Software Archive
Read-only legacy content
17060 Discussions
Intel HAXM 1.1.1 Generating CPU Parity Errors?
Matthew_G_7
Hello, I just installed Android Studio and Intel HAXM 1.1.1 two days ago to start learning Android development. Since then, I've been seeing WHEA-Logger events in my Windows System Log every time I have HAXM actively running an emulated Android device. Is this a bug? Known error? Uncharted waters never seen before...? Everything seems to be working fine, but I started to get quite worried that I had a bad CPU once I saw the logs popping in...Until I was able to tie all the timestamps back to my new usage of HAXM. I have an i5-4460 in a desktop I just built this August. Output from one of the events is below: A corrected hardware error has occurred. Reported by component: Processor Core Error Source: Corrected Machine Check Error Type: Internal parity error Processor APIC ID: 0 ErrorSource 1 ApicId 0 MCABank 0 MciStat 0x90000040000f0005 MciAddr 0x0 MciMisc 0x0 ErrorType 12 TransactionType 256 Participation 256 RequestType 256 MemorIO 256 MemHierarchyLvl 256 Timeout 256 OperationType 256 Channel 256 Length 864
Ionel_M_Intel
Does it happens with latest version of Android Studio + HAXM 1.1.5? Which Windows version do you have?
Matthew_G_7
This was all on Windows 10 Pro x64. I haven't tried HAXM 1.1.5. After noticing the errors I ended up uninstalling HAXM and using my Nexus 6 to test on instead.
