Software Archive
Read-only legacy content
17060 Discussions
Intel XDK 3088 IOS Build failed
Christian_K_
i have updated to Intel XDK 3088 and i can`t build for IOS. The build for Android is ok.
I see this message without a log.
Build Log
  • Building a Cordova 5.4.1 application.
  • Using platform cordova-ios 4.0.1.
  • The application name is "MyFoodDB"
  • The package name is "de.myfooddb"
  • Plugin "cordova-plugin-splashscreen" (2.1.0) installed.
  • Plugin "cordova-plugin-file" (2.1.0) installed.
  • Plugin "cordova-plugin-statusbar" (1.0.0) installed.
  • Plugin "cordova-plugin-network-information" (1.0.1) installed.
  • Plugin "cordova-plugin-dialogs" (1.1.1) installed.
  • Plugin "cordova-plugin-globalization" (1.0.1) installed.
  • Plugin "cordova-plugin-apprate" (1.1.11) installed.
  • Plugin "cordova-plugin-inappbrowser" (1.0.1) installed.
  • Plugin "cordova-plugin-screen-orientation" (1.4.0) installed.
  • Plugin "hu.dpal.phonegap.plugins.UniqueDeviceID" (1.2.0) installed.
  • Plugin "cordova-plugin-device" (1.1.0) installed.
  • Plugin "de.appplant.cordova.common.registerusernotificationsettings" (1.0.1) installed.
  • Plugin "de.appplant.cordova.plugin.local-notification" (0.8.2) installed.
  • Plugin "cordova-plugin-x-toast" (2.4.0) installed.
  • Plugin "phonegap-plugin-barcodescanner" (4.1.0) installed.
Swati_S_Intel1
Please check few things.
1. Please follow this document https://software.intel.com/en-us/xdk/docs/intel-xdk-certificate-management to import your iOS certificate in the XDK. (When you imported your certificate is it possible you had multiple certs and the one you selected is not valid?)
2. Make sure your app ID matches the one provided while generating provisioning profile
3. Try to build one project created from sample app or blank template and see if it builds without error.
4. If above does not work please send you project in a zip file via PM.
PaulF_IntelCorp
Yes, please create a new thread. :)
polaiah_b_
Am trying to build iOS app with cordova cli 5.1.1, build status is failed and build log does not show any clue to understand why build failed. Please could you let me know what to build iOS app.
Build Log
  • Building a Cordova 5.1.1 application.
  • Using platform cordova-ios 3.8.0.
  • The application name is "hello"
  • The package name is "BatsAppBundle"
  • Plugin "cordova-plugin-statusbar" (2.0.0) installed.
  • Plugin "cordova-plugin-camera" (1.2.0) installed.
  • Plugin "cordova-plugin-battery-status" (1.1.1) installed.
PaulF_IntelCorp
Polaiah -- this thread has too many conflicting issues in it. I'm closing it. Please start a new thread and please attach the detailed build log to your new thread (do not paste it into the thread, please attach it as a file using the "Attach Files to Post" link below the editing window. The information you provided in this post is insufficient to help resolve the issue.
