14:695: IIF_PROGRAMFILES86FOLDER=C:\Program Files (x86) 2018:09:30 14:44:14:695: IIF_PROGRAMFILESFOLDER=C:\Program Files 2018:09:30 14:44:14:695: IIF_HASBATTERY=1 2018:09:30 14:44:14:695: IIF_BATTERYPOWER=100 2018:09:30 14:44:14:695: IIF_RESOURCEFOLDER=C:\Users\SAD~1\AppData\Local\Temp\IIFC2A2.tmp 2018:09:30 14:44:14:695: IIF_SETUPMODE=INSTALL 2018:09:30 14:44:14:695: IIF_EXITCODE=20004 2018:09:30 14:44:14:695: IIF_LICENSE= 2018:09:30 14:44:14:695: IIF_README= 2018:09:30 14:44:14:695: Dumping feature states 2018:09:30 14:44:14:695: Feature: 'LegacyUninstallFeature' | Package: '{8D93D30D-EB30-463C-A89D-6C347A623730}' | Current: 'false' | New: 'false' 2018:09:30 14:44:14:695: Feature: 'DriverFeature' | Package: '{EBB4E1B1-D0A2-4F8E-BAFC-EF49A4D4E2A7}' | Current: 'false' | New: 'false' 2018:09:30 14:44:14:695: Feature: 'DriverFeature' | Package: '{7F26F9B8-4011-417B-A8F8-3D12D264CAEC}' | Current: 'false' | New: 'false' 2018:09:30 14:44:14:695: Feature: 'LangFeature' | Package: '{4792E8B1-F79E-4C5B-A8DC-391F64C30B75}' | Current: 'false' | New: 'false' 2018:09:30 14:44:14:695: Feature: 'LMSFeature' | Package: '{C769B4D9-C208-4FC9-BBEF-420C8C219253}' | Current: 'false' | New: 'false' 2018:09:30 14:44:14:695: Feature: 'WMIFeature' | Package: '{C769B4D9-C208-4FC9-BBEF-420C8C219253}' | Current: 'false' | New: 'false' 2018:09:30 14:44:14:695: Feature: 'NACFeature' | Package: '{C769B4D9-C208-4FC9-BBEF-420C8C219253}' | Current: 'false' | New: 'false' 2018:09:30 14:44:14:695: Feature: 'IMSSFeature' | Package: '{C769B4D9-C208-4FC9-BBEF-420C8C219253}' | Current: 'false' | New: 'false' 2018:09:30 14:44:14:695: Feature: 'VCRedistx86' | Package: '{9A048310-A23E-4E0C-9DDC-95748970F9CE}' | Current: 'false' | New: 'false' 2018:09:30 14:44:14:711: Feature: 'UCRTx86' | Package: '{9A048310-A23E-4E0C-9DDC-95748970F9CE}' | Current: 'false' | New: 'false' 2018:09:30 14:44:14:711: Feature: 'VCRedistx64' | Package: '{AC14C73B-181A-46C8-BA0F-1FA3E5493297}' | Current: 'false' | New: 'false' 2018:09:30 14:44:14:711: Feature: 'UCRTx64' | Package: '{AC14C73B-181A-46C8-BA0F-1FA3E5493297}' | Current: 'false' | New: 'false' 2018:09:30 14:44:14:711: Feature: 'DALFeature' | Package: '{C769B4D9-C208-4FC9-BBEF-420C8C219253}' | Current: 'false' | New: 'false' 2018:09:30 14:44:14:711: Feature: 'ALL' | Package: '{EE5981C2-58DA-4C72-BB73-A7EB9962C4B3}' | Current: 'false' | New: 'false' 2018:09:30 14:44:14:711: Feature: 'ALL' | Package: '{1CB652E2-CC71-4528-8FD3-298733596FDA}' | Current: 'false' | New: 'false' 2018:09:30 14:44:14:711: Feature: 'ALL' | Package: '{F1C8187B-2653-47CD-A9BE-B554B98F68A7}' | Current: 'false' | New: 'false' 2018:09:30 14:44:14:711: Exit code (command line): 1603 2018:09:30 14:44:14:711: >>> Log End 2018:09:30 14:44:53:212: 2018:09:30 14:44:53:212: >>>Dumping deffered logs 2018:09:30 14:44:53:196: Adding XP-x86 (0x50000501 == 0x40000501) 2018:09:30 14:44:53:196: Adding XP-x64 (0x90000502 == 0x80000502) 2018:09:30 14:44:53:196: Adding W2K3-x64 (0xA0000502 == 0x80000502) 2018:09:30 14:44:53:196: Adding W2K3-x86 (0x60000502 == 0x40000502) 2018:09:30 14:44:53:196: Adding Vista-x64 (0x90000600 == 0x80000600) 2018:09:30 14:44:53:196: Adding W2K8-x64 (0xA0000600 == 0x80000600) 2018:09:30 14:44:53:196: Adding Vista-x86 (0x50000600 == 0x40000600) 2018:09:30 14:44:53:196: Adding W2K8-x86 (0x60000600 == 0x40000600) 2018:09:30 14:44:53:196: Adding Windows7-x64 (0x90000601 == 0x80000601) 2018:09:30 14:44:53:196: Adding W2K8R2-x64 (0xA0000601 == 0x80000601) 2018:09:30 14:44:53:196: Adding Windows7-x86 (0x50000601 == 0x40000601) 2018:09:30 14:44:53:196: Adding Windows8-x64 (0x90000602 == 0x80000602) 2018:09:30 14:44:53:196: Adding W2K12-x64 (0xA0000602 == 0x80000602) 2018:09:30 14:44:53:196: Adding Windows8-x86 (0x50000602 == 0x40000602) 2018:09:30 14:44:53:196: Adding Windows8.1-x64 (0x90000603 == 0x80000603) 2018:09:30 14:44:53:196: Adding W2K12R2-x64 (0xA0000603 == 0x80000603) 2018:09:30 14:44:53:196: Adding Windows8.1-x86 (0x50000603 == 0x40000603) 2018:09:30 14:44:53:196: Adding Windows10-x64 (0x90000A00 == 0x80000A00) 2018:09:30 14:44:53:196: Adding W2K16-x64 (0xA0000A00 == 0x80000A00) 2018:09:30 14:44:53:196: Adding Windows10-x86 (0x50000A00 == 0x40000A00) 2018:09:30 14:44:53:196: Checking .NET version... 2018:09:30 14:44:53:196: Expected version: v2.0.50727 2018:09:30 14:44:53:196: Found registry key for the expected .NET version. 2018:09:30 14:44:53:196: Checking .NET version... 2018:09:30 14:44:53:196: Expected version: v3.0 2018:09:30 14:44:53:196: Found registry key for the expected .NET version. 2018:09:30 14:44:53:196: Checking .NET version... 2018:09:30 14:44:53:196: Expected version: v3.5 2018:09:30 14:44:53:196: Found registry key for the expected .NET version. 2018:09:30 14:44:53:196: Checking .NET version... 2018:09:30 14:44:53:196: Expected version: v4\Client 2018:09:30 14:44:53:196: Found registry key for the expected .NET version. 2018:09:30 14:44:53:196: Checking .NET version... 2018:09:30 14:44:53:196: Expected version: v4\Full 2018:09:30 14:44:53:196: Found registry key for the expected .NET version. 2018:09:30 14:44:53:196: Checking .NET version... 2018:09:30 14:44:53:196: Expected version: v4.5\Client 2018:09:30 14:44:53:196: Found registry key for the expected .NET version. 2018:09:30 14:44:53:196: Looking for .NET version 4.5 or above 2018:09:30 14:44:53:196: Found version: 4.7.02053 2018:09:30 14:44:53:196: Checking .NET version... 2018:09:30 14:44:53:196: Expected version: v4.5\Full 2018:09:30 14:44:53:196: Found registry key for the expected .NET version. 2018:09:30 14:44:53:196: Looking for .NET version 4.5 or above 2018:09:30 14:44:53:196: Found version: 4.7.02053 2018:09:30 14:44:53:196: Loading saved properties 2018:09:30 14:44:53:212: Effective command line: "Disk1\ME_SW_MSI\SetupME.exe" 2018:09:30 14:44:53:212: >>> Log start 2018:09:30 14:44:53:212: Mutex with given name doesn't exist. Creating new one. 2018:09:30 14:44:53:212: Obtained mutex succesfully. 2018:09:30 14:44:53:212: Single-instance mutex has been obtained 2018:09:30 14:44:53:227: Core version: 2.7.4 2018:09:30 14:44:53:227: Setup version: 12.0.2704.1 2018:09:30 14:44:53:227: Command line: "Disk1\ME_SW_MSI\SetupME.exe" 2018:09:30 14:44:53:227: OS data: 6-1-1-1 64-bit 2018:09:30 14:44:53:243: System up time: 440 sec 2018:09:30 14:44:53:243: Reboot pending: No 2018:09:30 14:44:53:243: Current UI language: 040C 2018:09:30 14:44:53:258: Language folder: C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp 2018:09:30 14:44:53:274: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\ar-SA\IntelCommon.dll. Lang 0401. Rank 0 2018:09:30 14:44:53:290: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\cs-CZ\IntelCommon.dll. Lang 0405. Rank 0 2018:09:30 14:44:53:305: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\da-DK\IntelCommon.dll. Lang 0406. Rank 0 2018:09:30 14:44:53:336: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\de-DE\IntelCommon.dll. Lang 0407. Rank 0 2018:09:30 14:44:53:368: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\el-GR\IntelCommon.dll. Lang 0408. Rank 0 2018:09:30 14:44:53:399: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\en-US\IntelCommon.dll. Lang 0409. Rank 1 2018:09:30 14:44:53:414: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\es-ES\IntelCommon.dll. Lang 0C0A. Rank 0 2018:09:30 14:44:53:430: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\fi-FI\IntelCommon.dll. Lang 040B. Rank 0 2018:09:30 14:44:53:446: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\fr-FR\IntelCommon.dll. Lang 040C. Rank 3 2018:09:30 14:44:53:461: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\he-IL\IntelCommon.dll. Lang 040D. Rank 0 2018:09:30 14:44:53:477: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\hu-HU\IntelCommon.dll. Lang 040E. Rank 0 2018:09:30 14:44:53:492: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\it-IT\IntelCommon.dll. Lang 0410. Rank 0 2018:09:30 14:44:53:524: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\ja-JP\IntelCommon.dll. Lang 0411. Rank 0 2018:09:30 14:44:53:555: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\ko-KR\IntelCommon.dll. Lang 0412. Rank 0 2018:09:30 14:44:53:602: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\nb-NO\IntelCommon.dll. Lang 0414. Rank 0 2018:09:30 14:44:53:617: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\nl-NL\IntelCommon.dll. Lang 0413. Rank 0 2018:09:30 14:44:53:648: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\pl-PL\IntelCommon.dll. Lang 0415. Rank 0 2018:09:30 14:44:53:695: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\pt-BR\IntelCommon.dll. Lang 0416. Rank 0 2018:09:30 14:44:53:711: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\pt-PT\IntelCommon.dll. Lang 0816. Rank 0 2018:09:30 14:44:53:726: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\ru-RU\IntelCommon.dll. Lang 0419. Rank 0 2018:09:30 14:44:53:758: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\sk-SK\IntelCommon.dll. Lang 041B. Rank 0 2018:09:30 14:44:53:773: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\sl-SI\IntelCommon.dll. Lang 0424. Rank 0 2018:09:30 14:44:53:789: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\sv-SE\IntelCommon.dll. Lang 041D. Rank 0 2018:09:30 14:44:53:789: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\th-TH\IntelCommon.dll. Lang 041E. Rank 0 2018:09:30 14:44:53:820: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\tr-TR\IntelCommon.dll. Lang 041F. Rank 0 2018:09:30 14:44:53:836: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\zh-CN\IntelCommon.dll. Lang 0804. Rank 0 2018:09:30 14:44:53:867: Found C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp\zh-TW\IntelCommon.dll. Lang 0404. Rank 0 2018:09:30 14:44:53:867: Loading language 040C 2018:09:30 14:44:53:867: Setup mode: Installation 2018:09:30 14:44:53:867: Looking for OS: 5.1 5.2 2018:09:30 14:44:53:867: Preparing to check for Kernal Mode Driver Framework 1.11 or higher 2018:09:30 14:44:53:867: KMDF 1.11 or higher detected! 2018:09:30 14:44:53:867: Checking .NET version... 2018:09:30 14:44:53:867: Expected version: v3.5 2018:09:30 14:44:53:867: Found registry key for the expected .NET version. 2018:09:30 14:44:53:867: .NET version check passed 2018:09:30 14:44:53:867: Looking for OS: 5.1 5.2 6.0 6.1 6.2 6.3 10.0 2018:09:30 14:44:53:867: OS check passed 2018:09:30 14:44:53:867: Checking .NET version... 2018:09:30 14:44:53:867: Expected version: v3.5 2018:09:30 14:44:53:867: Found registry key for the expected .NET version. 2018:09:30 14:44:53:867: .NET version check passed 2018:09:30 14:44:53:867: Resolving driver source 2018:09:30 14:44:53:867: Using embedded driver(s). Temp source is 'C:\Users\SAD~1\AppData\Local\Temp\IIFB951.tmp' 2018:09:30 14:44:53:898: Using folder 'C:\Users\SAD~1\AppData\Local\Temp\IIFB951.tmp' as the driver source 2018:09:30 14:44:53:898: Scanning all active devices 2018:09:30 14:44:53:929: Scanning HECI_REL\win10\heci.inf (Name: HECI_REL_WIN10_HECI, Version: 1815.12.0.2021) 2018:09:30 14:44:53:929: Section with the best match: Intel.NTamd64.6.2 2018:09:30 14:44:53:929: Device: PCI\VEN_8086&DEV_9CBA (Intel(R) Management Engine Interface ) 2018:09:30 14:44:53:929: Device: PCI\VEN_8086&DEV_9D3A (Intel(R) Management Engine Interface ) 2018:09:30 14:44:53:929: Device: PCI\VEN_8086&DEV_A13A (Intel(R) Management Engine Interface ) 2018:09:30 14:44:53:929: Device: PCI\VEN_8086&DEV_A2BA (Intel(R) Management Engine Interface ) 2018:09:30 14:44:53:929: Device: PCI\VEN_8086&DEV_A1BA (Intel(R) Management Engine Interface ) 2018:09:30 14:44:53:929: Device: PCI\VEN_8086&DEV_A23A (Intel(R) Management Engine Interface ) 2018:09:30 14:44:53:929: Device: PCI\VEN_8086&DEV_9DE0 (Intel(R) Management Engine Interface ) 2018:09:30 14:44:53:929: Device: PCI\VEN_8086&DEV_A360 (Intel(R) Management Engine Interface ) 2018:09:30 14:44:53:929: MUP OS bits: 0x1FF000 2018:09:30 14:44:53:929: Scanning HECI_REL\win7\heci.inf (Name: HECI_REL_WIN7_HECI, Version: 1815.12.0.2021) 2018:09:30 14:44:53:929: Section with the best match: Intel.NTamd64.6.1 2018:09:30 14:44:53:929: Device: PCI\VEN_8086&DEV_9CBA (Intel(R) Management Engine Interface ) 2018:09:30 14:44:53:929: Device: PCI\VEN_8086&DEV_9D3A (Intel(R) Management Engine Interface ) 2018:09:30 14:44:53:929: Device: PCI\VEN_8086&DEV_A13A (Intel(R) Management Engine Interface ) 2018:09:30 14:44:53:929: Device: PCI\VEN_8086&DEV_A2BA (Intel(R) Management Engine Interface ) 2018:09:30 14:44:53:929: MUP OS bits: 0xE00 2018:09:30 14:44:53:929: Scanning SOL_REL\mesrl.inf (Name: SOL_REL_MESRL, Version: 1744.12.0.1071) 2018:09:30 14:44:53:929: Section with the best match: Intel.NTamd64 2018:09:30 14:44:53:929: Device: PCI\VEN_8086&DEV_9CBD&CC_0700 (Intel(R) Active Management Technology - SOL) 2018:09:30 14:44:53:929: Device: PCI\VEN_8086&DEV_9D3D&CC_0700 (Intel(R) Active Management Technology - SOL) 2018:09:30 14:44:53:929: Device: PCI\VEN_8086&DEV_A13D&CC_0700 (Intel(R) Active Management Technology - SOL) 2018:09:30 14:44:53:929: Device: PCI\VEN_8086&DEV_A2BD&CC_0700 (Intel(R) Active Management Technology - SOL) 2018:09:30 14:44:53:929: Device: PCI\VEN_8086&DEV_A1BD&CC_0700 (Intel(R) Active Management Technology - SOL) 2018:09:30 14:44:53:929: Device: PCI\VEN_8086&DEV_A23D&CC_0700 (Intel(R) Active Management Technology - SOL) 2018:09:30 14:44:53:929: Device: PCI\VEN_8086&DEV_9DE3&CC_0700 (Intel(R) Active Management Technology - SOL) 2018:09:30 14:44:53:929: Device: PCI\VEN_8086&DEV_A363&CC_0700 (Intel(R) Active Management Technology - SOL) 2018:09:30 14:44:53:929: MUP OS bits: 0x1FFFFE 2018:09:30 14:44:53:929: E Win32 exception occurred!! 2018:09:30 14:44:53:929: Error code: 0x4E24 (20004) 2018:09:30 14:44:53:929: Error text: '' 2018:09:30 14:44:53:929: Extended error text: 'Error in device matching' 2018:09:30 14:44:53:929: Debug info: 'd:\buildagent_prod\p4\1326309967\installer_ws\common\core\setup.cpp (827)' 2018:09:30 14:44:53:929: Reading storyboard 2018:09:30 14:44:53:929: Page count: 7 2018:09:30 14:44:53:929: Added: Welcome 2018:09:30 14:44:53:929: Added: Modify 2018:09:30 14:44:53:929: Added: License 2018:09:30 14:44:53:929: Added: Destination 2018:09:30 14:44:53:929: Added: Progress 2018:09:30 14:44:53:929: Added: Finish 2018:09:30 14:44:53:929: Added: Error 2018:09:30 14:44:53:929: Reading string map 2018:09:30 14:44:53:929: No string map present 2018:09:30 14:44:53:945: Showing page: Error 2018:09:30 14:44:57:658: Link: Launching 'C:\Users\Saâd\Intel\Logs' 2018:09:30 15:08:05:582: Dumping properties (38 total) 2018:09:30 15:08:05:582: IIF_MSILOGLEVEL=4096 2018:09:30 15:08:05:582: ME_WMI_STATE=1 2018:09:30 15:08:05:582: ME_LMS_STATE=1 2018:09:30 15:08:05:582: ME_NAC_STATE=1 2018:09:30 15:08:05:598: ME_IMSS_STATE=1 2018:09:30 15:08:05:598: ME_VCCRT_STATE=1 2018:09:30 15:08:05:598: ME_DAL_STATE=1 2018:09:30 15:08:05:598: ME_GEMALTO_FW=0 2018:09:30 15:08:05:598: IIF_NOPRUNE=1 2018:09:30 15:08:05:598: IIF_NOMSITRANSACTIONS=1 2018:09:30 15:08:05:598: ME_ICLS_ONLY=0 2018:09:30 15:08:05:598: ME_ICLS_SHOW=0 2018:09:30 15:08:05:598: IIF_LOGFOLDER=C:\Users\Saâd\Intel\Logs 2018:09:30 15:08:05:598: IIF_SETUPVERSION=12.0.2704.1 2018:09:30 15:08:05:598: IIF_PACKAGEVERSION=1824.12.0.1140 2018:09:30 15:08:05:598: IIF_SETUPPATH=C:\Users\Saâd\AppData\Local\Temp\{48E33A46-3439-476F-9A89-55D428C79A2E}\Disk1\ME_SW_MSI 2018:09:30 15:08:05:598: IIF_CACHELOC=C:\ProgramData\Intel\Package Cache\{1CEAC85D-2590-4760-800F-8DE5E91F3700} 2018:09:30 15:08:05:598: IIF_OS=6.1 2018:09:30 15:08:05:598: IIF_OSSERVICEPACK=1 2018:09:30 15:08:05:598: IIF_IS64=1 2018:09:30 15:08:05:598: IIF_NET20=1 2018:09:30 15:08:05:598: IIF_NET30=1 2018:09:30 15:08:05:598: IIF_NET35=1 2018:09:30 15:08:05:598: IIF_NET40CLIENT=1 2018:09:30 15:08:05:598: IIF_NET40FULL=1 2018:09:30 15:08:05:598: IIF_NET45CLIENT=1 2018:09:30 15:08:05:598: IIF_NET45FULL=1 2018:09:30 15:08:05:598: IIF_INSTALLFOLDER=C:\Program Files (x86)\Intel\Intel(R) Management Engine Components 2018:09:30 15:08:05:613: IIF_LANGCOUNTRY=fr-FR 2018:09:30 15:08:05:613: IIF_PROGRAMFILES86FOLDER=C:\Program Files (x86) 2018:09:30 15:08:05:613: IIF_PROGRAMFILESFOLDER=C:\Program Files 2018:09:30 15:08:05:613: IIF_HASBATTERY=1 2018:09:30 15:08:05:613: IIF_BATTERYPOWER=100 2018:09:30 15:08:05:613: IIF_RESOURCEFOLDER=C:\Users\SAD~1\AppData\Local\Temp\IIFB6EF.tmp 2018:09:30 15:08:05:613: IIF_SETUPMODE=INSTALL 2018:09:30 15:08:05:613: IIF_EXITCODE=20004 2018:09:30 15:08:05:613: IIF_LICENSE= 2018:09:30 15:08:05:613: IIF_README= 2018:09:30 15:08:05:613: Dumping feature states 2018:09:30 15:08:05:613: Feature: 'DriverFeature' | Package: '{EBB4E1B1-D0A2-4F8E-BAFC-EF49A4D4E2A7}' | Current: 'false' | New: 'false' 2018:09:30 15:08:05:613: Feature: 'DriverFeature' | Package: '{7F26F9B8-4011-417B-A8F8-3D12D264CAEC}' | Current: 'false' | New: 'false' 2018:09:30 15:08:05:613: Feature: 'LangFeature' | Package: '{4792E8B1-F79E-4C5B-A8DC-391F64C30B75}' | Current: 'false' | New: 'false' 2018:09:30 15:08:05:613: Feature: 'LMSFeature' | Package: '{C769B4D9-C208-4FC9-BBEF-420C8C219253}' | Current: 'false' | New: 'false' 2018:09:30 15:08:05:613: Feature: 'WMIFeature' | Package: '{C769B4D9-C208-4FC9-BBEF-420C8C219253}' | Current: 'false' | New: 'false' 2018:09:30 15:08:05:629: Feature: 'NACFeature' | Package: '{C769B4D9-C208-4FC9-BBEF-420C8C219253}' | Current: 'false' | New: 'false' 2018:09:30 15:08:05:629: Feature: 'IMSSFeature' | Package: '{C769B4D9-C208-4FC9-BBEF-420C8C219253}' | Current: 'false' | New: 'false' 2018:09:30 15:08:05:629: Feature: 'VCRedistx86' | Package: '{9A048310-A23E-4E0C-9DDC-95748970F9CE}' | Current: 'false' | New: 'false' 2018:09:30 15:08:05:629: Feature: 'UCRTx86' | Package: '{9A048310-A23E-4E0C-9DDC-95748970F9CE}' | Current: 'false' | New: 'false' 2018:09:30 15:08:05:629: Feature: 'VCRedistx64' | Package: '{AC14C73B-181A-46C8-BA0F-1FA3E5493297}' | Current: 'false' | New: 'false' 2018:09:30 15:08:05:629: Feature: 'UCRTx64' | Package: '{AC14C73B-181A-46C8-BA0F-1FA3E5493297}' | Current: 'false' | New: 'false' 2018:09:30 15:08:05:629: Feature: 'DALFeature' | Package: '{C769B4D9-C208-4FC9-BBEF-420C8C219253}' | Current: 'false' | New: 'false' 2018:09:30 15:08:05:629: Exit code (command line): 1603 2018:09:30 15:08:05:645: >>> Log End
