Software Archive
Read-only legacy content
17060 Discussions
Intel XDK Build Failed - Only Core Plugins Fail To Install
Nick_B_2
I am getting this error when I try to build for crosswalk 15 with the 5.1.1 Cordova CLI:
The build failed.
An error occurred while building the application. Verify your build assets are correct and try again.
Build Log:
  • The App ID is "www.bondappdev.yourchurch"
  • The App Name is "Your Church"
  • Preference android-signed set to true. Application will be signed.
  • Crosswalk Version: 15.44.384.7
  • Error: Plugin "Notification" failed to install.
  • Error: Plugin "File" failed to install.
  • Error: Plugin "File Transfer" failed to install.
  • Error: Plugin "Media" failed to install.
  • Error: Plugin "InAppBrowser" failed to install.
  • Error: Plugin "Device" failed to install.
  • Error: Plugin "Cordova Network Whitelist Plugin" failed to install.
  • Plugin "com.bunkerpalace.cordova.YoutubeVideoPlayer" (1.0.1) installed.
  • Plugin "cordova-plugin-secure-storage" (2.1.0) installed.
  • Plugin "cordova-plugin-actionsheet" (2.2.0) installed.
  • Plugin "cordova-sqlite-storage" (0.7.12-pre) installed.
  • Plugin "nl.x-services.plugins.backgroundaudio" (1.0.1) installed.
  • Plugin "cordova-plugin-x-socialsharing" (5.0.6) installed.
  • Plugin "com.telerik.plugins.nativepagetransitions" (0.5.4) installed.
Swati_S_Intel1
There is a problem with crosswalk build. I just talked with the build engineer and the fix will be available shortly.
Amrita_C_Intel
Have you tried building with CLI 4.1.2? Is it failing too?
Nick_B_2
I'll try building in CLI 4.1.2 right now....
Nick_B_2
The 4.1.2 failed as well....
Installing "com.bunkerpalace.cordova.YoutubeVideoPlayer" for android
Installing "cordova-plugin-secure-storage" for android
Installing "cordova-plugin-actionsheet" for android
Installing "nl.x-services.plugins.backgroundaudio" for android
Installing "cordova-plugin-x-socialsharing" for android
Installing "com.telerik.plugins.nativepagetransitions" for android
Installing "org.apache.cordova.device" for android
Installing "io.litehelpers.cordova.sqlite" for android
Installing "org.apache.cordova.file" for android
Installing "org.apache.cordova.file-transfer" for android
Installing "org.apache.cordova.inappbrowser" for android
Installing "org.apache.cordova.dialogs" for android
Installing "org.apache.cordova.media" for android
************* Processing the main config.xml file (after_prepare)  *****************
App Directory = [.../YourChurch]
Will process and update the following config files:
    Config.xml = [.../YourChurch/res/xml/config.xml]
Namespaces:
    prefix/uri ''/'http://www.w3.org/ns/widgets'
    prefix/uri 'intelxdk'/'http://xdk.intel.com/ns/v1'
Android Manifest Namespaces:
    prefix/uri 'android'/'http://schemas.android.com/apk/res/android'
Name of the app is [Your Church]
Updating full app name to [Your Church]
Processing preference android-minSdkVersion [19]
Processing preference android-targetSdkVersion [19]
Processing preference android-installLocation [auto]
Processing preference Orientation [portrait]
    Updated screenOrientation with value portrait
Processing preference permissions
Updating the versionCode
Updating the versionName
Processing debuggable
Added [{http://schemas.android.com/apk/res/android}debuggable] with [false]
Processing config file values
Saving config.xml to [.../YourChurch/res/xml/config.xml]
************* Completed processing the main config.xml file (after_prepare)  *****************
Buildfile: .../YourChurch/build.xml
-check-env:
 [checkenv] Android SDK Tools Revision 24.0.2
 [checkenv] Installed at /Developer/android-sdk-linux
-setup:
     [echo] Project Name: YourChurch
-set-mode-check:
-set-release-mode:
  [gettype] Project Type: Application
-pre-clean:
clean:
[getlibpath] Library dependencies:
[getlibpath]
[getlibpath] ------------------
[getlibpath] Ordered libraries:
-release-obfuscation-check:
     [echo] proguard.config is ${proguard.config}
-pre-build:
-check-env:
-setup:
-build-setup:
[getbuildtools] Using latest Build Tools: 21.1.2
     [echo] Resolving Build Target for YourChurch...
nodeps:
-check-env:
-setup:
     [echo] Project Name: XWalkCoreLibrary
  [gettype] Project Type: Android Library
-pre-clean:
clean:
   [delete] Deleting directory .../YourChurch/CordovaLib/xwalk_core_library/bin
   [delete] Deleting directory .../YourChurch/CordovaLib/xwalk_core_library/gen
nodeps:
-check-env:
-setup:
-pre-clean:
clean:
BUILD SUCCESSFUL
Total time: 1 second
[gettarget] Project Target:   Android 5.0.1
[gettarget] API level:        21
     [echo] ----------
     [echo] Creating output directories if needed...
    [mkdir] Created dir: .../YourChurch/bin
    [mkdir] Created dir: .../YourChurch/bin/res
    [mkdir] Created dir: .../YourChurch/bin/rsObj
    [mkdir] Created dir: .../YourChurch/bin/rsLibs
    [mkdir] Created dir: .../YourChurch/gen
    [mkdir] Created dir: .../YourChurch/bin/classes
    [mkdir] Created dir: .../YourChurch/bin/dexedLibs
     [echo] ----------
     [echo] Resolving Dependencies for YourChurch...
[dependency] Library dependencies:
[dependency]
[dependency] ------------------
[dependency] Ordered libraries:
[dependency]
     [echo] ----------
     [echo] Building Libraries with 'release'...
nodeps:
-set-mode-check:
-set-release-mode:
-pre-build:
-check-env:
-setup:
-build-setup:
     [echo] Resolving Build Target for XWalkCoreLibrary...
     [echo] ----------
    [mkdir] Created dir: .../YourChurch/CordovaLib/xwalk_core_library/bin
    [mkdir] Created dir: .../YourChurch/CordovaLib/xwalk_core_library/bin/res
    [mkdir] Created dir: .../YourChurch/CordovaLib/xwalk_core_library/bin/rsObj
    [mkdir] Created dir: .../YourChurch/CordovaLib/xwalk_core_library/bin/rsLibs
    [mkdir] Created dir: .../YourChurch/CordovaLib/xwalk_core_library/gen
    [mkdir] Created dir: .../YourChurch/CordovaLib/xwalk_core_library/bin/classes
    [mkdir] Created dir: .../YourChurch/CordovaLib/xwalk_core_library/bin/dexedLibs
     [echo] ----------
     [echo] Resolving Dependencies for XWalkCoreLibrary...
[dependency] No Libraries
[dependency]
-code-gen:
[mergemanifest] Merging AndroidManifest files into one.
[mergemanifest] Manifest merger disabled. Using project manifest only.
     [echo] Handling aidl files...
     [aidl] No AIDL files to compile.
     [echo] ----------
     [echo] Handling RenderScript files...
     [echo] ----------
     [echo] Handling Resources...
     [aapt] Generating resource IDs...
     [echo] ----------
     [echo] Handling BuildConfig class...
[buildconfig] Generating BuildConfig class.
-pre-compile:
-compile:
    [javac] Compiling 2 source files to .../YourChurch/CordovaLib/xwalk_core_library/bin/classes
     [echo] Creating library output jar file...
      [jar] Building jar: .../YourChurch/CordovaLib/xwalk_core_library/bin/classes.jar
-post-compile:
-obfuscate:
-dex:
     [echo] Library project: do not convert bytecode...
-crunch:
   [crunch] Crunching PNG Files in source dir: .../YourChurch/CordovaLib/xwalk_core_library/res
   [crunch] To destination dir: .../YourChurch/CordovaLib/xwalk_core_library/bin/res
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-hdpi/bubble.9.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-hdpi/bubble.9.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-hdpi/bubble.9.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-hdpi/bubble_arrow_up.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-hdpi/bubble_arrow_up.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-hdpi/bubble_arrow_up.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-hdpi/color_picker_advanced_select_handle.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-hdpi/color_picker_advanced_select_handle.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-hdpi/color_picker_advanced_select_handle.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-hdpi/dropdown_popup_background_down.9.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-hdpi/dropdown_popup_background_down.9.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-hdpi/dropdown_popup_background_down.9.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-hdpi/dropdown_popup_background_up.9.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-hdpi/dropdown_popup_background_up.9.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-hdpi/dropdown_popup_background_up.9.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-hdpi/ic_menu_share_holo_light.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-hdpi/ic_menu_share_holo_light.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-hdpi/ic_menu_share_holo_light.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-hdpi/ic_search.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-hdpi/ic_search.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-hdpi/ic_search.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-hdpi/ic_warning.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-hdpi/ic_warning.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-hdpi/ic_warning.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-hdpi/ondemand_overlay.9.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-hdpi/ondemand_overlay.9.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-hdpi/ondemand_overlay.9.png: 82% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-hdpi/refresh_blue.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-hdpi/refresh_blue.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-hdpi/refresh_blue.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-hdpi/refresh_gray.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-hdpi/refresh_gray.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-hdpi/refresh_gray.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-hdpi/verify_checkmark.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-hdpi/verify_checkmark.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-hdpi/verify_checkmark.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-xhdpi/bubble.9.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xhdpi/bubble.9.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xhdpi/bubble.9.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-xhdpi/bubble_arrow_up.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xhdpi/bubble_arrow_up.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xhdpi/bubble_arrow_up.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-xhdpi/color_picker_advanced_select_handle.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xhdpi/color_picker_advanced_select_handle.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xhdpi/color_picker_advanced_select_handle.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-xhdpi/dropdown_popup_background_down.9.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xhdpi/dropdown_popup_background_down.9.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xhdpi/dropdown_popup_background_down.9.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-xhdpi/dropdown_popup_background_up.9.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xhdpi/dropdown_popup_background_up.9.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xhdpi/dropdown_popup_background_up.9.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-xhdpi/ic_menu_share_holo_light.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xhdpi/ic_menu_share_holo_light.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xhdpi/ic_menu_share_holo_light.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-xhdpi/ic_search.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xhdpi/ic_search.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xhdpi/ic_search.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-xhdpi/ic_warning.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xhdpi/ic_warning.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xhdpi/ic_warning.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-xhdpi/ondemand_overlay.9.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xhdpi/ondemand_overlay.9.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xhdpi/ondemand_overlay.9.png: 64% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-xhdpi/refresh_blue.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xhdpi/refresh_blue.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xhdpi/refresh_blue.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-xhdpi/refresh_gray.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xhdpi/refresh_gray.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xhdpi/refresh_gray.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-xhdpi/verify_checkmark.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xhdpi/verify_checkmark.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xhdpi/verify_checkmark.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-xxhdpi/ic_menu_share_holo_light.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xxhdpi/ic_menu_share_holo_light.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xxhdpi/ic_menu_share_holo_light.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-xxhdpi/ic_search.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xxhdpi/ic_search.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xxhdpi/ic_search.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-xxhdpi/ic_warning.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xxhdpi/ic_warning.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xxhdpi/ic_warning.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-xxhdpi/refresh_blue.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xxhdpi/refresh_blue.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xxhdpi/refresh_blue.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-xxhdpi/refresh_gray.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xxhdpi/refresh_gray.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xxhdpi/refresh_gray.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-xxhdpi/verify_checkmark.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xxhdpi/verify_checkmark.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xxhdpi/verify_checkmark.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-xxxhdpi/ic_menu_share_holo_light.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xxxhdpi/ic_menu_share_holo_light.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xxxhdpi/ic_menu_share_holo_light.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-xxxhdpi/ic_search.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xxxhdpi/ic_search.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xxxhdpi/ic_search.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-xxxhdpi/ic_warning.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xxxhdpi/ic_warning.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xxxhdpi/ic_warning.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-xxxhdpi/refresh_blue.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xxxhdpi/refresh_blue.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xxxhdpi/refresh_blue.png: 106% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-xxxhdpi/refresh_gray.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xxxhdpi/refresh_gray.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xxxhdpi/refresh_gray.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable-xxxhdpi/verify_checkmark.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xxxhdpi/verify_checkmark.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable-xxxhdpi/verify_checkmark.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable/bubble.9.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable/bubble.9.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable/bubble.9.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable/bubble_arrow_up.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable/bubble_arrow_up.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable/bubble_arrow_up.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable/color_picker_advanced_select_handle.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable/color_picker_advanced_select_handle.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable/color_picker_advanced_select_handle.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable/dropdown_popup_background_down.9.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable/dropdown_popup_background_down.9.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable/dropdown_popup_background_down.9.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable/dropdown_popup_background_up.9.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable/dropdown_popup_background_up.9.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable/dropdown_popup_background_up.9.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable/ic_menu_share_holo_light.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable/ic_menu_share_holo_light.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable/ic_menu_share_holo_light.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable/ic_search.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable/ic_search.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable/ic_search.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable/ic_warning.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable/ic_warning.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable/ic_warning.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable/ondemand_overlay.9.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable/ondemand_overlay.9.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable/ondemand_overlay.9.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable/refresh_blue.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable/refresh_blue.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable/refresh_blue.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable/refresh_gray.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable/refresh_gray.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable/refresh_gray.png: 0% size of source)
   [crunch] Processing image to cache: .../YourChurch/CordovaLib/xwalk_core_library/res/drawable/verify_checkmark.png => .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable/verify_checkmark.png
   [crunch]   (processed image to cache entry .../YourChurch/CordovaLib/xwalk_core_library/bin/res/drawable/verify_checkmark.png: 0% size of source)
   [crunch] Crunched 48 PNG files to update cache
-package-resources:
     [echo] Library project: do not package resources...
-package:
     [echo] Library project: do not package apk...
-post-package:
-release-prompt-for-password:
-release-nosign:
     [echo]
[propertyfile] Creating new property file: .../YourChurch/CordovaLib/xwalk_core_library/bin/build.prop
[propertyfile] Updating property file: .../YourChurch/CordovaLib/xwalk_core_library/bin/build.prop
-release-sign:
-post-build:
release:
nodeps:
-set-mode-check:
-set-release-mode:
-pre-build:
-check-env:
-setup:
-build-setup:
     [echo] ----------
    [mkdir] Created dir: .../YourChurch/CordovaLib/res
    [mkdir] Created dir: .../YourChurch/CordovaLib/libs
    [mkdir] Created dir: .../YourChurch/CordovaLib/bin
    [mkdir] Created dir: .../YourChurch/CordovaLib/bin/res
    [mkdir] Created dir: .../YourChurch/CordovaLib/bin/rsObj
    [mkdir] Created dir: .../YourChurch/CordovaLib/bin/rsLibs
    [mkdir] Created dir: .../YourChurch/CordovaLib/gen
    [mkdir] Created dir: .../YourChurch/CordovaLib/bin/classes
    [mkdir] Created dir: .../YourChurch/CordovaLib/bin/dexedLibs
     [echo] ----------
[dependency]
[dependency]
-code-gen:
     [echo] ----------
     [echo] ----------
     [echo] ----------
-pre-compile:
-compile:
    [javac] Compiling 95 source files to .../YourChurch/CordovaLib/bin/classes
    [javac] Note: Some input files use or override a deprecated API.
    [javac] Note: Recompile with -Xlint:deprecation for details.
      [jar] Building jar: .../YourChurch/CordovaLib/bin/classes.jar
-post-compile:
-obfuscate:
-dex:
-crunch:
   [crunch] Crunching PNG Files in source dir: .../YourChurch/CordovaLib/res
   [crunch] To destination dir: .../YourChurch/CordovaLib/bin/res
   [crunch] Crunched 0 PNG files to update cache
-package-resources:
-package:
-post-package:
-release-nosign:
     [echo]
[propertyfile] Creating new property file: .../YourChurch/CordovaLib/bin/build.prop
[propertyfile] Updating property file: .../YourChurch/CordovaLib/bin/build.prop
-release-sign:
-post-build:
release:
-code-gen:
     [echo] ----------
     [echo] ----------
     [echo] ----------
-pre-compile:
-compile:
    [javac] Compiling 38 source files to .../YourChurch/bin/classes
    [javac] .../YourChurch/src/com/telerik/plugins/nativepagetransitions/NativePageTransitions.java:290: error: cannot find symbol
    [javac]             ((View) webView.getView().getParent()).setBackgroundColor(Color.parseColor(backgroundColor));
    [javac]                            ^
    [javac]   symbol:   method getView()
    [javac]   location: variable webView of type CordovaWebView
    [javac] .../YourChurch/src/com/telerik/plugins/nativepagetransitions/NativePageTransitions.java:427: error: cannot find symbol
    [javac]                   ((View) webView.getView().getParent()).setBackgroundColor(Color.BLACK);
    [javac]                                  ^
    [javac] Note: Some input files use unchecked or unsafe operations.
    [javac] Note: Recompile with -Xlint:unchecked for details.
    [javac] 2 errors
BUILD FAILED
/Developer/android-sdk-linux/tools/ant/build.xml:720: The following error occurred while executing this line:
/Developer/android-sdk-linux/tools/ant/build.xml:734: Compile failed; see the compiler error output for details.
Total time: 6 seconds
.../YourChurch/cordova/node_modules/q/q.js:126
                    throw e;
Error code 1 for command: ant with args: release,-f,.../YourChurch/build.xml
Swati_S_Intel1
Try now, it's fixed.
I mean Crosswalk build with Cordova CLI 5.1.1 works now.
Nick_B_2
Yep, it works now on 5.1.1. Thanks!
