Software Archive
Read-only legacy content
17060 Discussions
Intel@ Android USB driver support on Windows 8.1
Sandro_A_
Why i cannot install usb to my win 8.1? a message  "This OS is not supported: Windows"
My computer is DELL.
Alexander_W_Intel
the driver was released for devices that are on the market since a while. So I'm not sure even if you get it installed it will really work with your device.
If you would like to try this drivers anyways, please try to run the installer in compatibility mode: Right click on the installer, select properties, go on the Compatibility tab and select "Run this program in compatibility mode for" Windows 7. This usually helps, but I haven't tried it for this particular installer.
Alex
Sandro_A_
thanks! win 7 not work is only win xp sp3
Alexander_W_Intel
Great that it worked now for you and thanks for reporting the solution!
Alex
Made_W_
I just installed this driver on Windows 8.1 64bit with compatibility mode for Windows 7.
Aszrul_Aszrie_M_
Dear Intel,
Unfortunately, we are unable to download your latest version (1.9.0) of Intel USB driver for Android. (Access denied). Care for some clarification?
Thank you
Ernie_V_
Same issue here. 'Access Denied'. I have signed-up and confirmed my email as well. Any solution, as in right away?
Second concern. Why do you require Captcha to send a post when we've already confirmed our email?
Sergio_J__C_
I have this problem too! With my ultrabook with win8.1, i  made a downgrade to win7 but with win 8.0 work fine, maybe with win 10.
