I'm using the Intel Device Builder with Build: 1.0.2777.24761.
I try to create a Root Device with just one embedded device. The target platform should be "Intel C Stack - Windows 95,98,NT,XP (WinSock1)" and with CR+LF Windows Style Code.
Everything works fine ( I can export the stack etc) till I try to build the project. I get the following errormessage: "upnpmicrostack.c(1243) : error C2065: 'FriendlyName2': unknown identendifier".
Can anyone help me? Does the Intel Device Builder Support embedded Devices?
Johannes
Johannes
I've just followeda tutorial video description (link below)to build a sampleUPnP device on Windows XP. FYI, I selected "Intel C Stack - Windows 98, NT, XP (Winsock2)" and unchecked HTTP1.1on "Intel Device Builder for UPnP Technologies Build: 1.0.2777.24761)
Then it works fine
(http://www3.intel.com/cd/ids/developer/asmo-na/eng/downloads/upnp/tutorials/index.htm)
Good luck
Hello Johannes,
I am using http://opentools.homeip.net/dev-tools-for-upnp downloaded 2/2012 must be version v0.0.51 and am seeing the same issue.
What did you finally do to solve the problem? AND - are you aware of any docs, videos, pdfs for this software?
I would love a tutorial. Thanks - Just using this S/W for the first time.
Scott
Scott
