Software Archive
Read-only legacy content
Intel XDK Push Notification - GCM
Tassyo_M_
Hi, good?
recently I am on a project que I have to use notification in the application, researched and found a plugin called phonegap-plugin-push, I Contacted plugin developers, asked to contact the team at Intel and here we are, how can I use GCM Intel XDK?
I tried to use the plugin mentioned above, no success, must have management of reports, I have the logic to be implemented, I get the regid, write to a bench made that I can manage ...
Some help on the above problem, push + GCM. + + XDK intel cross
Pamela_H_Intel
Tassyo,
I haven't used GCM myself, but I found some instructions for coding in JavaScript using GSM with Cordova that look reasonable (https://www.pubnub.com/blog/2014-12-18-sending-android-push-notifications-via-gcm-javascript-using-phonegap/) - just note that this article is almost a year old, so you will have to verify that all the plugins will work with CLI 5 (since that is what your push plugin requires).
Pamela
