Software Archive
Read-only legacy content
17061 Discussions
Intel MPSS on Ubuntu and Mellanox OFED 2.3
Patrice_H_
We recently installed a PHI on a Dell R720 server running Ubuntu 14.04 with Mellanox OFED 2.3
From https://software.intel.com/en-us/blogs/2014/09/23/working-with-mellanox-infiniband-adapter-on-system-with-intel-xeon-phi-coprocessors at section 2.3, there is instructions to install Mellanox OFED 2.1 to support host IB adapter. I am running Mellanox OFED 2.3.1 and can't take it down to 2.1. The question is: Is it possible to work with Mellanox OFED 2.3.1 on the PHI?
If I follow the instruction in the above mentionned documentation, I will end up in downgrading the Mellanox DAPL package from dapl 2.1.1 to dapl 2.0.42, and I don't expect it to work.
Thanks!
Patrice_H_
Furthermore, I cannot compile ofed-drivers.
ib8-gn01:~/mpss-3.4.3/src# rpmbuild --nodeps --rebuild --define "MOFED 1" ofed-driver-3.4.3-1.src.rpm
Installing ofed-driver-3.4.3-1.src.rpm
warning: user build does not exist - using root
warning: group build does not exist - using root
sh: line 1: package: command not found
sh: line 2: package: command not found
sh: line 3: package: command not found
sh: line 4: package: command not found
sh: line 5: package: command not found
sh: line 6: package: command not found
sh: line 7: package: command not found
error: syntax error in expression
error: /root/rpmbuild/SPECS/intel-mic-ofed-kmod.spec:212: parseExpressionBoolean returns -1
Any clues?
I am running Ubuntu 12 and Mellanox OFED 2.1.
Loc_N_Intel
Hi Patrice,
Depending on the MPSS version, different OFED stacks are supported. If you use MPSS 3.4.x, Intel(R) Xeon Phi(TM) coprocessor supports Mellanox* OFED 2.1/2.2/2.3 . Please take a look at the MPSS Users Guide for MPSS 3.4.3  here  http://registrationcenter.intel.com/irc_nas/6253/MPSS_Users_Guide.pdf
However, we just support SuSE and RHEL officially. If you are installing OFED on Ubuntu, please give it a try and let us know if it is working.
Patrice_H_
Just tried Ubuntu 12.04 with Mellanox OFED 2.1 which produces same result.  The problem stands into Ubuntu compatibility.
