Software Archive
Read-only legacy content
17060 Discussions
Intel XDK 3900 - Error Simulate iOS Device
Webert_R_
It's my first time here, I'm asking for help with a problem that occurs when I simulate my app with iOS.
Using Android or Windows in the simulation, no problem occurs. Only with iOS comes a popup window (The Intel XDK encountered a problem and must restart). At the end, I present the complete log.
If in this window I do nothing, I can use the emulated iOS device with no problems.
In the previous version of the Intel XDK 3900, the simulator worked without error.
The error log follows.
Thanks in advance for your support.
xdk:client:[2017-03-18T16:11:51.493Z]: (1489853511493): memlim: 750780416
xdk:client:[2017-03-18T16:11:51.920Z]: (1489853511921): Intel XDK: 3900
xdk:client:[2017-03-18T16:11:51.921Z]: (1489853511921): Platform: win32-ia32 (10.0.10586)
xdk:client:[2017-03-18T16:11:51.922Z]: (1489853511922): System Info:  CPU: 4 X Intel(R) Core(TM) i5 CPU       M 450  @ 2.40GHz Physical Memory: 3949678592
xdk:client:[2017-03-18T16:11:51.922Z]: (1489853511922): NW: 0.18.9
xdk:client:[2017-03-18T16:11:52.081Z]: (1489853512081): Created new theme: base
xdk:client:[2017-03-18T16:11:52.081Z]: (1489853512081): Registered new theme: base
xdk:client:[2017-03-18T16:11:52.081Z]: (1489853512081): Failed to apply theme: Missing CoreStyle.g in context.
xdk:client:[2017-03-18T16:11:52.081Z]: (1489853512081): Current theme is now: base
xdk:client:[2017-03-18T16:11:52.082Z]: (1489853512082): Loading theme from: ../../public/themes/xdk.json
xdk:client:[2017-03-18T16:11:52.082Z]: (1489853512082): Failed to load theme: xdk { Error: Cannot find module '../../public/themes/xdk.json'
    at Function.Module._resolveFilename (module.js:494:15)
    at Function.Module._load (module.js:437:25)
    at Module.require (module.js:522:17)
    at require (internal/module.js:20:19)
    at importThemeByName (C:\Users\Developer Java\AppData\Local\Intel\XDK\xdk\core-modules\public\theme.js:17:1049)
    at Object.init (C:\Users\Developer Java\AppData\Local\Intel\XDK\xdk\core-modules\public\theme.js:17:758) code: 'MODULE_NOT_FOUND' }
xdk:client:[2017-03-18T16:11:52.408Z]: (1489853512408): Starting client process initialization
xdk:client:[2017-03-18T16:11:52.443Z]: (1489853512443): NW Cache is up-to-date.
xdk:server:[2017-03-18T16:11:53.837Z]: (1489853513837): memlim: 750780416
xdk:server:[2017-03-18T16:11:54.262Z]: (1489853514262): Starting server process initialization
xdk:server:[2017-03-18T16:11:54.626Z]: (1489853514626): Trying to start server on default port: 58889
xdk:server:[2017-03-18T16:11:54.643Z]: (1489853514643): Http server started on the standard port 58889
xdk:server:[2017-03-18T16:11:54.644Z]: (1489853514644): Checking proxy settings
xdk:server:[2017-03-18T16:11:54.677Z]: (1489853514677): NW Cache is up-to-date.
xdk:client:[2017-03-18T16:11:56.496Z]: (1489853516496): memmrk:	17486376	29474816
xdk:server:[2017-03-18T16:11:56.982Z]: (1489853516982): Component "core:assert" starting import
xdk:server:[2017-03-18T16:11:56.982Z]: (1489853516982): Component "core:assert" finished initialization
xdk:server:[2017-03-18T16:11:56.982Z]: (1489853516982): Component "core:component-error" starting import
xdk:server:[2017-03-18T16:11:56.982Z]: (1489853516982): Component "core:component-error" finished initialization
xdk:server:[2017-03-18T16:11:56.983Z]: (1489853516983): Component "core:service-error" starting import
xdk:server:[2017-03-18T16:11:56.983Z]: (1489853516983): Component "core:service-error" finished initialization
xdk:server:[2017-03-18T16:11:56.983Z]: (1489853516983): Component "core:buffer" starting import
xdk:server:[2017-03-18T16:11:56.984Z]: (1489853516984): Component "core:buffer" finished initialization
xdk:server:[2017-03-18T16:11:56.984Z]: (1489853516984): Component "core:signaler" starting import
xdk:server:[2017-03-18T16:11:56.987Z]: (1489853516987): Component "core:signaler" finished initialization
xdk:server:[2017-03-18T16:11:56.987Z]: (1489853516987): Component "core:signaler-group" starting import
xdk:server:[2017-03-18T16:11:56.991Z]: (1489853516991): Component "core:signaler-group" finished initialization
xdk:server:[2017-03-18T16:11:56.991Z]: (1489853516991): Component "core:logger" starting import
xdk:server:[2017-03-18T16:11:56.993Z]: (1489853516993): Component "core:logger" finished initialization
xdk:server:[2017-03-18T16:11:56.995Z]: (1489853516995): Component "core:http-request" starting import
xdk:server:[2017-03-18T16:11:56.998Z]: (1489853516998): Component "core:http-request" finished initialization
xdk:server:[2017-03-18T16:11:56.998Z]: (1489853516998): Component "core:database" starting import
xdk:server:[2017-03-18T16:11:57.000Z]: (1489853517000): Component "core:database" finished initialization
xdk:server:[2017-03-18T16:11:57.000Z]: (1489853517000): Component "core:version" starting import
xdk:server:[2017-03-18T16:11:57.000Z]: (1489853517000): Component "core:version" finished initialization
xdk:server:[2017-03-18T16:11:57.000Z]: (1489853517000): Component "core:userfs-name-converter" starting import
xdk:server:[2017-03-18T16:11:57.002Z]: (1489853517002): Component "core:userfs-name-converter" finished initialization
xdk:server:[2017-03-18T16:11:57.002Z]: (1489853517002): Component "core:crash-handler" starting import
xdk:server:[2017-03-18T16:11:57.003Z]: (1489853517003): Component "core:crash-handler" finished initialization
xdk:server:[2017-03-18T16:11:57.003Z]: (1489853517003): Component "core:i18n-support" starting import
xdk:server:[2017-03-18T16:11:57.003Z]: (1489853517003): Component "core:i18n-support" finished initialization
xdk:server:[2017-03-18T16:11:57.003Z]: (1489853517003): Component "core:theme" starting import
xdk:server:[2017-03-18T16:11:57.094Z]: (1489853517094): Component "core:theme" finished initialization
xdk:server:[2017-03-18T16:11:57.094Z]: (1489853517094): Component "core:session-util" starting import
xdk:server:[2017-03-18T16:11:57.097Z]: (1489853517097): Component "core:session-util" finished initialization
xdk:server:[2017-03-18T16:11:57.098Z]: (1489853517098): Component "server:userfs" starting import
xdk:server:[2017-03-18T16:11:57.104Z]: (1489853517104): Component "server:userfs" calling init()
xdk:server:[2017-03-18T16:11:57.189Z]: (1489853517189): Component "server:userfs" finished initialization
xdk:server:[2017-03-18T16:11:57.189Z]: (1489853517189): Component "server:user-profile" starting import
xdk:server:[2017-03-18T16:11:57.191Z]: (1489853517191): Component "server:user-profile" calling init()
xdk:server:[2017-03-18T16:11:57.192Z]: (1489853517192): Component "server:user-profile" finished initialization
xdk:server:[2017-03-18T16:11:57.192Z]: (1489853517192): Component "server:ui-builder" starting import
xdk:server:[2017-03-18T16:11:57.438Z]: (1489853517438): Component "server:ui-builder" calling init()
xdk:server:[2017-03-18T16:11:57.441Z]: (1489853517441): Component "server:ui-builder" finished initialization
xdk:server:[2017-03-18T16:11:57.441Z]: (1489853517441): Component "server:simulator" starting import
xdk:server:[2017-03-18T16:11:58.042Z]: (1489853518042): Component "server:simulator" calling init()
xdk:server:[2017-03-18T16:11:58.043Z]: (1489853518043): Component "server:simulator" finished initialization
xdk:server:[2017-03-18T16:11:58.043Z]: (1489853518043): Component "server:zip-util" starting import
xdk:server:[2017-03-18T16:11:58.045Z]: (1489853518045): Component "server:zip-util" calling init()
xdk:server:[2017-03-18T16:11:58.045Z]: (1489853518046): Component "server:zip-util" finished initialization
xdk:server:[2017-03-18T16:11:58.046Z]: (1489853518046): Component "server:uuid-server" starting import
xdk:server:[2017-03-18T16:11:58.048Z]: (1489853518048): Component "server:uuid-server" calling init()
xdk:server:[2017-03-18T16:11:58.049Z]: (1489853518049): Component "server:uuid-server" finished initialization
xdk:server:[2017-03-18T16:11:58.049Z]: (1489853518049): Component "server:force-download" starting import
xdk:server:[2017-03-18T16:11:58.054Z]: (1489853518054): Component "server:force-download" calling init()
xdk:server:[2017-03-18T16:11:58.055Z]: (1489853518055): Component "server:force-download" finished initialization
xdk:server:[2017-03-18T16:11:58.055Z]: (1489853518055): Component "server:updater" starting import
xdk:server:[2017-03-18T16:11:58.059Z]: (1489853518059): Component "server:updater" calling init()
xdk:server:[2017-03-18T16:11:58.059Z]: (1489853518059): Component "server:updater" finished initialization
xdk:server:[2017-03-18T16:11:58.059Z]: (1489853518059): Component "server:editor-node" starting import
xdk:server:[2017-03-18T16:11:58.096Z]: (1489853518096): Component "server:editor-node" calling init()
xdk:server:[2017-03-18T16:11:58.097Z]: (1489853518097): Component "server:editor-node" waiting for delayed initialization
xdk:server:[2017-03-18T16:11:58.098Z]: (1489853518098): Component "server:cordova" starting import
xdk:server:[2017-03-18T16:11:58.101Z]: (1489853518101): Component "server:cordova" calling init()
xdk:server:[2017-03-18T16:11:58.686Z]: (1489853518686): Component "server:cordova" finished initialization
xdk:server:[2017-03-18T16:11:58.686Z]: (1489853518686): Component "server:plugin-listener" starting import
xdk:server:[2017-03-18T16:11:58.689Z]: (1489853518689): Component "server:plugin-listener" calling init()
xdk:server:[2017-03-18T16:11:58.690Z]: (1489853518690): Component "server:plugin-listener" finished initialization
xdk:server:[2017-03-18T16:11:58.690Z]: (1489853518690): Component "server:git-runner" starting import
xdk:server:[2017-03-18T16:11:58.692Z]: (1489853518692): Component "server:git-runner" calling init()
xdk:server:[2017-03-18T16:11:58.693Z]: (1489853518693): Component "server:git-runner" finished initialization
xdk:server:[2017-03-18T16:11:58.693Z]: (1489853518693): Component "server:api-explorer" starting import
xdk:server:[2017-03-18T16:11:59.223Z]: (1489853519223): Component "server:api-explorer" calling init()
xdk:server:[2017-03-18T16:11:59.224Z]: (1489853519224): Component "server:api-explorer" finished initialization
server:editor-node:[2017-03-18T16:11:59.226Z]: (1489853519226): Starting Brackets node process "C:\Users\Developer Java\AppData\Local\Intel\XDK\bin\node.exe" "C:\Users\Developer Java\AppData\Local\Intel\XDK\bin\node-core"
xdk:server:[2017-03-18T16:11:59.251Z]: (1489853519251): memmrk:	25315736	36159488
server:editor-node:[2017-03-18T16:11:59.936Z]: (1489853519936): Brackets node is running on port 55662
xdk:server:[2017-03-18T16:11:59.938Z]: (1489853519938): Component "server:editor-node" finished delayed initialization
xdk:server:[2017-03-18T16:11:59.941Z]: (1489853519941): Component "server:ui-builder" calling start()
xdk:server:[2017-03-18T16:11:59.949Z]: (1489853519949): Component "server:ui-builder" finished start()
xdk:server:[2017-03-18T16:11:59.949Z]: (1489853519949): Component "server:editor-node" calling start()
xdk:server:[2017-03-18T16:11:59.949Z]: (1489853519949): Component "server:editor-node" finished start()
xdk:server:[2017-03-18T16:11:59.951Z]: (1489853519951): Intel XDK is initialized now
xdk:server:[2017-03-18T16:11:59.952Z]: (1489853519952): Writing to the server data file
xdk:server:[2017-03-18T16:11:59.964Z]: (1489853519964): Wrote server data to "C:\Users\Developer Java\AppData\Local\XDK\User Data\Default\server-data.txt"
xdk:client:[2017-03-18T16:12:00.447Z]: (1489853520448): Successfully read server data file
xdk:client:[2017-03-18T16:12:00.449Z]: (1489853520449): Server data file read. Intents= 15
xdk:client:[2017-03-18T16:12:01.496Z]: (1489853521496): memmrk:	15845732	22134784
xdk:client:[2017-03-18T16:12:01.944Z]: (1489853521944): Component "core:assert" starting import
xdk:client:[2017-03-18T16:12:01.944Z]: (1489853521944): Component "core:assert" finished initialization
xdk:client:[2017-03-18T16:12:01.944Z]: (1489853521944): Component "core:component-error" starting import
xdk:client:[2017-03-18T16:12:01.945Z]: (1489853521945): Component "core:component-error" finished initialization
xdk:client:[2017-03-18T16:12:01.945Z]: (1489853521945): Component "core:service-error" starting import
xdk:client:[2017-03-18T16:12:01.945Z]: (1489853521945): Component "core:service-error" finished initialization
xdk:client:[2017-03-18T16:12:01.945Z]: (1489853521945): Component "core:buffer" starting import
xdk:client:[2017-03-18T16:12:01.945Z]: (1489853521945): Component "core:buffer" finished initialization
xdk:client:[2017-03-18T16:12:01.945Z]: (1489853521945): Component "core:signaler" starting import
xdk:client:[2017-03-18T16:12:01.947Z]: (1489853521947): Component "core:signaler" finished initialization
xdk:client:[2017-03-18T16:12:01.947Z]: (1489853521947): Component "core:signaler-group" starting import
xdk:client:[2017-03-18T16:12:01.951Z]: (1489853521951): Component "core:signaler-group" finished initialization
xdk:client:[2017-03-18T16:12:01.951Z]: (1489853521951): Component "core:logger" starting import
xdk:client:[2017-03-18T16:12:01.954Z]: (1489853521954): Component "core:logger" finished initialization
xdk:client:[2017-03-18T16:12:01.954Z]: (1489853521954): Component "core:http-request" starting import
xdk:client:[2017-03-18T16:12:01.957Z]: (1489853521957): Component "core:http-request" finished initialization
xdk:client:[2017-03-18T16:12:01.957Z]: (1489853521957): Component "core:version" starting import
xdk:client:[2017-03-18T16:12:01.957Z]: (1489853521957): Component "core:version" finished initialization
xdk:client:[2017-03-18T16:12:01.957Z]: (1489853521957): Component "core:exit-notifier" starting import
xdk:client:[2017-03-18T16:12:01.957Z]: (1489853521957): Component "core:exit-notifier" finished initialization
xdk:client:[2017-03-18T16:12:01.957Z]: (1489853521957): Component "core:userfs-name-converter" starting import
xdk:client:[2017-03-18T16:12:01.959Z]: (1489853521959): Component "core:userfs-name-converter" finished initialization
xdk:client:[2017-03-18T16:12:01.959Z]: (1489853521959): Component "core:crash-handler" starting import
xdk:client:[2017-03-18T16:12:01.963Z]: (1489853521963): Component "core:crash-handler" finished initialization
xdk:client:[2017-03-18T16:12:01.963Z]: (1489853521963): Component "core:analytics" starting import
xdk:client:[2017-03-18T16:12:01.963Z]: (1489853521963): Component "core:analytics" finished initialization
xdk:client:[2017-03-18T16:12:01.963Z]: (1489853521963): Component "core:i18n-support" starting import
xdk:client:[2017-03-18T16:12:01.963Z]: (1489853521963): Component "core:i18n-support" finished initialization
xdk:client:[2017-03-18T16:12:01.963Z]: (1489853521963): Component "core:theme" starting import
xdk:client:[2017-03-18T16:12:01.963Z]: (1489853521963): Component "core:theme" finished initialization
xdk:client:[2017-03-18T16:12:01.963Z]: (1489853521963): Component "core:session-util" starting import
xdk:client:[2017-03-18T16:12:01.966Z]: (1489853521966): Component "core:session-util" finished initialization
xdk:client:[2017-03-18T16:12:02.035Z]: (1489853522035): Analytics ID: 0004d713-5188-431a-aa7e-dc644d8fdb13
xdk:client:[2017-03-18T16:12:02.037Z]: (1489853522037): onExit listener 0:
    at Object.exports.onExit (C:\Users\Developer Java\AppData\Local\Intel\XDK\xdk\core-modules\public\exit-notifier.js:17:2339)
    at setupDefaultAnalytics (C:\Users\Developer Java\AppData\Local\Intel\XDK\xdk\core-modules\public\analytics.js:17:1438)
    at C:\Users\Developer Java\AppData\Local\Intel\XDK\xdk\core-modules\public\analytics.js:17:6615
    at C:\Users\Developer Java\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:1229:26
    at _fulfilled (C:\Users\Developer Java\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:834:54)
    at self.promiseDispatch.done (C:\Users\Developer Java\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:863:30)
    at Promise.promise.promiseDispatch (C:\Users\Developer Java\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:796:13)
    at C:\Users\Developer Java\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:604:44
    at runSingle (C:\Users\Developer Java\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:137:13)
xdk:client:[2017-03-18T16:12:02.057Z]: (1489853522057): Component "client:app" starting import
xdk:client:[2017-03-18T16:12:02.058Z]: (1489853522058): Component "client:help-helper" starting import
xdk:client:[2017-03-18T16:12:02.059Z]: (1489853522059): Component "client:nativefs" starting import
xdk:client:[2017-03-18T16:12:02.059Z]: (1489853522059): Component "client:tweets" starting import
xdk:client:[2017-03-18T16:12:02.059Z]: (1489853522059): Component "client:document-manager" starting import
xdk:client:[2017-03-18T16:12:02.060Z]: (1489853522060): Component "client:project-manager" starting import
xdk:client:[2017-03-18T16:12:02.061Z]: (1489853522061): Component "client:project-exporter-config" starting import
xdk:client:[2017-03-18T16:12:02.061Z]: (1489853522061): Component "client:build-validator" starting import
xdk:client:[2017-03-18T16:12:02.061Z]: (1489853522061): Component "client:projects-renderers" starting import
xdk:client:[2017-03-18T16:12:02.061Z]: (1489853522061): Component "client:projects-renderers-jsapp" starting import
xdk:client:[2017-03-18T16:12:02.061Z]: (1489853522061): Component "client:projects-renderers-webapp" starting import
xdk:client:[2017-03-18T16:12:02.061Z]: (1489853522061): Component "client:projects-renderers-iotapp" starting import
xdk:client:[2017-03-18T16:12:02.061Z]: (1489853522061): Component "client:projects-renderers-smarthome" starting import
xdk:client:[2017-03-18T16:12:02.063Z]: (1489853522063): Component "client:test-local-server" starting import
xdk:client:[2017-03-18T16:12:02.063Z]: (1489853522063): Component "client:build-service" starting import
xdk:client:[2017-03-18T16:12:02.064Z]: (1489853522064): Component "client:appcenter-options" starting import
xdk:client:[2017-03-18T16:12:02.064Z]: (1489853522064): Component "client:bower-package-manager" starting import
xdk:client:[2017-03-18T16:12:02.064Z]: (1489853522064): Component "client:iot-tools" starting import
xdk:client:[2017-03-18T16:12:02.064Z]: (1489853522064): Component "client:iot-connection" starting import
xdk:client:[2017-03-18T16:12:02.064Z]: (1489853522064): Component "client:web-services-manager" starting import
xdk:client:[2017-03-18T16:12:02.064Z]: (1489853522064): Component "client:editor" starting import
xdk:client:[2017-03-18T16:12:02.064Z]: (1489853522064): Component "client:backend-services" starting import
xdk:client:[2017-03-18T16:12:02.065Z]: (1489853522065): Component "client:backend-services-ext" starting import
xdk:client:[2017-03-18T16:12:02.065Z]: (1489853522065): Component "client:backend-feeds" starting import
xdk:client:[2017-03-18T16:12:02.065Z]: (1489853522065): Component "client:merged-feed" starting import
xdk:client:[2017-03-18T16:12:02.065Z]: (1489853522065): Component "client:backend-service-utils" starting import
xdk:client:[2017-03-18T16:12:02.065Z]: (1489853522065): Component "client:cert-manager" starting import
xdk:client:[2017-03-18T16:12:02.065Z]: (1489853522065): Component "client:account-settings" starting import
xdk:client:[2017-03-18T16:12:02.066Z]: (1489853522066): Component "client:ui-builder-client" starting import
xdk:client:[2017-03-18T16:12:02.066Z]: (1489853522066): Component "client:project-meta" starting import
xdk:client:[2017-03-18T16:12:02.066Z]: (1489853522066): Component "client:contenttype-registry" starting import
xdk:client:[2017-03-18T16:12:02.066Z]: (1489853522066): Component "client:editor-registry" starting import
xdk:client:[2017-03-18T16:12:02.066Z]: (1489853522066): Component "client:platform-registry" starting import
xdk:client:[2017-03-18T16:12:02.066Z]: (1489853522067): Component "client:projecttype-registry" starting import
xdk:client:[2017-03-18T16:12:02.067Z]: (1489853522067): Component "client:library-registry" starting import
xdk:client:[2017-03-18T16:12:02.067Z]: (1489853522067): Component "client:cordova-registry" starting import
xdk:client:[2017-03-18T16:12:02.067Z]: (1489853522067): Component "client:service-method" starting import
xdk:client:[2017-03-18T16:12:02.067Z]: (1489853522067): Component "client:settings-db" starting import
xdk:client:[2017-03-18T16:12:02.067Z]: (1489853522067): Component "client:dialog-box" starting import
xdk:client:[2017-03-18T16:12:02.067Z]: (1489853522067): Component "client:quick-tour" starting import
xdk:client:[2017-03-18T16:12:02.067Z]: (1489853522067): Component "client:hot-keys" starting import
xdk:client:[2017-03-18T16:12:02.067Z]: (1489853522067): Component "client:persistance" starting import
xdk:client:[2017-03-18T16:12:02.067Z]: (1489853522067): Component "client:tabs" starting import
xdk:client:[2017-03-18T16:12:02.067Z]: (1489853522067): Component "client:hash-utils" starting import
xdk:client:[2017-03-18T16:12:02.068Z]: (1489853522068): Component "client:file-watcher" starting import
xdk:client:[2017-03-18T16:12:02.068Z]: (1489853522068): Component "client:tool-tip" starting import
xdk:client:[2017-03-18T16:12:02.068Z]: (1489853522068): Component "client:cordova" starting import
xdk:client:[2017-03-18T16:12:02.068Z]: (1489853522068): Component "client:settings-ui" starting import
xdk:client:[2017-03-18T16:12:02.068Z]: (1489853522068): Component "client:external-links" starting import
xdk:client:[2017-03-18T16:12:02.068Z]: (1489853522068): Component "client:external-editors-runner" starting import
xdk:client:[2017-03-18T16:12:02.068Z]: (1489853522068): Component "client:upload-manager" starting import
xdk:client:[2017-03-18T16:12:02.068Z]: (1489853522068): Component "client:git-manager" starting import
xdk:client:[2017-03-18T16:12:02.068Z]: (1489853522068): Component "client:new-project-creator" starting import
xdk:client:[2017-03-18T16:12:02.068Z]: (1489853522068): Component "client:variant-manager" starting import
xdk:client:[2017-03-18T16:12:02.068Z]: (1489853522068): Component "client:web-services-explorer" starting import
xdk:client:[2017-03-18T16:12:02.202Z]: (1489853522202): Component "client:help-helper" finished initialization
xdk:client:[2017-03-18T16:12:02.209Z]: (1489853522209): Component "client:nativefs" finished initialization
xdk:client:[2017-03-18T16:12:02.311Z]: (1489853522311): Component "client:build-service" calling init()
xdk:client:[2017-03-18T16:12:02.312Z]: (1489853522312): Component "client:build-service" finished initialization
xdk:client:[2017-03-18T16:12:02.358Z]: (1489853522358): Component "client:backend-services" calling init()
xdk:client:[2017-03-18T16:12:02.359Z]: (1489853522359): Component "client:backend-services" finished initialization
xdk:client:[2017-03-18T16:12:02.363Z]: (1489853522363): Component "client:backend-services-ext" calling init()
xdk:client:[2017-03-18T16:12:02.363Z]: (1489853522363): Component "client:backend-services-ext" waiting for delayed initialization
xdk:client:[2017-03-18T16:12:02.366Z]: (1489853522366): Component "client:backend-services-ext" finished delayed initialization
xdk:client:[2017-03-18T16:12:02.369Z]: (1489853522369): Component "client:backend-feeds" calling init()
xdk:client:[2017-03-18T16:12:02.370Z]: (1489853522370): Component "client:backend-feeds" finished initialization
xdk:client:[2017-03-18T16:12:02.373Z]: (1489853522373): Component "client:merged-feed" finished initialization
xdk:client:[2017-03-18T16:12:02.376Z]: (1489853522376): Component "client:backend-service-utils" finished initialization
xdk:client:[2017-03-18T16:12:02.387Z]: (1489853522387): Component "client:project-meta" calling init()
xdk:client:[2017-03-18T16:12:02.387Z]: (1489853522387): Component "client:project-meta" finished initialization
xdk:client:[2017-03-18T16:12:02.406Z]: (1489853522406): Component "client:service-method" finished initialization
xdk:client:[2017-03-18T16:12:02.424Z]: (1489853522424): Component "client:settings-db" calling init()
xdk:client:[2017-03-18T16:12:02.424Z]: (1489853522424): Component "client:settings-db" waiting for delayed initialization
xdk:client:[2017-03-18T16:12:02.434Z]: (1489853522434): Component "client:persistance" calling init()
xdk:client:[2017-03-18T16:12:02.435Z]: (1489853522435): Component "client:persistance" waiting for delayed initialization
xdk:client:[2017-03-18T16:12:02.439Z]: (1489853522439): Component "client:file-watcher" calling init()
xdk:client:[2017-03-18T16:12:02.439Z]: (1489853522439): Component "client:file-watcher" finished initialization
xdk:client:[2017-03-18T16:12:02.629Z]: (1489853522629): Component "client:cordova" calling init()
xdk:client:[2017-03-18T16:12:02.630Z]: (1489853522630): Component "client:cordova" waiting for delayed initialization
xdk:client:[2017-03-18T16:12:02.631Z]: (1489853522631): Component "client:external-links" finished initialization
xdk:client:[2017-03-18T16:12:02.632Z]: (1489853522632): Component "client:external-editors-runner" calling init()
xdk:client:[2017-03-18T16:12:02.633Z]: (1489853522633): Component "client:external-editors-runner" finished initialization
xdk:client:[2017-03-18T16:12:02.639Z]: (1489853522639): Component "client:upload-manager" calling init()
xdk:client:[2017-03-18T16:12:02.640Z]: (1489853522640): Component "client:upload-manager" finished initialization
xdk:client:[2017-03-18T16:12:02.642Z]: (1489853522642): Component "client:git-manager" calling init()
client:git-manager:[2017-03-18T16:12:02.642Z]: (1489853522642): git path =  C:\Users\Developer Java\AppData\Local\Intel\XDK\bin\git\bin\git.exe
xdk:client:[2017-03-18T16:12:02.642Z]: (1489853522642): Component "client:git-manager" waiting for delayed initialization
xdk:client:[2017-03-18T16:12:02.645Z]: (1489853522645): Component "client:new-project-creator" calling init()
xdk:client:[2017-03-18T16:12:02.646Z]: (1489853522646): Component "client:new-project-creator" finished initialization
xdk:client:[2017-03-18T16:12:02.647Z]: (1489853522647): Component "client:variant-manager" finished initialization
xdk:client:[2017-03-18T16:12:02.662Z]: (1489853522662): Component "client:build-validator" finished initialization
xdk:client:[2017-03-18T16:12:02.871Z]: (1489853522871): Component "client:hot-keys" calling init()
xdk:client:[2017-03-18T16:12:02.872Z]: (1489853522872): Component "client:hot-keys" finished initialization
xdk:client:[2017-03-18T16:12:02.883Z]: (1489853522883): Component "client:ui-builder-client" calling init()
xdk:client:[2017-03-18T16:12:02.883Z]: (1489853522883): Component "client:ui-builder-client" finished initialization
xdk:client:[2017-03-18T16:12:02.889Z]: (1489853522889): Component "client:dialog-box" finished initialization
xdk:client:[2017-03-18T16:12:02.915Z]: (1489853522915): Component "client:tool-tip" finished initialization
xdk:client:[2017-03-18T16:12:02.921Z]: (1489853522921): Component "client:settings-ui" finished initialization
xdk:client:[2017-03-18T16:12:02.928Z]: (1489853522928): Component "client:tweets" finished initialization
xdk:client:[2017-03-18T16:12:02.937Z]: (1489853522937): Component "client:document-manager" calling init()
xdk:client:[2017-03-18T16:12:02.938Z]: (1489853522938): Component "client:document-manager" finished initialization
xdk:client:[2017-03-18T16:12:03.250Z]: (1489853523250): Component "client:test-local-server" calling init()
xdk:client:[2017-03-18T16:12:03.437Z]: (1489853523437): Component "client:test-local-server" finished initialization
xdk:client:[2017-03-18T16:12:03.442Z]: (1489853523442): Component "client:appcenter-options" calling init()
xdk:client:[2017-03-18T16:12:03.443Z]: (1489853523443): Component "client:appcenter-options" waiting for delayed initialization
xdk:client:[2017-03-18T16:12:03.448Z]: (1489853523448): Component "client:tabs" finished initialization
xdk:client:[2017-03-18T16:12:03.464Z]: (1489853523464): Component "client:app" calling init()
xdk:client:[2017-03-18T16:12:03.494Z]: (1489853523494): Component "client:app" finished initialization
xdk:client:[2017-03-18T16:12:03.593Z]: (1489853523593): Component "client:cert-manager" finished initialization
xdk:client:[2017-03-18T16:12:03.595Z]: (1489853523595): Component "client:navbar" starting import
xdk:client:[2017-03-18T16:12:03.596Z]: (1489853523596): Component "client:project-exporter" starting import
xdk:client:[2017-03-18T16:12:03.596Z]: (1489853523596): Component "client:projects-tab" starting import
xdk:client:[2017-03-18T16:12:03.596Z]: (1489853523597): Component "client:test-tab" starting import
xdk:client:[2017-03-18T16:12:03.597Z]: (1489853523597): Component "client:simulator" starting import
xdk:client:[2017-03-18T16:12:03.597Z]: (1489853523597): Component "client:build-tab" starting import
xdk:client:[2017-03-18T16:12:03.597Z]: (1489853523597): Component "client:bower-client" starting import
xdk:client:[2017-03-18T16:12:03.597Z]: (1489853523597): Component "client:editor-tab" starting import
xdk:client:[2017-03-18T16:12:03.597Z]: (1489853523597): Component "client:account" starting import
xdk:client:[2017-03-18T16:12:03.597Z]: (1489853523597): Component "client:project-selector" starting import
xdk:client:[2017-03-18T16:12:03.597Z]: (1489853523597): Component "client:publish-tab" starting import
xdk:client:[2017-03-18T16:12:03.628Z]: (1489853523628): Component "client:contenttype-registry" calling init()
xdk:client:[2017-03-18T16:12:03.636Z]: (1489853523636): Component "client:contenttype-registry" finished initialization
xdk:client:[2017-03-18T16:12:03.642Z]: (1489853523643): Component "client:editor-registry" finished initialization
xdk:client:[2017-03-18T16:12:03.696Z]: (1489853523696): Component "client:library-registry" calling init()
xdk:client:[2017-03-18T16:12:03.696Z]: (1489853523696): Component "client:library-registry" finished initialization
xdk:client:[2017-03-18T16:12:03.773Z]: (1489853523773): Component "client:hash-utils" finished initialization
xdk:client:[2017-03-18T16:12:03.780Z]: (1489853523780): Component "client:web-services-explorer" calling init()
xdk:client:[2017-03-18T16:12:03.781Z]: (1489853523781): Component "client:web-services-explorer" finished initialization
xdk:client:[2017-03-18T16:12:03.909Z]: (1489853523909): Component "client:iot-tools" calling init()
xdk:client:[2017-03-18T16:12:03.910Z]: (1489853523910): Component "client:iot-tools" finished initialization
xdk:client:[2017-03-18T16:12:04.141Z]: (1489853524141): Component "client:cordova-registry" calling init()
xdk:server:[2017-03-18T16:12:04.267Z]: (1489853524267): memmrk:	24336340	36487168
xdk:client:[2017-03-18T16:12:04.142Z]: (1489853524142): Component "client:cordova-registry" waiting for delayed initialization
xdk:client:[2017-03-18T16:12:04.153Z]: (1489853524153): Component "client:quick-tour" calling init()
xdk:client:[2017-03-18T16:12:04.153Z]: (1489853524153): Component "client:quick-tour" finished initialization
xdk:client:[2017-03-18T16:12:04.163Z]: (1489853524163): Component "client:project-exporter-config" calling init()
xdk:client:[2017-03-18T16:12:04.163Z]: (1489853524163): Component "client:project-exporter-config" finished initialization
xdk:client:[2017-03-18T16:12:04.175Z]: (1489853524175): Component "client:projects-renderers" calling init()
xdk:client:[2017-03-18T16:12:04.176Z]: (1489853524176): Component "client:projects-renderers" waiting for delayed initialization
xdk:client:[2017-03-18T16:12:04.176Z]: (1489853524176): Component "client:projects-renderers-iotapp" calling init()
xdk:client:[2017-03-18T16:12:04.176Z]: (1489853524176): Component "client:projects-renderers-iotapp" finished initialization
xdk:client:[2017-03-18T16:12:04.185Z]: (1489853524185): Component "client:projects-renderers-smarthome" calling init()
xdk:client:[2017-03-18T16:12:04.186Z]: (1489853524186): Component "client:projects-renderers-smarthome" finished initialization
xdk:client:[2017-03-18T16:12:04.318Z]: (1489853524318): Component "client:web-services-manager" calling init()
xdk:client:[2017-03-18T16:12:04.319Z]: (1489853524319): Component "client:web-services-manager" finished initialization
xdk:client:[2017-03-18T16:12:04.328Z]: (1489853524328): Component "client:settings-db" finished delayed initialization
client:git-manager:[2017-03-18T16:12:04.335Z]: (1489853524335): Custom Git Client Path is C:\Users\Developer Java\AppData\Local\Intel\XDK\bin\git\bin\git.exe
client:git-manager:[2017-03-18T16:12:04.335Z]: (1489853524335): Auto-Proxy setting is true
xdk:client:[2017-03-18T16:12:04.336Z]: (1489853524336): Component "client:persistance" finished delayed initialization
xdk:client:[2017-03-18T16:12:04.363Z]: (1489853524363): Component "client:account-settings" calling init()
xdk:client:[2017-03-18T16:12:04.363Z]: (1489853524363): Component "client:account-settings" waiting for delayed initialization
xdk:client:[2017-03-18T16:12:04.392Z]: (1489853524392): Component "client:platform-registry" calling init()
xdk:client:[2017-03-18T16:12:04.394Z]: (1489853524394): Component "client:platform-registry" finished initialization
xdk:client:[2017-03-18T16:12:04.440Z]: (1489853524440): Component "client:bower-package-manager" calling init()
xdk:client:[2017-03-18T16:12:04.441Z]: (1489853524441): Component "client:bower-package-manager" waiting for delayed initialization
xdk:client:[2017-03-18T16:12:04.445Z]: (1489853524445): Component "client:bower-package-manager" finished delayed initialization
xdk:client:[2017-03-18T16:12:04.451Z]: (1489853524451): Component "client:editor" calling init()
xdk:client:[2017-03-18T16:12:04.452Z]: (1489853524452): Component "client:editor" finished initialization
xdk:client:[2017-03-18T16:12:04.452Z]: (1489853524452): Component "client:editor-tab" getting UI region for "develop"
xdk:client:[2017-03-18T16:12:04.453Z]: (1489853524453): Component "client:editor-tab" calling init()
xdk:client:[2017-03-18T16:12:04.584Z]: (1489853524584): Component "client:editor-tab" waiting for delayed initialization
xdk:client:[2017-03-18T16:12:04.596Z]: (1489853524596): Component "client:git-manager" finished delayed initialization
xdk:client:[2017-03-18T16:12:04.813Z]: (1489853524813): Component "client:cordova" finished delayed initialization
xdk:client:[2017-03-18T16:12:04.819Z]: (1489853524819): Component "client:project-exporter" getting UI region for "exporter"
xdk:client:[2017-03-18T16:12:04.820Z]: (1489853524820): Component "client:project-exporter" calling init()
xdk:client:[2017-03-18T16:12:04.820Z]: (1489853524820): Component "client:project-exporter" finished initialization
xdk:client:[2017-03-18T16:12:04.841Z]: (1489853524841): Component "client:test-tab" getting UI region for "test"
xdk:client:[2017-03-18T16:12:04.842Z]: (1489853524842): Component "client:test-tab" calling init()
xdk:client:[2017-03-18T16:12:04.842Z]: (1489853524842): Component "client:test-tab" waiting for delayed initialization
xdk:client:[2017-03-18T16:12:04.860Z]: (1489853524860): Component "client:account" getting UI region for "account"
xdk:client:[2017-03-18T16:12:04.860Z]: (1489853524860): Component "client:account" calling init()
xdk:client:[2017-03-18T16:12:04.880Z]: (1489853524880): Component "client:account" finished initialization
xdk:client:[2017-03-18T16:12:04.886Z]: (1489853524886): Component "client:project-selector" getting UI region for "project-selector"
xdk:client:[2017-03-18T16:12:04.887Z]: (1489853524887): Component "client:project-selector" calling init()
xdk:client:[2017-03-18T16:12:04.887Z]: (1489853524887): Component "client:project-selector" finished initialization
xdk:client:[2017-03-18T16:12:05.188Z]: (1489853525188): Component "client:projects-renderers-webapp" calling init()
xdk:client:[2017-03-18T16:12:05.189Z]: (1489853525189): Component "client:projects-renderers-webapp" finished initialization
xdk:client:[2017-03-18T16:12:05.202Z]: (1489853525202): Component "client:projects-renderers-jsapp" calling init()
xdk:client:[2017-03-18T16:12:05.204Z]: (1489853525204): Component "client:projects-renderers-jsapp" finished initialization
xdk:client:[2017-03-18T16:12:05.205Z]: (1489853525205): Component "client:projects-tab" getting UI region for "project"
xdk:client:[2017-03-18T16:12:05.205Z]: (1489853525205): Component "client:projects-tab" calling init()
xdk:client:[2017-03-18T16:12:05.207Z]: (1489853525207): Component "client:projects-tab" waiting for delayed initialization
xdk:client:[2017-03-18T16:12:05.380Z]: (1489853525380): Component "client:projects-tab" finished delayed initialization
xdk:client:[2017-03-18T16:12:05.380Z]: (1489853525380): Component "client:projects-list" starting import
xdk:client:[2017-03-18T16:12:05.380Z]: (1489853525380): Component "client:projects-info" starting import
xdk:client:[2017-03-18T16:12:05.381Z]: (1489853525381): Component "client:projects-create-list" starting import
xdk:client:[2017-03-18T16:12:05.381Z]: (1489853525381): Component "client:projects-create-info" starting import
xdk:client:[2017-03-18T16:12:05.390Z]: (1489853525390): Component "client:navbar" getting UI region for "navbar-common"
xdk:client:[2017-03-18T16:12:05.390Z]: (1489853525390): Component "client:navbar" calling init()
client:navbar:[2017-03-18T16:12:05.392Z]: (1489853525392): navbar options: {"common":{"servicesVersion":"release-2017-ww5"},"updatePollingInterval":1800}
xdk:client:[2017-03-18T16:12:05.392Z]: (1489853525392): Component "client:navbar" finished initialization
xdk:client:[2017-03-18T16:12:05.482Z]: (1489853525482): Component "client:account-settings" finished delayed initialization
xdk:client:[2017-03-18T16:12:05.498Z]: (1489853525498): Component "client:build-tab" getting UI region for "build"
xdk:client:[2017-03-18T16:12:05.498Z]: (1489853525498): Component "client:build-tab" calling init()
xdk:client:[2017-03-18T16:12:05.518Z]: (1489853525518): Component "client:build-tab" waiting for delayed initialization
xdk:client:[2017-03-18T16:12:05.520Z]: (1489853525520): Component "client:build-tab" finished delayed initialization
xdk:client:[2017-03-18T16:12:05.528Z]: (1489853525528): Component "client:projecttype-registry" calling init()
xdk:client:[2017-03-18T16:12:05.528Z]: (1489853525528): Component "client:projecttype-registry" waiting for delayed initialization
xdk:client:[2017-03-18T16:12:06.346Z]: (1489853526346): Component "client:iot-connection" calling init()
xdk:client:[2017-03-18T16:12:06.347Z]: (1489853526347): Component "client:iot-connection" finished initialization
xdk:client:[2017-03-18T16:12:06.513Z]: (1489853526513): Component "client:projecttype-registry" finished delayed initialization
client:appcenter-options:[2017-03-18T16:12:06.583Z]: (1489853526583): Fetch Status: 1, Message: Feched latest appcenter-options info because network is available.
xdk:client:[2017-03-18T16:12:06.585Z]: (1489853526585): Component "client:appcenter-options" finished delayed initialization
xdk:client:[2017-03-18T16:12:06.623Z]: (1489853526624): Component "client:projects-renderers" finished delayed initialization
xdk:client:[2017-03-18T16:12:06.624Z]: (1489853526624): Component "client:test-tab" finished delayed initialization
xdk:client:[2017-03-18T16:12:06.643Z]: (1489853526643): Component "client:publish-tab" getting UI region for "publish"
xdk:client:[2017-03-18T16:12:06.643Z]: (1489853526643): Component "client:publish-tab" calling init()
xdk:client:[2017-03-18T16:12:06.714Z]: (1489853526714): Component "client:publish-tab" finished initialization
xdk:client:[2017-03-18T16:12:06.725Z]: (1489853526725): Component "client:cordova-registry" finished delayed initialization
xdk:client:[2017-03-18T16:12:06.739Z]: (1489853526739): memmrk:	27194804	34754560
xdk:client:[2017-03-18T16:12:06.811Z]: (1489853526811): Component "client:bower-client" getting UI region for "deps-manager"
xdk:client:[2017-03-18T16:12:06.811Z]: (1489853526811): Component "client:bower-client" calling init()
xdk:client:[2017-03-18T16:12:06.816Z]: (1489853526816): Component "client:bower-client" finished initialization
xdk:client:[2017-03-18T16:12:06.826Z]: (1489853526826): Component "client:projects-list" getting UI region for "existing-list"
xdk:client:[2017-03-18T16:12:06.826Z]: (1489853526826): Component "client:projects-list" calling init()
xdk:client:[2017-03-18T16:12:06.833Z]: (1489853526833): Component "client:projects-list" finished initialization
xdk:client:[2017-03-18T16:12:06.838Z]: (1489853526838): Component "client:projects-info" getting UI region for "existing-info"
xdk:client:[2017-03-18T16:12:06.839Z]: (1489853526839): Component "client:projects-info" calling init()
xdk:client:[2017-03-18T16:12:06.840Z]: (1489853526840): Component "client:projects-info" finished initialization
xdk:client:[2017-03-18T16:12:07.112Z]: (1489853527112): Component "client:projects-create-info" getting UI region for "create-info"
xdk:client:[2017-03-18T16:12:07.113Z]: (1489853527113): Component "client:projects-create-info" calling init()
xdk:client:[2017-03-18T16:12:07.114Z]: (1489853527114): Component "client:projects-create-info" finished initialization
xdk:client:[2017-03-18T16:12:07.325Z]: (1489853527325): Component "client:projects-create-list" getting UI region for "create-list"
xdk:client:[2017-03-18T16:12:07.325Z]: (1489853527325): Component "client:projects-create-list" calling init()
xdk:client:[2017-03-18T16:12:07.325Z]: (1489853527325): Component "client:projects-create-list" finished initialization
xdk:client:[2017-03-18T16:12:07.341Z]: (1489853527341): Component "client:simulator" getting UI region for "simulate"
xdk:client:[2017-03-18T16:12:07.341Z]: (1489853527341): Component "client:simulator" calling init()
xdk:client:[2017-03-18T16:12:07.346Z]: (1489853527346): Component "client:simulator" waiting for delayed initialization
xdk:client:[2017-03-18T16:12:07.354Z]: (1489853527354): Component "client:project-manager" calling init()
xdk:client:[2017-03-18T16:12:07.356Z]: (1489853527357): onExitRequest listener 1:
    at Object.exports.onExitRequest (C:\Users\Developer Java\AppData\Local\Intel\XDK\xdk\core-modules\public\exit-notifier.js:17:2170)
    at C:\Users\Developer Java\AppData\Local\Intel\XDK\xdk\core-modules\private\main.js:17:9177
xdk:client:[2017-03-18T16:12:07.357Z]: (1489853527357): Component "client:project-manager" waiting for delayed initialization
xdk:client:[2017-03-18T16:12:07.367Z]: (1489853527367): Component "client:simulator" finished delayed initialization
xdk:client:[2017-03-18T16:12:07.387Z]: (1489853527387): Component "client:project-manager" finished delayed initialization
xdk:server:[2017-03-18T16:12:09.268Z]: (1489853529268): memmrk:	22590036	28098560
xdk:client:[2017-03-18T16:12:12.133Z]: (1489853532133): memmrk:	40301008	48099328
xdk:client:[2017-03-18T16:12:14.088Z]: (1489853534088): onExitRequest listener 2:
xdk:server:[2017-03-18T16:12:14.269Z]: (1489853534269): memmrk:	23187568	28098560
xdk:client:[2017-03-18T16:12:16.496Z]: (1489853536496): memmrk:	47264448	69070848
xdk:client:[2017-03-18T16:12:17.090Z]: (1489853537090): Component "client:editor-tab" finished delayed initialization
xdk:client:[2017-03-18T16:12:17.095Z]: (1489853537095): Component "client:app" calling start()
xdk:client:[2017-03-18T16:12:17.129Z]: (1489853537129): Component "client:app" finished start()
xdk:client:[2017-03-18T16:12:17.129Z]: (1489853537129): Component "client:navbar" calling start()
xdk:client:[2017-03-18T16:12:17.166Z]: (1489853537166): Component "client:navbar" finished start()
xdk:client:[2017-03-18T16:12:17.166Z]: (1489853537166): Component "client:project-manager" calling start()
xdk:client:[2017-03-18T16:12:17.177Z]: (1489853537177): Component "client:project-manager" finished start()
xdk:client:[2017-03-18T16:12:17.177Z]: (1489853537177): Component "client:project-exporter-config" calling start()
xdk:client:[2017-03-18T16:12:17.179Z]: (1489853537179): Component "client:project-exporter-config" finished start()
xdk:client:[2017-03-18T16:12:17.179Z]: (1489853537179): Component "client:projects-tab" calling start()
xdk:client:[2017-03-18T16:12:17.199Z]: (1489853537199): Component "client:projects-tab" finished start()
xdk:client:[2017-03-18T16:12:17.199Z]: (1489853537199): Component "client:projects-list" calling start()
xdk:client:[2017-03-18T16:12:17.207Z]: (1489853537207): Component "client:projects-list" finished start()
xdk:client:[2017-03-18T16:12:17.207Z]: (1489853537207): Component "client:projects-info" calling start()
xdk:client:[2017-03-18T16:12:17.210Z]: (1489853537210): Component "client:projects-info" finished start()
xdk:client:[2017-03-18T16:12:17.210Z]: (1489853537210): Component "client:projects-create-list" calling start()
xdk:client:[2017-03-18T16:12:17.294Z]: (1489853537294): Component "client:projects-create-list" finished start()
xdk:client:[2017-03-18T16:12:17.294Z]: (1489853537294): Component "client:projects-create-info" calling start()
xdk:client:[2017-03-18T16:12:17.304Z]: (1489853537304): Component "client:projects-create-info" finished start()
xdk:client:[2017-03-18T16:12:17.304Z]: (1489853537304): Component "client:test-tab" calling start()
xdk:client:[2017-03-18T16:12:17.320Z]: (1489853537320): Component "client:test-tab" finished start()
xdk:client:[2017-03-18T16:12:17.320Z]: (1489853537320): Component "client:test-local-server" calling start()
xdk:client:[2017-03-18T16:12:17.320Z]: (1489853537320): Component "client:test-local-server" finished start()
xdk:client:[2017-03-18T16:12:17.320Z]: (1489853537320): Component "client:simulator" calling start()
xdk:client:[2017-03-18T16:12:17.386Z]: (1489853537386): Component "client:simulator" finished start()
xdk:client:[2017-03-18T16:12:17.386Z]: (1489853537386): Component "client:build-tab" calling start()
client:build-tab:[2017-03-18T16:12:17.397Z]: (1489853537397): [updatePageState] Set State: PAGE_STATE_INITIALIZING
xdk:client:[2017-03-18T16:12:17.406Z]: (1489853537406): Component "client:build-tab" finished start()
xdk:client:[2017-03-18T16:12:17.406Z]: (1489853537406): Component "client:bower-client" calling start()
xdk:client:[2017-03-18T16:12:17.407Z]: (1489853537407): Component "client:bower-client" finished start()
xdk:client:[2017-03-18T16:12:17.407Z]: (1489853537407): Component "client:iot-tools" calling start()
xdk:client:[2017-03-18T16:12:17.871Z]: (1489853537871): Component "client:iot-tools" finished start()
xdk:client:[2017-03-18T16:12:17.871Z]: (1489853537871): Component "client:iot-connection" calling start()
xdk:client:[2017-03-18T16:12:18.031Z]: (1489853538031): Component "client:iot-connection" finished start()
xdk:client:[2017-03-18T16:12:18.031Z]: (1489853538031): Component "client:editor" calling start()
xdk:client:[2017-03-18T16:12:18.031Z]: (1489853538031): Component "client:editor" finished start()
xdk:client:[2017-03-18T16:12:18.032Z]: (1489853538032): Component "client:editor-tab" calling start()
xdk:client:[2017-03-18T16:12:18.042Z]: (1489853538042): Component "client:editor-tab" finished start()
xdk:client:[2017-03-18T16:12:18.043Z]: (1489853538043): Component "client:account" calling start()
xdk:client:[2017-03-18T16:12:18.044Z]: (1489853538044): Component "client:account" finished start()
xdk:client:[2017-03-18T16:12:18.044Z]: (1489853538044): Component "client:project-selector" calling start()
xdk:client:[2017-03-18T16:12:18.046Z]: (1489853538046): Component "client:project-selector" finished start()
xdk:client:[2017-03-18T16:12:18.046Z]: (1489853538046): Component "client:ui-builder-client" calling start()
xdk:client:[2017-03-18T16:12:18.049Z]: (1489853538049): Component "client:ui-builder-client" finished start()
xdk:client:[2017-03-18T16:12:18.049Z]: (1489853538049): Component "client:project-meta" calling start()
xdk:client:[2017-03-18T16:12:18.049Z]: (1489853538049): Component "client:project-meta" finished start()
xdk:client:[2017-03-18T16:12:18.049Z]: (1489853538049): Component "client:cordova-registry" calling start()
xdk:client:[2017-03-18T16:12:18.049Z]: (1489853538050): Component "client:cordova-registry" finished start()
xdk:client:[2017-03-18T16:12:18.050Z]: (1489853538050): Component "client:quick-tour" calling start()
xdk:client:[2017-03-18T16:12:18.050Z]: (1489853538050): Component "client:quick-tour" finished start()
xdk:client:[2017-03-18T16:12:18.050Z]: (1489853538050): Component "client:hot-keys" calling start()
xdk:client:[2017-03-18T16:12:18.051Z]: (1489853538052): Component "client:hot-keys" finished start()
xdk:client:[2017-03-18T16:12:18.052Z]: (1489853538052): Component "client:persistance" calling start()
xdk:client:[2017-03-18T16:12:18.083Z]: (1489853538083): onExit listener 3:
    at resumeClientInit (C:\Users\Developer Java\AppData\Local\Intel\XDK\xdk\core-modules\private\main.js:17:12181)
    at C:\Users\Developer Java\AppData\Local\Intel\XDK\xdk\core-modules\private\main.js:17:1734
    at flush (C:\Users\Developer Java\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:125:13)
xdk:client:[2017-03-18T16:12:18.084Z]: (1489853538084): Component "client:persistance" finished start()
xdk:client:[2017-03-18T16:12:18.084Z]: (1489853538084): Component "client:file-watcher" calling start()
xdk:client:[2017-03-18T16:12:18.087Z]: (1489853538087): Component "client:file-watcher" finished start()
xdk:client:[2017-03-18T16:12:18.095Z]: (1489853538095): Component "client:cordova" calling start()
xdk:client:[2017-03-18T16:12:18.095Z]: (1489853538096): Component "client:cordova" finished start()
xdk:client:[2017-03-18T16:12:18.096Z]: (1489853538096): Component "client:external-editors-runner" calling start()
xdk:client:[2017-03-18T16:12:18.099Z]: (1489853538099): Component "client:external-editors-runner" finished start()
xdk:client:[2017-03-18T16:12:18.099Z]: (1489853538099): Component "client:upload-manager" calling start()
xdk:client:[2017-03-18T16:12:18.100Z]: (1489853538101): Component "client:upload-manager" finished start()
xdk:client:[2017-03-18T16:12:18.101Z]: (1489853538101): Component "client:publish-tab" calling start()
xdk:client:[2017-03-18T16:12:18.115Z]: (1489853538115): onExitRequest listener 4:
xdk:client:[2017-03-18T16:12:18.231Z]: (1489853538231): Component "client:publish-tab" finished start()
xdk:client:[2017-03-18T16:12:18.231Z]: (1489853538231): Component "client:web-services-explorer" calling start()
xdk:client:[2017-03-18T16:12:18.231Z]: (1489853538231): Component "client:web-services-explorer" finished start()
xdk:client:[2017-03-18T16:12:18.232Z]: (1489853538232): Intel XDK is initialized now
client:build-tab:[2017-03-18T16:12:18.522Z]: (1489853538522): [updatePageStatus] Set Status: PAGE_STATUS_ERROR
xdk:server:[2017-03-18T16:12:19.275Z]: (1489853539275): memmrk:	23205632	28098560
client:cordova:[2017-03-18T16:12:19.577Z]: (1489853539577): { xdkProjectStatus: 'all_same',
  pluginStatus:
   { 'cordova-plugin-device': 'same',
     'cordova-plugin-dialogs': 'same',
     'cordova-plugin-screen-orientation': 'same',
     'cordova-plugin-splashscreen': 'same',
     'cordova-plugin-statusbar': 'same' } }
client:build-tab:[2017-03-18T16:12:21.175Z]: (1489853541175): [updatePageState] Set State: PAGE_STATE_INITIALIZING
bower-package-manager:[2017-03-18T16:12:22.546Z]: (1489853542546): Bower packages not found { Error: An error ocurred while trying to check for the file "C:/Users/Developer Java/Documents/Intel XDK/Tank11/bower.json".
    at Object.createError (file:///C:/Users/Developer%20Java/AppData/Local/Intel/XDK/xdk/brackets/b/extensions/default/BracketsBower/src/utils/ErrorUtils.js:65:21)
    at file:///C:/Users/Developer%20Java/AppData/Local/Intel/XDK/xdk/brackets/b/extensions/default/BracketsBower/src/utils/FileUtils.js:66:38
    at FileSystem.eval (/filesystem/FileSystem.js:617:21)
    at eval (/filesystem/impls/xdk/XDKFileSystem.js:239:17)
    at eval (/filesystem/impls/xdk/XDKFileSystem.js:215:17)
  code: 22,
  message: 'An error ocurred while trying to check for the file "C:/Users/Developer Java/Documents/Intel XDK/Tank11/bower.json".',
  originalMessage: 'NotFound',
  originalError: null }
bower-package-manager:[2017-03-18T16:12:22.559Z]: (1489853542559): Bower packages not found { Error: An error ocurred while trying to check for the file "C:/Users/Developer Java/Documents/Intel XDK/Tank11/bower.json".
  code: 22,
xdk:server:[2017-03-18T16:12:24.295Z]: (1489853544295): memmrk:	23448436	28098560
xdk:server:[2017-03-18T16:12:29.296Z]: (1489853549296): memmrk:	23581292	28098560
client:publish-tab:[2017-03-18T16:12:32.215Z]: (1489853552215): Stores data feed has been successfully loaded.
client:build-tab:[2017-03-18T16:12:32.309Z]: (1489853552309): [updatePageStatus] Set Status: PAGE_STATUS_ERROR
xdk:client:[2017-03-18T16:12:32.459Z]: (1489853552459): memmrk:	53440100	68022272
client:build-tab:[2017-03-18T16:12:33.541Z]: (1489853553541): [updatePageState] Set State: PAGE_STATE_INITIALIZING
server:updater:[2017-03-18T16:12:33.791Z]: (1489853553791): Check for update: https://appcenter.html5tools-software.intel.com/api/v3.0/redirect/updates/xdk/
client:navbar:[2017-03-18T16:12:33.774Z]: (1489853553774): pollForUpdates called
xdk:server:[2017-03-18T16:12:34.318Z]: (1489853554318): memmrk:	23759892	28098560
client:build-tab:[2017-03-18T16:12:36.567Z]: (1489853556567): [refreshPage] projectId YbxF7gxJMiUOeBFq9pOaKqO3bJY4jx0LTRnGkJm-0D0
client:build-tab:[2017-03-18T16:12:36.568Z]: (1489853556568): [updatePageState] Set State: PAGE_STATE_LOADING
client:build-tab:[2017-03-18T16:12:36.599Z]: (1489853556599): [getBuildTargets] Getting available targets for project YbxF7gxJMiUOeBFq9pOaKqO3bJY4jx0LTRnGkJm-0D0
client:build-tab:[2017-03-18T16:12:36.604Z]: (1489853556604): [refreshProjectInfo] Getting project info.
client:build-tab:[2017-03-18T16:12:36.632Z]: (1489853556632): [refreshBuildAssetsDate] Getting latest upload date for project files
client:navbar:[2017-03-18T16:12:36.697Z]: (1489853556697): polling up-to-date
xdk:client:[2017-03-18T16:12:36.900Z]: (1489853556900): memmrk:	56255956	69070848
xdk:server:[2017-03-18T16:12:39.319Z]: (1489853559319): memmrk:	23806440	28098560
xdk:client:[2017-03-18T16:12:43.394Z]: (1489853563394): memmrk:	51240976	77459456
xdk:server:[2017-03-18T16:12:44.347Z]: (1489853564347): memmrk:	23907468	28098560
xdk:client:[2017-03-18T16:12:46.954Z]: (1489853566954): memmrk:	48622784	71168000
client:build-tab:[2017-03-18T16:12:47.987Z]: (1489853567987): [getBuildTargets] Targets retrieved for project YbxF7gxJMiUOeBFq9pOaKqO3bJY4jx0LTRnGkJm-0D0
client:build-tab:[2017-03-18T16:12:48.078Z]: (1489853568078): [updatePageStatus] Set Status: PAGE_STATUS_READY
client:build-tab:[2017-03-18T16:12:48.080Z]: (1489853568080): [updatePageState] Set State: PAGE_STATE_IDLE
client:build-tab:[2017-03-18T16:12:48.087Z]: (1489853568087): [startUpdateStatusProcess] Starting build pulling process. Project: YbxF7gxJMiUOeBFq9pOaKqO3bJY4jx0LTRnGkJm-0D0
client:build-tab:[2017-03-18T16:12:48.087Z]: (1489853568087): [updatePageState] Set State: PAGE_STATE_UPDATING
client:build-service:[2017-03-18T16:12:48.092Z]: (1489853568092): [startUpdateStatusProcess] Starting polling. Project: YbxF7gxJMiUOeBFq9pOaKqO3bJY4jx0LTRnGkJm-0D0
xdk:server:[2017-03-18T16:12:49.347Z]: (1489853569347): memmrk:	23741624	30195712
client:build-tab:[2017-03-18T16:12:51.472Z]: (1489853571472): [refreshBuildAssetsDate] latest upload date null
xdk:client:[2017-03-18T16:12:51.955Z]: (1489853571955): memmrk:	51548504	71168000
client:build-service:[2017-03-18T16:12:52.191Z]: (1489853572191): [startUpdateStatusProcess] Polling process has finished.
client:build-tab:[2017-03-18T16:12:52.191Z]: (1489853572191): [updatePageState] Set State: PAGE_BUILDING
client:build-tab:[2017-03-18T16:12:52.199Z]: (1489853572199): [updatePageStatus] Set Status: PAGE_STATUS_READY
client:build-tab:[2017-03-18T16:12:52.199Z]: (1489853572199): [updatePageState] Set State: PAGE_STATE_IDLE
xdk:server:[2017-03-18T16:12:54.348Z]: (1489853574348): memmrk:	23925496	30195712
xdk:client:[2017-03-18T16:12:56.954Z]: (1489853576954): memmrk:	48330732	55439360
xdk:server:[2017-03-18T16:12:59.349Z]: (1489853579349): memmrk:	24028740	30195712
xdk:client:[2017-03-18T16:13:01.954Z]: (1489853581954): memmrk:	48340948	55439360
xdk:server:[2017-03-18T16:13:04.349Z]: (1489853584349): memmrk:	23695584	30195712
xdk:client:[2017-03-18T16:13:06.953Z]: (1489853586954): memmrk:	48345760	55439360
xdk:server:[2017-03-18T16:13:09.350Z]: (1489853589350): memmrk:	23795668	30195712
xdk:client:[2017-03-18T16:13:11.954Z]: (1489853591954): memmrk:	48349428	55439360
xdk:server:[2017-03-18T16:13:14.350Z]: (1489853594350): memmrk:	23895736	30195712
xdk:client:[2017-03-18T16:13:16.954Z]: (1489853596954): memmrk:	48353096	55439360
xdk:server:[2017-03-18T16:13:19.350Z]: (1489853599350): memmrk:	23995804	30195712
xdk:client:[2017-03-18T16:13:21.954Z]: (1489853601954): memmrk:	48356764	55439360
xdk:server:[2017-03-18T16:13:24.351Z]: (1489853604351): memmrk:	24095872	30195712
xdk:client:[2017-03-18T16:13:26.954Z]: (1489853606954): memmrk:	48360432	55439360
xdk:server:[2017-03-18T16:13:29.353Z]: (1489853609353): memmrk:	24195956	30195712
xdk:client:[2017-03-18T16:13:31.954Z]: (1489853611954): memmrk:	48364100	55439360
xdk:server:[2017-03-18T16:13:34.354Z]: (1489853614354): memmrk:	23898260	30195712
xdk:client:[2017-03-18T16:13:36.495Z]: (1489853616495): memmrk:	50778844	58585088
xdk:server:[2017-03-18T16:13:39.355Z]: (1489853619355): memmrk:	24119860	30195712
xdk:client:[2017-03-18T16:13:41.497Z]: (1489853621497): memmrk:	53548888	69070848
uib-client:[2017-03-18T16:13:43.323Z]: (1489853623323): gradeHTMLFile 4 /C/Users/Developer Java/Documents/Intel XDK/Tank11/www/index.html
uib-client:[2017-03-18T16:13:43.329Z]: (1489853623330): gradeHTMLFile 4 /C/Users/Developer Java/Documents/Intel XDK/Tank11/www/index.html
uib-server:[2017-03-18T16:13:43.448Z]: (1489853623448): less_cmd  C:\Users\Developer Java\Documents\Intel XDK\Tank11\www\css\index\index_main.less > /C/Users/Developer Java/Documents/Intel XDK/Tank11/www/css/index_main.less.css
xdk:server:[2017-03-18T16:13:44.359Z]: (1489853624359): memmrk:	25737416	35438592
uib-server:[2017-03-18T16:13:46.354Z]: (1489853626354): error:  500 target directory does not exist
/C/Users/Developer Java/Documents/Intel XDK/Tank11/www/icon-fonts/
uib-server:[2017-03-18T16:13:47.639Z]: (1489853627639): error:  500 target directory does not exist
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/layout/ver
uib-server:[2017-03-18T16:13:47.646Z]: (1489853627646): error:  500 target directory does not exist
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/media/ver
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/widgets/ver
xdk:client:[2017-03-18T16:13:47.968Z]: (1489853627968): memmrk:	69133332	90042368
xdk:server:[2017-03-18T16:13:49.368Z]: (1489853629368): memmrk:	28674688	53264384
uib-server:[2017-03-18T16:13:49.381Z]: (1489853629381): error:  500 target directory does not exist
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/layout/card/ver
uib-server:[2017-03-18T16:13:49.400Z]: (1489853629400): error:  500 target directory does not exist
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/layout/card_columns/ver
uib-server:[2017-03-18T16:13:49.401Z]: (1489853629401): error:  500 target directory does not exist
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/layout/card_grid/ver
uib-server:[2017-03-18T16:13:49.488Z]: (1489853629488): error:  500 target directory does not exist
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/layout/row/ver
uib-server:[2017-03-18T16:13:49.511Z]: (1489853629511): error:  500 target directory does not exist
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/media/button_bar/ver
uib-server:[2017-03-18T16:13:49.515Z]: (1489853629515): error:  500 target directory does not exist
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/media/camera/ver
uib-server:[2017-03-18T16:13:49.544Z]: (1489853629544): error:  500 target directory does not exist
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/media/chart/ver
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/media/chartjs/ver
uib-server:[2017-03-18T16:13:49.545Z]: (1489853629545): error:  500 target directory does not exist
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/media/file_input/ver
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/media/google_maps/ver
uib-server:[2017-03-18T16:13:49.551Z]: (1489853629551): error:  500 target directory does not exist
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/media/graphic_button/ver
uib-server:[2017-03-18T16:13:49.572Z]: (1489853629572): error:  500 target directory does not exist
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/media/iframe/ver
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/media/image_gallery/ver
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/media/img/ver
uib-server:[2017-03-18T16:13:49.573Z]: (1489853629573): error:  500 target directory does not exist
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/media/sprite_button/ver
uib-server:[2017-03-18T16:13:49.606Z]: (1489853629606): error:  500 target directory does not exist
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/media/video/ver
uib-server:[2017-03-18T16:13:49.607Z]: (1489853629607): error:  500 target directory does not exist
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/media/vimeo/ver
uib-server:[2017-03-18T16:13:49.608Z]: (1489853629608): error:  500 target directory does not exist
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/media/yandex_maps/ver
uib-server:[2017-03-18T16:13:49.609Z]: (1489853629609): error:  500 target directory does not exist
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/media/youtube/ver
uib-server:[2017-03-18T16:13:49.625Z]: (1489853629625): error:  500 target directory does not exist
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/widgets/admob/ver
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/widgets/console/ver
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/widgets/justgage/ver
uib-server:[2017-03-18T16:13:49.626Z]: (1489853629626): error:  500 target directory does not exist
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/widgets/webrtc-connect-to/ver
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/widgets/webrtc-login/ver
uib-server:[2017-03-18T16:13:49.646Z]: (1489853629646): error:  500 target directory does not exist
/C/Users/Developer Java/AppData/Local/Intel/XDK/xdk/components/server/ui-builder/ui-builder_repo/resources/toolbar/widgets/webrtc-video/ver
uib-client:[2017-03-18T16:13:52.141Z]: (1489853632141): src_path /C/Users/Developer Java/Documents/Intel XDK/Tank11/www
xdk:client:[2017-03-18T16:13:52.182Z]: (1489853632182): memmrk:	74302712	95285248
xdk:server:[2017-03-18T16:13:54.382Z]: (1489853634382): memmrk:	33916668	53264384
xdk:client:[2017-03-18T16:13:58.726Z]: (1489853638726): memmrk:	81885380	91090944
xdk:server:[2017-03-18T16:13:59.382Z]: (1489853639383): memmrk:	22784584	29147136
xdk:client:[2017-03-18T16:14:02.415Z]: (1489853642415): memmrk:	68207860	82702336
xdk:server:[2017-03-18T16:14:04.383Z]: (1489853644383): memmrk:	22882960	29147136
xdk:client:[2017-03-18T16:14:06.954Z]: (1489853646954): memmrk:	68238020	82702336
xdk:server:[2017-03-18T16:14:09.385Z]: (1489853649385): memmrk:	23006288	29147136
xdk:client:[2017-03-18T16:14:11.954Z]: (1489853651954): memmrk:	64473344	73265152
xdk:server:[2017-03-18T16:14:14.385Z]: (1489853654385): memmrk:	23126632	29147136
xdk:client:[2017-03-18T16:14:16.955Z]: (1489853656955): memmrk:	64483560	73265152
xdk:server:[2017-03-18T16:14:19.385Z]: (1489853659385): memmrk:	23226112	29147136
xdk:client:[2017-03-18T16:14:21.954Z]: (1489853661954): memmrk:	64488372	73265152
xdk:server:[2017-03-18T16:14:24.387Z]: (1489853664387): memmrk:	23325592	29147136
xdk:client:[2017-03-18T16:14:26.954Z]: (1489853666954): memmrk:	64492040	73265152
xdk:server:[2017-03-18T16:14:29.387Z]: (1489853669387): memmrk:	23435272	29147136
xdk:client:[2017-03-18T16:14:31.954Z]: (1489853671954): memmrk:	64495708	73265152
xdk:server:[2017-03-18T16:14:34.387Z]: (1489853674387): memmrk:	23532432	29147136
xdk:client:[2017-03-18T16:14:36.953Z]: (1489853676953): memmrk:	64499376	73265152
xdk:server:[2017-03-18T16:14:39.387Z]: (1489853679387): memmrk:	23631912	29147136
xdk:client:[2017-03-18T16:14:41.954Z]: (1489853681954): memmrk:	64503044	73265152
xdk:server:[2017-03-18T16:14:44.388Z]: (1489853684388): memmrk:	23731392	29147136
xdk:client:[2017-03-18T16:14:46.954Z]: (1489853686954): memmrk:	64506712	73265152
xdk:server:[2017-03-18T16:14:49.389Z]: (1489853689389): memmrk:	22888284	29147136
xdk:client:[2017-03-18T16:14:51.953Z]: (1489853691953): memmrk:	64510380	73265152
xdk:server:[2017-03-18T16:14:54.390Z]: (1489853694390): memmrk:	22987764	29147136
xdk:client:[2017-03-18T16:14:56.954Z]: (1489853696954): memmrk:	64514048	73265152
xdk:server:[2017-03-18T16:14:59.390Z]: (1489853699390): memmrk:	23087244	29147136
xdk:client:[2017-03-18T16:15:01.954Z]: (1489853701954): memmrk:	64517716	73265152
xdk:server:[2017-03-18T16:15:04.391Z]: (1489853704391): memmrk:	23186724	29147136
xdk:client:[2017-03-18T16:15:06.954Z]: (1489853706954): memmrk:	64521384	73265152
xdk:server:[2017-03-18T16:15:09.391Z]: (1489853709391): memmrk:	23286204	29147136
xdk:client:[2017-03-18T16:15:11.954Z]: (1489853711954): memmrk:	64525052	73265152
xdk:server:[2017-03-18T16:15:14.392Z]: (1489853714392): memmrk:	22864556	29147136
xdk:client:[2017-03-18T16:15:16.954Z]: (1489853716954): memmrk:	64528720	73265152
xdk:server:[2017-03-18T16:15:19.393Z]: (1489853719393): memmrk:	22965408	29147136
xdk:client:[2017-03-18T16:15:21.954Z]: (1489853721954): memmrk:	64532388	73265152
xdk:server:[2017-03-18T16:15:24.393Z]: (1489853724393): memmrk:	23064896	29147136
xdk:client:[2017-03-18T16:15:26.954Z]: (1489853726954): memmrk:	64536056	73265152
xdk:server:[2017-03-18T16:15:29.393Z]: (1489853729393): memmrk:	23162064	29147136
xdk:client:[2017-03-18T16:15:31.954Z]: (1489853731954): memmrk:	64539724	73265152
xdk:server:[2017-03-18T16:15:34.394Z]: (1489853734394): memmrk:	23261552	29147136
xdk:client:[2017-03-18T16:15:36.954Z]: (1489853736954): memmrk:	64543392	73265152
xdk:server:[2017-03-18T16:15:39.394Z]: (1489853739394): memmrk:	23361040	29147136
xdk:client:[2017-03-18T16:15:41.954Z]: (1489853741954): memmrk:	64547060	73265152
xdk:server:[2017-03-18T16:15:44.394Z]: (1489853744394): memmrk:	22939368	29147136
xdk:client:[2017-03-18T16:15:46.953Z]: (1489853746953): memmrk:	64550728	73265152
xdk:server:[2017-03-18T16:15:49.393Z]: (1489853749393): memmrk:	23038856	29147136
xdk:client:[2017-03-18T16:15:51.953Z]: (1489853751953): memmrk:	64554396	73265152
xdk:server:[2017-03-18T16:15:54.394Z]: (1489853754394): memmrk:	23138344	29147136
xdk:client:[2017-03-18T16:15:56.952Z]: (1489853756952): memmrk:	64558064	73265152
xdk:server:[2017-03-18T16:15:59.395Z]: (1489853759395): memmrk:	23237832	29147136
xdk:client:[2017-03-18T16:16:01.952Z]: (1489853761952): memmrk:	64561732	73265152
xdk:server:[2017-03-18T16:16:04.396Z]: (1489853764396): memmrk:	23337320	29147136
xdk:client:[2017-03-18T16:16:06.953Z]: (1489853766953): memmrk:	64565400	73265152
xdk:server:[2017-03-18T16:16:09.397Z]: (1489853769397): memmrk:	22914604	29147136
xdk:client:[2017-03-18T16:16:11.952Z]: (1489853771952): memmrk:	64569068	73265152
xdk:server:[2017-03-18T16:16:14.397Z]: (1489853774397): memmrk:	23014092	29147136
xdk:client:[2017-03-18T16:16:16.953Z]: (1489853776953): memmrk:	64572736	73265152
xdk:server:[2017-03-18T16:16:19.398Z]: (1489853779398): memmrk:	23113580	29147136
xdk:client:[2017-03-18T16:16:21.952Z]: (1489853781952): memmrk:	64576404	73265152
xdk:server:[2017-03-18T16:16:24.398Z]: (1489853784398): memmrk:	23210748	29147136
xdk:client:[2017-03-18T16:16:26.953Z]: (1489853786953): memmrk:	64580072	73265152
xdk:server:[2017-03-18T16:16:29.398Z]: (1489853789398): memmrk:	23310236	29147136
xdk:client:[2017-03-18T16:16:31.952Z]: (1489853791952): memmrk:	64583740	73265152
xdk:server:[2017-03-18T16:16:34.399Z]: (1489853794399): memmrk:	22888768	29147136
xdk:client:[2017-03-18T16:16:36.953Z]: (1489853796953): memmrk:	64587408	73265152
xdk:server:[2017-03-18T16:16:39.400Z]: (1489853799400): memmrk:	22988256	29147136
xdk:client:[2017-03-18T16:16:41.953Z]: (1489853801953): memmrk:	64591076	73265152
xdk:server:[2017-03-18T16:16:44.400Z]: (1489853804400): memmrk:	23087744	29147136
xdk:client:[2017-03-18T16:16:46.952Z]: (1489853806952): memmrk:	64594744	73265152
xdk:server:[2017-03-18T16:16:49.401Z]: (1489853809401): memmrk:	23187232	29147136
xdk:client:[2017-03-18T16:16:51.953Z]: (1489853811953): memmrk:	64598412	73265152
xdk:server:[2017-03-18T16:16:54.402Z]: (1489853814402): memmrk:	23286720	29147136
xdk:client:[2017-03-18T16:16:56.953Z]: (1489853816953): memmrk:	64602080	73265152
xdk:server:[2017-03-18T16:16:59.403Z]: (1489853819403): memmrk:	23386208	29147136
xdk:client:[2017-03-18T16:17:01.953Z]: (1489853821953): memmrk:	64605748	73265152
xdk:server:[2017-03-18T16:17:04.403Z]: (1489853824403): memmrk:	22966700	29147136
xdk:client:[2017-03-18T16:17:06.954Z]: (1489853826954): memmrk:	64609416	73265152
xdk:server:[2017-03-18T16:17:09.405Z]: (1489853829405): memmrk:	23066188	29147136
xdk:client:[2017-03-18T16:17:11.953Z]: (1489853831953): memmrk:	64613084	73265152
xdk:server:[2017-03-18T16:17:14.405Z]: (1489853834405): memmrk:	23165676	29147136
xdk:client:[2017-03-18T16:17:16.954Z]: (1489853836954): memmrk:	64616752	73265152
xdk:server:[2017-03-18T16:17:19.406Z]: (1489853839406): memmrk:	23265164	29147136
xdk:client:[2017-03-18T16:17:21.953Z]: (1489853841953): memmrk:	64734524	73265152
xdk:server:[2017-03-18T16:17:24.406Z]: (1489853844406): memmrk:	23364652	29147136
xdk:client:[2017-03-18T16:17:26.954Z]: (1489853846954): memmrk:	64738192	73265152
xdk:server:[2017-03-18T16:17:29.407Z]: (1489853849407): memmrk:	22941900	29147136
xdk:client:[2017-03-18T16:17:31.953Z]: (1489853851953): memmrk:	64741860	73265152
xdk:server:[2017-03-18T16:17:34.407Z]: (1489853854407): memmrk:	23041388	29147136
xdk:client:[2017-03-18T16:17:36.954Z]: (1489853856954): memmrk:	64745528	73265152
xdk:server:[2017-03-18T16:17:39.409Z]: (1489853859409): memmrk:	23140876	29147136
xdk:client:[2017-03-18T16:17:41.953Z]: (1489853861953): memmrk:	64749196	73265152
xdk:server:[2017-03-18T16:17:44.408Z]: (1489853864408): memmrk:	23240364	29147136
xdk:client:[2017-03-18T16:17:46.954Z]: (1489853866954): memmrk:	64752864	73265152
xdk:server:[2017-03-18T16:17:49.409Z]: (1489853869409): memmrk:	23339884	29147136
xdk:client:[2017-03-18T16:17:51.953Z]: (1489853871953): memmrk:	64756532	73265152
xdk:server:[2017-03-18T16:17:54.408Z]: (1489853874408): memmrk:	22917392	29147136
xdk:client:[2017-03-18T16:17:56.954Z]: (1489853876954): memmrk:	64760200	73265152
xdk:server:[2017-03-18T16:17:59.408Z]: (1489853879408): memmrk:	23016880	29147136
xdk:client:[2017-03-18T16:18:01.954Z]: (1489853881954): memmrk:	64763868	73265152
xdk:server:[2017-03-18T16:18:04.408Z]: (1489853884408): memmrk:	23116368	29147136
xdk:client:[2017-03-18T16:18:06.954Z]: (1489853886954): memmrk:	64767536	73265152
xdk:server:[2017-03-18T16:18:09.408Z]: (1489853889408): memmrk:	23215856	29147136
xdk:client:[2017-03-18T16:18:11.953Z]: (1489853891953): memmrk:	64771204	73265152
xdk:server:[2017-03-18T16:18:14.408Z]: (1489853894408): memmrk:	23315344	29147136
xdk:client:[2017-03-18T16:18:16.954Z]: (1489853896954): memmrk:	64774872	73265152
xdk:server:[2017-03-18T16:18:19.409Z]: (1489853899409): memmrk:	23414832	29147136
xdk:client:[2017-03-18T16:18:21.954Z]: (1489853901954): memmrk:	64778540	73265152
xdk:server:[2017-03-18T16:18:24.410Z]: (1489853904410): memmrk:	22997856	29147136
xdk:client:[2017-03-18T16:18:26.954Z]: (1489853906954): memmrk:	64782208	73265152
xdk:server:[2017-03-18T16:18:29.410Z]: (1489853909410): memmrk:	23098596	29147136
xdk:client:[2017-03-18T16:18:31.954Z]: (1489853911954): memmrk:	64785876	73265152
xdk:server:[2017-03-18T16:18:34.411Z]: (1489853914411): memmrk:	23195044	29147136
xdk:client:[2017-03-18T16:18:36.954Z]: (1489853916954): memmrk:	64789544	73265152
xdk:server:[2017-03-18T16:18:39.411Z]: (1489853919411): memmrk:	23289248	29147136
xdk:client:[2017-03-18T16:18:41.955Z]: (1489853921955): memmrk:	64793212	73265152
xdk:server:[2017-03-18T16:18:44.412Z]: (1489853924412): memmrk:	23411596	29147136
xdk:client:[2017-03-18T16:18:46.953Z]: (1489853926953): memmrk:	64796880	73265152
xdk:server:[2017-03-18T16:18:49.412Z]: (1489853929412): memmrk:	22989664	29147136
xdk:client:[2017-03-18T16:18:51.954Z]: (1489853931954): memmrk:	64800548	73265152
xdk:server:[2017-03-18T16:18:54.413Z]: (1489853934413): memmrk:	23085952	29147136
xdk:client:[2017-03-18T16:18:56.953Z]: (1489853936953): memmrk:	64804248	73265152
xdk:server:[2017-03-18T16:18:59.413Z]: (1489853939413): memmrk:	23190468	29147136
xdk:client:[2017-03-18T16:19:01.953Z]: (1489853941953): memmrk:	64807916	73265152
xdk:server:[2017-03-18T16:19:04.414Z]: (1489853944414): memmrk:	23286756	29147136
xdk:client:[2017-03-18T16:19:06.953Z]: (1489853946953): memmrk:	64811584	73265152
xdk:server:[2017-03-18T16:19:09.414Z]: (1489853949414): memmrk:	23383044	29147136
xdk:client:[2017-03-18T16:19:11.953Z]: (1489853951953): memmrk:	64815252	73265152
xdk:server:[2017-03-18T16:19:14.414Z]: (1489853954414): memmrk:	23479332	29147136
xdk:client:[2017-03-18T16:19:16.952Z]: (1489853956952): memmrk:	64818920	73265152
xdk:server:[2017-03-18T16:19:19.414Z]: (1489853959414): memmrk:	23071344	29147136
xdk:client:[2017-03-18T16:19:21.953Z]: (1489853961953): memmrk:	64822588	73265152
xdk:server:[2017-03-18T16:19:24.415Z]: (1489853964415): memmrk:	23186964	29147136
xdk:client:[2017-03-18T16:19:26.952Z]: (1489853966952): memmrk:	64826256	73265152
xdk:server:[2017-03-18T16:19:29.415Z]: (1489853969415): memmrk:	23283252	29147136
xdk:client:[2017-03-18T16:19:31.953Z]: (1489853971953): memmrk:	64829924	73265152
xdk:server:[2017-03-18T16:19:34.416Z]: (1489853974416): memmrk:	23379540	29147136
xdk:client:[2017-03-18T16:19:36.952Z]: (1489853976952): memmrk:	64833592	73265152
xdk:server:[2017-03-18T16:19:39.416Z]: (1489853979416): memmrk:	23473584	29147136
xdk:client:[2017-03-18T16:19:41.953Z]: (1489853981953): memmrk:	64837260	73265152
xdk:server:[2017-03-18T16:19:44.417Z]: (1489853984417): memmrk:	23062776	29147136
xdk:client:[2017-03-18T16:19:46.952Z]: (1489853986952): memmrk:	64840928	73265152
xdk:server:[2017-03-18T16:19:49.416Z]: (1489853989416): memmrk:	23159064	29147136
xdk:client:[2017-03-18T16:19:51.953Z]: (1489853991953): memmrk:	64844596	73265152
xdk:server:[2017-03-18T16:19:54.417Z]: (1489853994417): memmrk:	23255352	29147136
xdk:client:[2017-03-18T16:19:56.953Z]: (1489853996953): memmrk:	64848264	73265152
xdk:server:[2017-03-18T16:19:59.417Z]: (1489853999417): memmrk:	23351640	29147136
xdk:client:[2017-03-18T16:20:01.953Z]: (1489854001953): memmrk:	64851932	73265152
xdk:server:[2017-03-18T16:20:04.417Z]: (1489854004417): memmrk:	23447928	29147136
xdk:client:[2017-03-18T16:20:06.953Z]: (1489854006953): memmrk:	64855600	73265152
xdk:server:[2017-03-18T16:20:09.417Z]: (1489854009417): memmrk:	23024944	29147136
xdk:client:[2017-03-18T16:20:11.954Z]: (1489854011954): memmrk:	64859268	73265152
xdk:server:[2017-03-18T16:20:14.417Z]: (1489854014417): memmrk:	23121232	29147136
xdk:client:[2017-03-18T16:20:16.953Z]: (1489854016953): memmrk:	64875288	73265152
xdk:server:[2017-03-18T16:20:19.417Z]: (1489854019417): memmrk:	23217520	29147136
xdk:client:[2017-03-18T16:20:21.954Z]: (1489854021954): memmrk:	64880896	73265152
xdk:server:[2017-03-18T16:20:24.417Z]: (1489854024417): memmrk:	23313808	29147136
xdk:client:[2017-03-18T16:20:26.953Z]: (1489854026953): memmrk:	64884524	73265152
xdk:server:[2017-03-18T16:20:29.418Z]: (1489854029418): memmrk:	23410096	29147136
xdk:client:[2017-03-18T16:20:31.954Z]: (1489854031954): memmrk:	64888152	73265152
xdk:server:[2017-03-18T16:20:34.418Z]: (1489854034418): memmrk:	23506384	29147136
xdk:client:[2017-03-18T16:20:36.953Z]: (1489854036953): memmrk:	64891780	73265152
xdk:server:[2017-03-18T16:20:39.418Z]: (1489854039418): memmrk:	23080656	29147136
xdk:client:[2017-03-18T16:20:41.496Z]: (1489854041497): memmrk:	66774476	75362304
xdk:server:[2017-03-18T16:20:44.419Z]: (1489854044419): memmrk:	23332384	29147136
xdk:client:[2017-03-18T16:20:46.496Z]: (1489854046496): memmrk:	67078936	77459456
xdk:server:[2017-03-18T16:20:49.421Z]: (1489854049421): memmrk:	23429672	29147136
xdk:client:[2017-03-18T16:20:51.496Z]: (1489854051496): memmrk:	68187708	77459456
xdk:server:[2017-03-18T16:20:54.422Z]: (1489854054422): memmrk:	23351916	29147136
client:simulator:[2017-03-18T16:20:54.805Z]: (1489854054805): Starting the simulator
xdk:client:[2017-03-18T16:20:56.496Z]: (1489854056496): memmrk:	70070840	79556608
xdk:client:[2017-03-18T16:21:01.496Z]: (1489854061496): memmrk:	69331416	78508032
xdk:client:[2017-03-18T16:21:06.495Z]: (1489854066495): memmrk:	69399260	78508032
xdk:client:[2017-03-18T16:21:11.496Z]: (1489854071496): memmrk:	69455792	78508032
xdk:client:[2017-03-18T16:21:16.497Z]: (1489854076497): memmrk:	69522096	78508032
xdk:server:[2017-03-18T16:21:21.052Z]: (1489854081052): memmrk:	33822160	42815488
xdk:client:[2017-03-18T16:21:21.496Z]: (1489854081496): memmrk:	69578624	78508032
xdk:client:[2017-03-18T16:21:26.495Z]: (1489854086495): memmrk:	69641220	78508032
xdk:client:[2017-03-18T16:21:31.496Z]: (1489854091496): memmrk:	69705200	78508032
xdk:client:[2017-03-18T16:21:36.495Z]: (1489854096495): memmrk:	69777256	78508032
xdk:client:[2017-03-18T16:21:41.496Z]: (1489854101496): memmrk:	70296352	78508032
xdk:client:[2017-03-18T16:21:46.495Z]: (1489854106495): memmrk:	69815368	78508032
xdk:client:[2017-03-18T16:21:51.496Z]: (1489854111496): memmrk:	69875812	78508032
xdk:client:[2017-03-18T16:21:56.496Z]: (1489854116496): memmrk:	69395108	78508032
xdk:client:[2017-03-18T16:22:01.495Z]: (1489854121496): memmrk:	69455500	78508032
xdk:client:[2017-03-18T16:22:06.496Z]: (1489854126496): memmrk:	69513492	78508032
xdk:client:[2017-03-18T16:22:11.496Z]: (1489854131496): memmrk:	69601440	78508032
xdk:client:[2017-03-18T16:22:16.495Z]: (1489854136495): memmrk:	69658160	78508032
xdk:client:[2017-03-18T16:22:21.494Z]: (1489854141494): memmrk:	69710412	78508032
xdk:client:[2017-03-18T16:22:26.495Z]: (1489854146495): memmrk:	69796924	78508032
xdk:client:[2017-03-18T16:22:31.494Z]: (1489854151494): memmrk:	70310160	78508032
xdk:server:[2017-03-18T16:22:35.436Z]: (1489854155436): memmrk:	45121548	57495552
xdk:client:[2017-03-18T16:22:36.495Z]: (1489854156495): memmrk:	69886672	78508032
xdk:client:[2017-03-18T16:22:41.494Z]: (1489854161494): memmrk:	69954136	78508032
xdk:server:[2017-03-18T16:22:42.416Z]: (1489854162416): memmrk:	43120976	53301248
cordova-simulate-server:[2017-03-18T16:22:44.418Z]: (1489854164418): SIM:  Server started:
- App running at: http://localhost:55900/index.html
- Sim host running at: http://localhost:55900/simulator/index.html
cordova-simulate-server:[2017-03-18T16:22:44.646Z]: (1489854164646): SIM:  Simulated project plugins:
cordova-simulate-server:[2017-03-18T16:22:44.646Z]: (1489854164646): SIM:  { 'cordova-plugin-device': 'C:\\Users\\Developer Java\\AppData\\Local\\Intel\\XDK\\xdk\\components\\server\\simulator\\cordova-simulate\\src\\plugins\\cordova-plugin-device',
  'cordova-plugin-dialogs': 'C:\\Users\\Developer Java\\AppData\\Local\\Intel\\XDK\\xdk\\components\\server\\simulator\\cordova-simulate\\src\\plugins\\cordova-plugin-dialogs',
  'cordova-plugin-statusbar': 'C:\\Users\\Developer Java\\AppData\\Local\\Intel\\XDK\\xdk\\components\\server\\simulator\\cordova-simulate\\src\\plugins\\cordova-plugin-statusbar' }
cordova-simulate-server:[2017-03-18T16:22:44.652Z]: (1489854164652): SIM:  Creating app-host.js
xdk:client:[2017-03-18T16:22:46.495Z]: (1489854166495): memmrk:	69694312	78508032
xdk:server:[2017-03-18T16:22:47.565Z]: (1489854167565): memmrk:	58451532	79515648
cordova-simulate-server:[2017-03-18T16:22:48.112Z]: (1489854168113): SIM:  Creating sim-host.js
xdk:client:[2017-03-18T16:22:51.495Z]: (1489854171495): memmrk:	70288232	78508032
xdk:server:[2017-03-18T16:22:52.566Z]: (1489854172566): memmrk:	67544772	88952832
cordova-simulate-server:[2017-03-18T16:22:56.482Z]: (1489854176482): SIM:  Creating app-host.js: Existing file found and is up-to-date.
cordova-simulate-server:[2017-03-18T16:22:56.505Z]: (1489854176505): SIM:  Injecting app-host into C:\Users\Developer Java\AppData\Local\XDK\User Data\Default\xdk-scratchdir\4defde68-1c87-4727-8ea3-20e6d8d8fcb4\platforms\windows\www\index.html
cordova-simulate-server:[2017-03-18T16:22:56.579Z]: (1489854176579): SIM:  SIM_HOST connected to the server
xdk:client:[2017-03-18T16:22:56.829Z]: (1489854176829): memmrk:	72081668	83750912
cordova-simulate-server:[2017-03-18T16:22:57.212Z]: (1489854177212): SIM:  Setup handlers for SIM_HOST
cordova-simulate-server:[2017-03-18T16:22:57.213Z]: (1489854177213): SIM:  Handling pending emits for SIM_HOST
xdk:server:[2017-03-18T16:22:57.572Z]: (1489854177572): memmrk:	47526592	58544128
cordova-simulate-server:[2017-03-18T16:22:58.223Z]: (1489854178223): SIM:  APP_HOST connected to the server
cordova-simulate-server:[2017-03-18T16:22:58.226Z]: (1489854178226): SIM:  Setup handlers for APP_HOST
cordova-simulate-server:[2017-03-18T16:22:58.227Z]: (1489854178227): SIM:  Handling pending emits for APP_HOST
xdk:client:[2017-03-18T16:23:01.496Z]: (1489854181496): memmrk:	72197744	80605184
xdk:server:[2017-03-18T16:23:02.572Z]: (1489854182572): memmrk:	47413472	59592704
xdk:client:[2017-03-18T16:23:06.495Z]: (1489854186495): memmrk:	68937020	77459456
xdk:server:[2017-03-18T16:23:07.572Z]: (1489854187572): memmrk:	47516340	59592704
simulator-socket-server:[2017-03-18T16:23:09.851Z]: (1489854189851): Unexpected message from simulator-host to control-host { type: 'close' }
cordova-simulate-server:[2017-03-18T16:23:09.873Z]: (1489854189873): SIM:  APP_HOST disconnected from the server
simulator-socket-server:[2017-03-18T16:23:09.876Z]: (1489854189876): Adding message "close-simulator" to host "SIMULATOR" to pending emits
cordova-simulate-server:[2017-03-18T16:23:09.889Z]: (1489854189889): SIM:  SIM_HOST disconnected from the server
xdk:client:[2017-03-18T16:23:11.495Z]: (1489854191495): memmrk:	69757416	77459456
xdk:server:[2017-03-18T16:23:12.572Z]: (1489854192572): memmrk:	47521544	58544128
xdk:client:[2017-03-18T16:23:16.495Z]: (1489854196495): memmrk:	69726972	78508032
cordova-simulate-server:[2017-03-18T16:23:17.417Z]: (1489854197417): SIM:  Emitting 'server-message' to APP_HOST (pending connection)
cordova-simulate-server:[2017-03-18T16:23:17.417Z]: (1489854197417): SIM:  Emitting 'server-message' to SIM_HOST (pending connection)
xdk:server:[2017-03-18T16:23:17.572Z]: (1489854197572): memmrk:	47782116	58544128
client:simulator:[2017-03-18T16:23:18.941Z]: (1489854198941): Starting the simulator
cordova-simulate-server:[2017-03-18T16:23:18.944Z]: (1489854198944): SIM:  Emitting 'server-message' to APP_HOST (pending connection)
cordova-simulate-server:[2017-03-18T16:23:18.944Z]: (1489854198944): SIM:  Emitting 'server-message' to SIM_HOST (pending connection)
xdk:client:[2017-03-18T16:23:21.496Z]: (1489854201496): memmrk:	71027036	82702336
xdk:client:[2017-03-18T16:23:26.495Z]: (1489854206495): memmrk:	71715848	82702336
xdk:client:[2017-03-18T16:23:31.495Z]: (1489854211495): memmrk:	70899176	79556608
xdk:client:[2017-03-18T16:23:36.495Z]: (1489854216495): memmrk:	71500568	79556608
xdk:client:[2017-03-18T16:23:41.495Z]: (1489854221495): memmrk:	71111616	79556608
xdk:client:[2017-03-18T16:23:46.495Z]: (1489854226495): memmrk:	70807568	79556608
xdk:server:[2017-03-18T16:23:49.130Z]: (1489854229130): memmrk:	47790864	59592704
xdk:client:[2017-03-18T16:23:51.495Z]: (1489854231495): memmrk:	71104876	79556608
cordova-simulate-server:[2017-03-18T16:23:52.800Z]: (1489854232800): SIM:  Server started:
- App running at: http://localhost:55933/index.html
- Sim host running at: http://localhost:55933/simulator/index.html
cordova-simulate-server:[2017-03-18T16:23:52.890Z]: (1489854232890): SIM:  Simulated project plugins:
cordova-simulate-server:[2017-03-18T16:23:52.890Z]: (1489854232890): SIM:  { 'cordova-plugin-device': 'C:\\Users\\Developer Java\\AppData\\Local\\Intel\\XDK\\xdk\\components\\server\\simulator\\cordova-simulate\\src\\plugins\\cordova-plugin-device',
cordova-simulate-server:[2017-03-18T16:23:52.981Z]: (1489854232981): SIM:  Creating app-host.js
xdk:client:[2017-03-18T16:23:56.495Z]: (1489854236496): memmrk:	70919044	79556608
xdk:server:[2017-03-18T16:23:56.646Z]: (1489854236646): memmrk:	53362184	79515648
cordova-simulate-server:[2017-03-18T16:23:58.600Z]: (1489854238600): SIM:  Creating sim-host.js
xdk:client:[2017-03-18T16:24:01.495Z]: (1489854241495): memmrk:	71094532	79556608
xdk:server:[2017-03-18T16:24:02.075Z]: (1489854242075): memmrk:	67689632	86855680
cordova-simulate-server:[2017-03-18T16:24:03.536Z]: (1489854243537): SIM:  Creating app-host.js: Existing file found and is up-to-date.
cordova-simulate-server:[2017-03-18T16:24:03.539Z]: (1489854243539): SIM:  Injecting app-host into C:\Users\Developer Java\AppData\Local\XDK\User Data\Default\xdk-scratchdir\4defde68-1c87-4727-8ea3-20e6d8d8fcb4\platforms\ios\www\index.html
cordova-simulate-server:[2017-03-18T16:24:05.783Z]: (1489854245783): SIM:  APP_HOST connected to the server
xdk:client:[2017-03-18T16:24:06.495Z]: (1489854246495): memmrk:	73391932	81653760
xdk:server:[2017-03-18T16:24:07.076Z]: (1489854247076): memmrk:	52020796	88952832
cordova-simulate-server:[2017-03-18T16:24:07.545Z]: (1489854247545): SIM:  SIM_HOST connected to the server
cordova-simulate-server:[2017-03-18T16:24:07.944Z]: (1489854247944): SIM:  Setup handlers for SIM_HOST
cordova-simulate-server:[2017-03-18T16:24:07.945Z]: (1489854247945): SIM:  Handling pending emits for SIM_HOST
cordova-simulate-server:[2017-03-18T16:24:07.947Z]: (1489854247947): SIM:  Setup handlers for APP_HOST
cordova-simulate-server:[2017-03-18T16:24:07.948Z]: (1489854247948): SIM:  Handling pending emits for APP_HOST
xdk:client:[2017-03-18T16:24:09.404Z]: (1489854249404): Uncaught top-level Node.js exception: TypeError: fail is not a function
    at handleSavedSim (http://localhost:55933/simulator/sim-host.js:4549:13)
    at * (http://localhost:55933/simulator/sim-host.js:4475:17)
    at Socket.<anonymous> (http://localhost:55933/simulator/sim-host.js:281:17)
    at Socket.Emitter.emit (http://localhost:55933/simulator/thirdparty/socket.io.js:4:10860)
    at Socket.onevent (http://localhost:55933/simulator/thirdparty/socket.io.js:4:5790)
    at Socket.onpacket (http://localhost:55933/simulator/thirdparty/socket.io.js:4:5306)
    at Manager.<anonymous> (http://localhost:55933/simulator/thirdparty/socket.io.js:4:9520)
    at Manager.Emitter.emit (http://localhost:55933/simulator/thirdparty/socket.io.js:4:10860)
    at Manager.ondecoded (http://localhost:55933/simulator/thirdparty/socket.io.js:3:31751)
    at Decoder.<anonymous> (http://localhost:55933/simulator/thirdparty/socket.io.js:4:9520)
[Log closed from xdk:client]
xdk:server:[2017-03-18T16:24:12.077Z]: (1489854252077): memmrk:	52753032	88952832
xdk:server:[2017-03-18T16:24:17.078Z]: (1489854257078): memmrk:	47008868	59592704
PaulF_IntelCorp
Please use the "submit log" feature in the crash box and provide a description of the problem there. There's not much that can be done with those logs here in the forum, they are analyzed by engineering to determine the root cause if you send the crash log report.
