Software Archive
Read-only legacy content
17060 Discussions
Intel XDK 3088 change plugin version
Christian_K_
I have Problems with my Plugins after the Update to Intel XDK 3088.
I see the following message after the Plugin Version change.
Uh oh! target destination "/Users/xxxx/Library/Application Support/XDK/xdk-scratchdir/644e5202-fd16-48d5-86a0-6611ef93bce7/platforms/ios/HelloCordova/Resources/CDVNotification.bundle" already exists
Christian_K_
I have removed manually all plugins and add it again. This solved my problem.
Amrita_C_Intel
Please try these and see what happens if you build in these cases.
  1. Remove all plugins (Core, XDK, 3rd Party) -
  2. Use only Core plugins -
  3. Use only 3rd party plugins -
Christian_K_
This message comes also, when i remove a plugin.
Christian_K_
I remove all plugins in the directory or files and add the plugins again.
Swati_S_Intel1
Please remove the scratch directory at  /Users/xxxx/Library/Application Support/XDK/xdk-scratchdir/ and restart the XDK.
Christian_K_
Maxim_P_1
Hello! I faced same problem when trying import to Intel XDK from Construct 2.
Intel XDK stopped to open projects maked by Construct 2 export at all.
not understand what to do :((
PaulF_IntelCorp
Make a list of the plugins that are part of your project and delete the plugins directory inside of your project. Then add them manually using the plugin manager.
Are you using the new Construct2 export for XDK option?
