Software Archive
Read-only legacy content
17060 Discussions
Intel XDK 1878 with some errors
Marcelo_Oliveira
I am using Intel XDK 1878 version, and I am getting some errors on it.
1) When I try to use the built in GPS example (HTML5 + Cordova), the example did not runs with any kind of Android device, but I can run with iOS devices. I am getting the error "Geolocation failed. Please enable GPS in Settings. 1" I think it could be a bug, but I am not finding a solution.
2) Everytime I start my IDE, I receive the error attached here. Anybody knows what is it ? I have already installed the IDE a couple of times, but nothing changes. The error is presented in a popup window. I close it and nothing happens. I don´t know what is the dimension of this error and if I am loosing something in my IDE because of that.
3) Another problem is that I am receiving a message to upgrade my IDE to a new version. But, when I click to upgrade, the IDE closes and nothing happens. When I see the task manager, there are 4 node files running in background, but nothing happens. So, I can´t upgrade to 1912 Version. When I try to download from Intel website, I only get the 1878 version. Are There any place where I can find the new 1912 version to download, besides direct from IDE ?
Marcelo Oliveira.
John_H_Intel2
1. There were a few bugs with 1878 that have been fixed in the new 1912 version which is available.
2. It looks like a low memory or disk space warning. Did you try googling the text of the message to see what comes up?
3. Kill all nw.exe processes and then download/install the update manually.https://software.intel.com/en-us/html5/tools
Marcelo_Oliveira
Hi John,
Answering your questions about second point, I am installing on the default path (suggested by the installer) in my C:\. It has more than 700GB so, it is not hard disk space. My PC is a 3.0 Ghz AMD 6-core, with 8GB of memory and Windows 8.1 Pro.
I don´t think my problem is space. And I did not find any useful answer googling this problem.
I will try to download again and install the new 1912 version.
Besta regards,
Marcelo Oliveira.
