Software Archive
Read-only legacy content
Intel@ Android USB driver support on Windows 8.1
Sandro_A_
初学者
5,154 次查看
Why i cannot install usb to my win 8.1? a message  "This OS is not supported: Windows"
My computer is DELL.
0 项奖励
7 回复数
Alexander_W_Intel
5,154 次查看
the driver was released for devices that are on the market since a while. So I'm not sure even if you get it installed it will really work with your device.
If you would like to try this drivers anyways, please try to run the installer in compatibility mode: Right click on the installer, select properties, go on the Compatibility tab and select "Run this program in compatibility mode for" Windows 7. This usually helps, but I haven't tried it for this particular installer.
Alex
0 项奖励
Sandro_A_
初学者
5,154 次查看
thanks! win 7 not work is only win xp sp3
0 项奖励
Alexander_W_Intel
5,154 次查看
Great that it worked now for you and thanks for reporting the solution!
Alex
0 项奖励
Made_W_
初学者
5,154 次查看
I just installed this driver on Windows 8.1 64bit with compatibility mode for Windows 7.
0 项奖励
Aszrul_Aszrie_M_
初学者
5,154 次查看
Dear Intel,
Unfortunately, we are unable to download your latest version (1.9.0) of Intel USB driver for Android. (Access denied). Care for some clarification?
Thank you
0 项奖励
Ernie_V_
初学者
5,154 次查看
Same issue here. 'Access Denied'. I have signed-up and confirmed my email as well. Any solution, as in right away?
Second concern. Why do you require Captcha to send a post when we've already confirmed our email?
0 项奖励
Sergio_J__C_
初学者
5,154 次查看
I have this problem too! With my ultrabook with win8.1, i  made a downgrade to win7 but with win 8.0 work fine, maybe with win 10.
0 项奖励
回复
