Software Archive
Read-only legacy content
17060 Discussions
Intel RealSense Depth Camera Manager issue.
Abdul_A_
I m using Windows 8.1 OS and I have downloaded the latest version of Intel RealSense Depth Camera Manager : intel_rs_dcm_f200_1.4.27.41944
and Intel RealSense SDK :  intel_rs_sdk_offline_package_r4_6.0.21.6598.
  • Intel(R) RealSense(TM) SDK 6.0.21.6598
  • Intel(R) RealSense(TM) SDK Runtime 6.0.21.6598
  • Intel(R) RealSense(TM) Depth Camera Manager 1.4.27.41944
  • Intel(R) RealSense(TM) 3D Camera 2780
It has installed successfully but after installation its showing this message. Does it really means that RealSense will not work.
Its showing this error in Unity 5.0 :
Unable to initialize all modalities
UnityEngine.Debug:LogError(Object)
RSUnityToolkit.SenseToolkitManager:OnEnable() (at Assets/RSUnityToolkit/Internals/RealSenseInput/SenseToolkitManager.cs:346)
RSUnityToolkit.SenseToolkitManager:Update() (at Assets/RSUnityToolkit/Internals/RealSenseInput/SenseToolkitManager.cs:590)
The installer detected that this system has a certain Windows* Hotfix installed that is known to cause issues with the Intel® RealSense™ 3D Camera. If you see issues using your camera, install all available Windows* Updates for your system.
After installation some of the samples work and some doesn't works, don't know why its happening. Ya i have installed some windows updates recently. There are no Hotfix i have installed recently. Is it only me or anyone else have this issue.? . Any help is appreciated
Xusheng_L_Intel
The screenshot is OK. Which sample you cannot run? Which app show this error message under Unity 5.0?
AKhan57
hi,
Can i use my laptop camera for real sense gesture Application Or I have to buy intel real sense camera?
Colleen_C_Intel
The Intel RealSense SDK is only for use with the Intel RealSense Camera(s).
Abdul_A_
Thanks for the reply,
Right Now none of the samples are working... I tried all the C++, C# and Unity samples but none of them work.
These are the messages i m seeing : Init Failed or Device Failed or PXCSenseManager.Init: PXCM_STATUS_ITEM_UNAVAILABLE(In Unity3d)
Should i install previous version of SDK to overcome this or have i done something wrong. Before Hand Viewer was working fine but now even that is not working and i have uninstalled some of the windows updates too.
eyalfoni
Has anyone made progress on this issue?
I have the same problem, Unity quits immediately when I try to run any of the example programs, however briefly the RealSense camera is turned on and the green LED is lit.
