Software Archive
Read-only legacy content
17061 讨论
Intel Fortran for Mac on multi-user machine
Burke_H_
初学者
1,230 次查看
I have a registered, activated version of the compiler which I have installed on my single-user desktop and 2 single-user laptops. I am trying to install the compiler on one of the desktops in my lab, which is registered to me but also has other users. The installer won't allow me to install on this machine.
How can I get the compiler to work on a multi-user machine?
0 项奖励
10 回复数
Chuck
新分销商 II
1,230 次查看
Greetings,
The license I show for you is a single user academic license. This would limit it's usage to machines that only you have access to.
Chuck
0 项奖励
Burke_H_
初学者
1,230 次查看
Quoting - Chuck (Intel)
Greetings,
Chuck
What are my options for using it on multi-user machines?
0 项奖励
Burke_H_
初学者
1,230 次查看
Greetings,
Chuck
one more question-- if i have it installed and working on a single user machine, and i then add a new user, what happens? will the compiler no longer work?
0 项奖励
Chuck
新分销商 II
1,230 次查看
You should be able to install it on any machine regardless of the user count. There are some variables that may not allow the installation.
Which MAC OS is running on this machine Versus the others?
0 项奖励
Burke_H_
初学者
1,230 次查看
All machines are running 10.5.8
0 项奖励
Burke_H_
初学者
1,230 次查看
Thanks, Chuck. Is the above comment in contradiction to yours of 18 September at 2:37:
"Greetings,
Chuck"
0 项奖励
Chuck
新分销商 II
1,230 次查看
"Greetings,
Chuck"
Well, Yes. Adding users would not be following the License agreement for a single user license.
Chuck
0 项奖励
Burke_H_
初学者
1,230 次查看
okay, so back to the earlier question:
How do I use the compiler on a multi-user machine?
Just buying a new single-user license for that machine won't solve the problem, right?
0 项奖励
Burke_H_
初学者
1,230 次查看
problem solved. turns out for some reason I needed to reset the privileges on the application support/Intel folder to get this to work.
0 项奖励
Chuck
新分销商 II
1,230 次查看
That's good news. Thank you for the update.
Chuck
0 项奖励
回复
