Software Archive
Read-only legacy content
17060 Discussions
Intel Parallel Studio XE license
Cayo_G_
Helo,
I have a student license of the Intel Parallel Studio XE Cluster Edition. I use the Intel software tools (Fortran Compiler and MKL) to make some highly advanced quantum chemistry calculations, and for that I use 11 computers. Last year I was able to install the tools in 6 of these 11 computers with no problem. This year my license expired, so I got a new one. This week I got 5 new computers and I am trying to install with the new license without sucess.
I use a linux system, and when I try to install with the new serial number I got an error saying the the serial number is not valid. I am sure that I inserted it correctly.
How should I proceed?
Thak you in advance,
Cayo Gonçalves.
Varsha_M_Intel
Hi Cayo,
Could you send me the serial number which you are trying to activate privately?
Varsha
Varsha_M_Intel
Hi Cayo,
 According to EULA, with named user license you can install on 3 systems. However, You could refer to the article below and check if it could help you.
https://software.intel.com/en-us/articles/using-named-user-licenses-on-a-cluster
Varsha
Cayo_G_
Hello Varsha,
On my account I see only two hosts id's. Is that correct? I used the new serial number only once, so far. The error appeared when I tried to install at two new computers at the same time.
How can I get a floating license? Am I able to change from a named-user to a floating license? Because my case is how the article you mentioned says, I have a cluster that uses the fortran compiler
Cayo
Devorah_H_Intel
Floating license can be purchased. Please refer to this link for information on purchasing:
https://software.intel.com/en-us/intel-parallel-studio-xe/try-buy
