Software Archive
Read-only legacy content
Intel Par. Studio XE licensing
Mark_W_1
Hi!
I am running into an issue with my fortran compiler.  I installed the Intel Parallel Studio XE 2015 Update 1 for Linux using a serial number provided to me by email from Intel after I registered.
The strange thing is that icc works just fine but when I attempted to use ifort it gives me this:
####@####: ~/foo
:> ifort foo.f
Error: A license for FCompL is not available (-5,357).
Make sure that a license file is being used that contains a license
for the requested feature.  If your license requires a license server,
make sure that the server is using the right license file (usually,
this would be the same license file that is being used by this
application), and make sure that you have not changed the license
file since starting the server.
License file(s) used were (in this order):
    1.  Trusted Storage
**  2.  /opt/intel/licenses/l_########.lic
**  3.  /opt/intel/composerxe/licenses
**  4.  /home/####/intel/licenses/l_########.lic
**  5.  /opt/intel/composer_xe_2015.1.133/bin/intel64/../../Licenses
**  6.  /home/####/Licenses
**  7.  /Users/Shared/Library/Application Support/Intel/Licenses
**  8.  /opt/intel/composer_xe_2015.1.133/bin/intel64/*.lic
Please visit http://software.intel.com/sites/support/ if you require technical assistance.
ifort: error #10052: could not checkout FLEXlm license
NOTE: I censored out any identifying information with #.
Devorah_H_Intel
I will help you in private message.
Devorah
subash_G_
Hello
I am using Linux and C language for my programming and suddenly today morning i received this error. I am using icc for compilation.
Error: A license for CCompL is not available now (-97,121).
A connection to the license server could not be made.  You should
make sure that your license daemon process is running: both an
lmgrd process and an INTEL process should be running
if your license limits you to a specified number of licenses in use
at a time.  Also, check to see if the wrong port@host or the wrong
license file is being used, or if the port or hostname in the license
file has changed.
    1.  Trusted Storage
**  2.  /opt/intel/composer_xe_2015.1.133/licenses
**  3.  /opt/intel/licenses/server.lic
**  4.  /home/s16me133/intel/licenses
**  6.  /home/s16me133/Licenses
icc: error #10052: could not checkout FLEXlm license
Can anybody help me how to fix this error. Please kindly inform me. My mail address is
ghimire.subash@hotmail.coom
ghimiresubash37@gmail.com
With regards
Subash Ghimire
Devorah_H_Intel
Hello Subash,
I received your private message and will assist you with the issue.
