Software Archive
Read-only legacy content
17060 Discussions
Intel Galileo Dev Kit, a few questions RE encryption and using arduino sketches
Anonymous
Not applicable
Hi guys just got the IoT Dev  Kit set up and working well. I have a few questions for a project that I am going to continue from when I was using the extended linux version. I have written a sketch that sends a get request from the board to my API on my website and updates the database with the temperature and also receives information from the database about whether to turn the led on or off on the board. I want to extend this with the new tools from the kit but have a few questions.
1.  Is it possible to import the Arduino sketch into the Eclipse IDE and continue work from where I left off or will it require re writing in Eclipse.
2. How can I send secure requests I have not been successful in sending a https request only http. I have read around that maybe this is not possible if not the minimum I need to do is some form of encryption that can be accessed via the php side on my webserver and vice versa I searched for days and found one library that was included on the previous version of linux for the Intel Galileo that would be compatible with php but could not get it working.
Thanks to anyone that can offer assistance.
Anonymous
Not applicable
Was this a bad question ?
Matthias_H_Intel
Looks like :-)
What is "the extended linux version"?
programming natively you could easily use HTML5 websockets for that purpose which might work even better than HTTP GET requests. You may e.g. use mod_pywebsocket for that on the target if you speak Python or something similar for C/C++ which you can work on within the Eclipse IDE.
high-level speaking Arduino sketches are just C++ code. Hence in principle can be compiled natively as well (at the end it's exactly what the Arduino IDE does - it takes the sketch code and cross compiles it to a native executable). However, if it comes to Arduino specifics, there are a lot of wrappers required which you wouldn't require and find in the Intel IoT devkit Eclipse (well, you could in principle take the wrappers from Arduino IDE and put them to Eclipse IDE - at the end copy&paste from one sysroot to the other - but you would be on your own on that journey). That said, it depends on what you need to port. If it's just pure C++ functions which don't use Arduino specifics you should be able to 1:1 copy&paste them over. But just continuing projects wouldn't work by default.
That's just a question of what your http server supports. For https you would require certificates (either self signed or from an authority). Implementation vice you shouldn't see a difference between HTTP and HTTPS
Not sure which server you use on Galileo. If you use lighttpd see e.g. http://redmine.lighttpd.net/projects/1/wiki/HowToSimpleSSL
Using websockets it should also be relatively easy to use either ws: or wss: for a non-secure or secured (over TLS) websocket (see e.g. https://code.google.com/p/pywebsocket/source/browse/trunk/src/mod_pywebsocket/standalone.py section "Using TLS")
Anonymous
Not applicable
matthias-hahn (Intel) wrote:
Looks like :-)
Thank you lol
The large linux SD image as opposed to the one that came with the board.
Ok thanks
Ok cool thank you for the explanation, I have created a AI bot with voice synthesis and my aim with getting to grips with Eclipse is to integrate the idea of what I created in Arduino IDE with the AI program, I am guessing that I will be able to do this using a speaker attached to the board and hoping to integrate voice recognition.
When I was trying to send https request to my secure web server it was failing using port 443 which is why I asked, I would also like to integrate similar to my web api int the requests which basically uses signed requests and csrf protection.
Using websockets it should also be relatively easy to use either ws: or wss: for a non-secure or secured (over TLS) websocket (see e.g. https://code.google.com/p/pywebsocket/source/browse/trunk/src/mod_pywebs... section "Using TLS")
Cool thank you for taking your time to explain the above I am starting to rebuild my galileo system now with the systems then will tackle the request to the api and then the AI integration.
Matthias_H_Intel
Is your server listening at all on 443? Have you looked with netstat? Which server do you use? Have you enabled https?
Anonymous
Not applicable
I was talking about connecting to my linux VPS yes SSL is enabled, I havent been successful with creating a web server on the Intel Galileo I get the results as mentioned in the post I wrote yesterday about IPs being messed up, just in case you are not following what I meant I have a web api on my VPS which I have a web based admin system I built for people to control their CMS systems, I created a system that can be accessed via the admin system where it receives the information sent from the Galileo using a sketch based on the WebClient every 60 seconds. As the VPS receives the statuses sent from the board it updates the database and also returns back a Json array of settings that are configured by the admin system such as sound alerts on, LED alerts on, sensor detection on etc which in return the board then uses in the sketch I wrote to control the parts on the board.
Anonymous
Not applicable
This is the project I have created in the Arduino IDE
https://www.techbubble.info/LinGalileoSecurity
